06-30-2012, 04:53 PM | #101 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| Re: JIA's IFS Wraith build
Thanks dude, but I'm not so sure about the inspiring part. I love the all-business stance that it has, hope the suspension works properly. I'm enjoying being able to relax and build something my way. Been the first time in a LONG time I've been able/wanted to do so. I've decided to build ONE rig this time around. It's a fuggin' expensive build too! Not enjoying that part of it. I've had some questions about lighting, and how the brakes work. I'm using two kits, a G.T. Racing LED kit and a 3Racing LED kit. Pics of set-up/instructions for those that need it. I'm using the 3Racing kit for the rear lights, that's how I'm getting brake function. I could also have left/right turn indicators if I want. The G.T. kit has 12 sockets and you can program all 12 to be on any time the unit has power. I'm using this for the front lights since the 3Racing kit won't power all nine forward-facing lights and the four rear lights. I'd love to have the MadDogRC/Chino dual Exo bar up top, but I'll wait for now. Need motor/servos first. If I go to the Dual Exo light bar I could get away with using only the 3Racing LED kit. Last edited by JasonInAugusta; 06-30-2012 at 05:08 PM. |
07-01-2012, 04:15 AM | #102 |
Made a battery mount from recycled Wraith parts. Cut a section out of the Wraith steering link, center drilled it, and trimmed down the Wraith battery tray to make battery install/removal easier. Also had to cut off one of the loops for the battery straps so the arm on the steering servo would clear. Battery is mounted nice and low now. Last edited by JasonInAugusta; 07-01-2012 at 01:57 PM. |
07-01-2012, 08:06 AM | #103 |
Pebble Pounder Join Date: Oct 2008 Location: Canada
| Re: JIA's IFS Wraith build Thanks for the inspiration Can you help me with how you fit the wraith bumper on it ??? |
07-01-2012, 10:20 AM | #104 |
Rock Stacker Join Date: Nov 2006 Location: The road less traveled. Now where the Hell am I?
Your probably chomping at the bit to have a garage again and not have to work off a table. This is a cool build.
07-01-2012, 11:53 AM | #105 | ||
| Re: JIA's IFS Wraith build Quote:
I'll get a picture of how I trimmed the Wraith bumper later. Camera is put away right now and battery is on charge. Quote:
Then, for whatever reason, I started tearing the Exo apart and the next thing I knew I had picked up a cheap hack saw. I made one cut with that hack saw. Everything else has been Sharpie and Dremel work. But soon I'll be able to get back into familiar territory. | ||
07-01-2012, 01:10 PM | #106 |
You should put this build on the garage journal also. That crew may get a kick out of crawlers. They really liked your other projects.
07-01-2012, 01:32 PM | #107 |
| Re: JIA's IFS Wraith build I didn't had to drive it yet a part of the steering is missing. When I bought the extra Exo kit it was because of my poor driving abilities. I distroyed the front left of the Exo in a crash. I'm waiting for parts to come soon and I will test drive then. Here, how it is, waiting for that steering link and if you cut your bottom plate just a tad longer you will be alble to use the 94 mm dog bone for the front drive shaft. You can see it in the second pic. I will keep watching your great built. |
07-01-2012, 01:46 PM | #108 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
| Re: JIA's IFS Wraith build |
07-01-2012, 01:55 PM | #109 | |
Big feet, I never thought about that. Might do it. DoubleJ, it's two washers. One countersunk, one cone. Drill hole, put washers on opposite sides, tighten the screw and nut. Done. Oh, here's the pics of the trimmed bumper and how it mounts. Just mark and cut the Wraith bumper so it will mount on the upper hinged/shock-absorbing front Exo skid mount. Then grab some longer screws and bolt it in. Last edited by JasonInAugusta; 07-01-2012 at 02:19 PM. | |
07-02-2012, 01:45 AM | #110 |
Had some clearance issues with the rear sway bar and the servo arm. Bent a new sway out of 3/32" stainless. Stainless wasn't my first choice, but it's all the LHS had in the size I needed. I'll make a new sway when they get regular stuff back in stock. Ground flats on each end for the lever arm setscrews and stuck it in place. Flats are ground so the arms/sway are level at full droop. Here's the "stock" flex with no grinding to soften the thing. Also, the little butane torch I picked up to make the bends. Last edited by JasonInAugusta; 07-02-2012 at 12:21 PM. |
07-02-2012, 02:18 AM | #111 |
Newbie Join Date: Nov 2009 Location: Russia
Can anyone post the part-list for the IFS conversion?
07-02-2012, 08:14 AM | #112 |
Keep the build pictures coming! Nice detailed build. I too have been inspired and bought up a wraith chassis and exo kit. I'll be running a truck body of some kind with a centered rear wraith axle. |
07-02-2012, 10:50 AM | #113 | |
07-02-2012, 04:50 PM | #114 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
07-02-2012, 05:13 PM | #115 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
07-02-2012, 05:36 PM | #116 |
Quarry Creeper Join Date: Jun 2006 Location: Aurora, CO
JIA, did you have to use wideners to get the wheels to clear the ExoTerra knuckles? Can you take a picture or two showing the clearance between the wheel and the knuckle?
07-02-2012, 06:49 PM | #117 |
| Re: JIA's IFS Wraith build These wheels don't fit. I need wideners due to offset. Right now there are just a couple of threads holding the front wheels on.
07-02-2012, 07:03 PM | #118 |
07-02-2012, 07:29 PM | #119 |
I believe the technical term is "wider than a maf*****a"
07-02-2012, 08:44 PM | #120 | |
I don't have much to measure with, but 8-10mm per side should work. Just need proper hexes and barrel nuts. I'll probably pick up some VP OMF 2.2s when they're ready. That will allow the use of VP's hub system to fine tune things. If I can't get what I want between now and the 22nd in aluminum, I'll run the Integy wheels I have here. THOSE fawkin' things make it wide. With the RC4WD Predators (pictured above) knuckle clearance is the only issue up front. Does anyone make some thin beadlock rings for the RC4WD wheels? I can't remember. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/388684-jias-ifs-ultra4-build.html | ||||
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - Axial Wraith | This thread | Refback | 03-01-2013 02:33 PM | |
Axial Racing - Project Wrexo – Bender’s Latest Custom Build | This thread | Refback | 02-18-2013 03:40 PM |
JIA's IFS Ultra4 build - Similar Threads | ||||
Solid axle Ultra4 build | JasonInAugusta | Axial Wraith | 79 | 07-08-2013 09:32 PM |
DTP's KOH IFS Ultra4 | DISTURBIN' tha PEACE | Scale Videos! | 7 | 12-20-2012 09:21 AM |
JIA's IFS KOH Ultra4 Wraith Conversions | JasonInAugusta | Chassis and Suspension | 77 | 11-10-2012 10:27 PM |
IFS axial build | red_zook | General Scale Talk | 6 | 04-28-2012 08:43 AM |
Ultra4/KOH build of doom | Ruff11 | 2.2 Scale Rigs | 14 | 10-10-2011 08:11 PM |
