Thread: JIA's IFS Ultra4 build
Old 07-06-2012, 09:07 AM   #141
Default Re: JIA's IFS Wraith build
Would of been a lot cooler if it was!!!
4xFord is offline   Reply With Quote
Old 07-06-2012, 11:11 AM   #142
Whatever happened with Jax??
Looks SICK JIA!!! Glad to see you are back!! Do you still have the Hydro Scorpion?
Going Up! is offline   Reply With Quote
Old 07-06-2012, 11:19 AM   #143
WOOPOOW!!
Really enjoying your build JIH! Keep the build pics comin man!
Colby is offline   Reply With Quote
Old 07-06-2012, 01:07 PM   #144
06 Super National Champ
JasonInAugusta's Avatar
Reminds me of Dazed and Confused
"Well alright, alright, alright."
"Lemme tell ya what Melba Toast is packin'."
Hensel has the hydro scorpion. I sold off a lot of the old crawlers, gave some away, threw some away, and gave away about 60 airplanes to my wife's soldiers. Also gave them boats, crawlers, and other stuff.
Thanks, man. I'll keep'm coming.
JasonInAugusta is offline   Reply With Quote
Old 07-08-2012, 12:42 AM   #145
Playing with panel ideas.
Old 07-08-2012, 12:46 AM   #146
lookin effin wild!
keep up the great work
SwampDawg is offline   Reply With Quote
Old 07-08-2012, 06:57 AM   #147
Great work JIA
I tested mine and here is what I found.
The truck is very stable at speed and will be a great trail truck.
The miss are in the steering, the throw is not enough for crawling. The steering components I have on the truck are the stock plastic one and I have to much plastic bend with a 430 oz servo. I will have to go aluminum and find a way to get more steering out of it.
I also thought that I had the front diff locked but it freed up. I had it in hot glue but that is not enough, will have to find a better way to do it.
Here are some pics of how did my front bumper as you showed me in your pics but I add 2 brace to the frame to keep the bumper from flipping backward.
Thanks for the inspiration and keep the great work. I will be playing to find a fix for the steering and I will let you know what I find.
Bullitrockcrawl is offline   Reply With Quote
Old 07-08-2012, 09:10 AM   #148
CA glue the diff gears ^^
Old 07-08-2012, 12:36 PM   #149
I'd use epoxy, that stuff is good. Or buy some difflocking fluid and you can take it off later.
Chili is offline   Reply With Quote
Old 07-08-2012, 12:53 PM   #150
Originally Posted by Bullitrockcrawl View Post
Great work JIA
I used a Wraith locker up front with the Exo universals.
For steering, I added rear steer. Use the stock Wraith stuff out back. Also, make sure you move the steering toe links to the forward-most hole in the steering rack. That will give you a little more throw.
I plan to use the stock Wraith bumper braces, just haven't got to that yet.
Old 07-08-2012, 01:10 PM   #151
GMV
I love this build. But it must be a rather costy one if it takes two kit's to build one. And it would be even more if you load it with aftermarket parts!
GMV is offline   Reply With Quote
Old 07-08-2012, 05:33 PM   #152
Quote "I used a Wraith locker up front with the Exo universals."
How did you lock the the output shaft Axial EXO Heavy Duty Differential Output Shaft on the wraith locker ????
Thanks for all the help.
Old 07-08-2012, 09:30 PM   #153
I didn't worry about it. I put O-rings in the drive cups to take up slack when I built the Exo. Using Exo drive cups slid in to the Wraith locker.
They can't come out - there's nowhere for them to go. The dogbone end of the universal keeps the drive cups in.
Old 07-08-2012, 11:04 PM   #154
I JB welded my exo front but the downfall is that if I smoke a diff bearing or ring gear I'll have to replace all of it as a unit. I dont think i'd trust o-rings to keep the output "D" from slipping out of the side gears.
frdtrkguy is offline   Reply With Quote
Old 07-09-2012, 03:22 AM   #155
There are no side gears, just a solid locker. The O-rings go IN the drive cups to keep the stock Exo dogbones from popping out of the drive cup at the steering knuckle.
With universals installed I left the O-rings in place. The diff drive cups can't pop out because they're kept in place by the universal shaft/dogbone - whichever you're using.
It's no different than simply sliding your Wraith shafts in place and allowing the ends of the axle shafts to sit in the Wraith locker.
I'm doing the same thing, but by using the Exo drive cups, I can use the Wraith Locker (or any aftermarket locker like a Felsenfest) and tighten the locker setscrews (with aftermarket) on the drive cups instead of the axle shafts.
Only REAL difference is I have a hinge point (drive cup/dogbone) on each drive side that allows the IFS to work.
Make sense?
Old 07-09-2012, 04:53 AM   #156
I will give it a try with the stock dog bone, the universal are on there way. Playing the parts waiting game again.
Thanks again
Old 07-09-2012, 12:29 PM   #157
Make sense?
I said side gears 'cause that is how mine is set-up. I understand that your using a spool. Same same..
I see where your coming from but what happens when the o-rings get torn and spit out by the end of the dog bone plunging in and out when the suspension cycles?
One of those clamping spools would probably be the best idea.
Old 07-09-2012, 02:44 PM   #158
You'd be surprised at how long people have been using O-rings for things like this. It's fairly common. They last a long time, too.
Small update. MadDogRC lights arrived.
The dual 4" Exo bar fits perfect.
Later today I'll install the others.
Night runs WILL NOT be an issue.
Old 07-09-2012, 03:59 PM   #159
I like how much crap you guys are giving him over the out drive cups.
He built this thing in a hotel room with little more than a few hand tools, I'm sure he made sure they aren't gonna fall out.
XSRCdesign is offline   Reply With Quote
Old 07-09-2012, 04:03 PM   #160
give that poor guy a break!
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-wraith/388684-jias-ifs-ultra4-build.html
Posted By For Type Date
RC Elétrico - o fórum de automodelismo elétrico! • Tópico: - Axial Wraith This thread Refback 03-01-2013 02:33 PM
Axial Racing - Project Wrexo – Bender’s Latest Custom Build This thread Refback 02-18-2013 03:40 PM
JIA's IFS Ultra4 build - Similar Threads
Solid axle Ultra4 build JasonInAugusta Axial Wraith 79 07-08-2013 09:32 PM
DTP's KOH IFS Ultra4 DISTURBIN' tha PEACE Scale Videos! 7 12-20-2012 09:21 AM
JIA's IFS KOH Ultra4 Wraith Conversions JasonInAugusta Chassis and Suspension 77 11-10-2012 10:27 PM
IFS axial build red_zook General Scale Talk 6 04-28-2012 08:43 AM
Ultra4/KOH build of doom Ruff11 2.2 Scale Rigs 14 10-10-2011 08:11 PM
