06-29-2012, 08:29 PM | #41 |
Newbie Join Date: Jul 2011 Location: Australia
| Re: What did you do to your Wraith today?
Cut the cage ! |
06-29-2012, 10:15 PM | #42 |
Rock Stacker Join Date: Feb 2012 Location: Flinthills
Tore mine apart, stock motor is toast. Waiting for funds for a Crawlmaster.
07-02-2012, 06:15 AM | #43 |
Pebble Pounder Join Date: Aug 2011 Location: Gresham, OR
I stripped a gear from a spektrum servo, I plan on upgrading to a Hitec 7955. Don't ask why I had a spektrum in the first place.
07-02-2012, 10:13 AM | #44 |
Newbie Join Date: Dec 2004 Location: Phoenix, AZ
I haven't installed everything yet, but I picked up a new set of R35 Ripsaws, Integy 5 spoke beadlocks, Savox SC-1268SG servo and a CC BEC. Anyone know if I actually need the BEC with this servo? It sounds like I can run the positive and negitive wire right to the servo. It says it can be ran of a unregulated Lipo. I'm running a 2S lipo....specs below. This is the Savox SC-1268SG High Torque Steel Gear Digital Servo (High Voltage). Savox have now released their 'High Voltage' servo line that can be powered by a unregulated LiPo battery! These servos also feature a redesigned motor/controller unit, and use a 'bullet proof' all steel gear set for unmatched strength. Features: •Combines leading edge technology with super high 12 bit (4096) resolution. •Higher performance due to increased voltage and improved technology •Incredible torque •Increased transit speed •Increased efficiency •Water resistant with 4 silicon seals implanted •Strong and precise-made steel gears •Suitable for 1/8th nitro racing and large scale aircraft, 600 and 700 class helicopters. Dimensions(mm): 40.3x20.2x37.2 Weight(g): 62.0 Speed(@4.8V sec/60): .15 Torque(@4.8V oz-in): 160.0 Speed(@6.0V sec/60): .13 Torque(@6.0V oz-in): 208.3 Speed(@7.4V sec/60): .11 Torque(@7.4V oz-in): 347.2 Gear: Unique Steel Bearing: 2BB Case: Aluminum 25 Tooth Spline |
07-02-2012, 10:28 AM | #45 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
It's wise to run a BEC with that servo so you can regulate power to it. You'll likely want to program the BEC to output to 7.0V-7.4V to get the maximum amount of torque out of the servo. I know it says you can run it unregulated, but certainly not a chance I'd want to take with an expensive servo. I think most here will tell you a simple rule of thumb regarding BEC's. If you have a crawler............ ......you need a BEC. |
07-04-2012, 06:40 PM | #46 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
I Cut the rear of my cage off today and made some new rear cage links out of 1/4" tubing and revo rod ends. I also added some styrene diamond plate upper shock area covers. Ohh yeah ordered the rubicon body, dinky cargo tub, hr steel spools and axial hub covers! Good day |
07-04-2012, 09:31 PM | #47 |
Quarry Creeper Join Date: May 2012 Location: Houston
Stainless Screws all around!
07-04-2012, 10:05 PM | #48 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
Replaced my STRC knuckles, C-hubs, lower shock mounts and rear lockouts with VP knuckles, C-hubs, lower shock mounts and rear lockouts. Mounted my new VP SLW V3 (Ripsaw tires with C.I. Double Deuce 5.25 foams) on my Wraith. After replacing and installing the VP stuff today, the quality of VP's parts is unmatched! Everything fit and went together like silk! Once again, hats off to the guys at VP!!! |
07-05-2012, 07:20 AM | #49 |
Charged up my 5000mah 2S Lipo. Maybe this evening the new Axial uni's will go in.
02-28-2013, 07:31 PM | #50 | |
Quarry Creeper Join Date: May 2012 Location: Baja, Mex / Calexico, Ca.
| Re: What did you do to your Wraith today? Quote:
02-28-2013, 07:32 PM | #51 |
| Re: What did you do to your Wraith today? |
02-28-2013, 07:46 PM | #52 |
been working on a servo winch |
02-28-2013, 08:11 PM | #53 |
Ordered a RC4WD center diff rear axle, installed VP floating lockers and a set of VVD's and swapped out the 7954 for 7950.
02-28-2013, 08:13 PM | #54 |
Rock Stacker Join Date: Jan 2013 Location: St George
I put in my new motor and gearing. Then went out and was blown away with the things it would crawl up.
02-28-2013, 09:23 PM | #55 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
added some scale beer to my rig and charcoal bag lol
03-01-2013, 08:16 AM | #56 |
Rock Stacker Join Date: Feb 2013 Location: Apache Junction
I dropped and painted mine and tonight I will be upgrading my transmission gears |
03-01-2013, 04:59 PM | #57 |
What does dropped mean?
03-01-2013, 05:21 PM | #58 |
03-01-2013, 05:35 PM | #59 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
Looked at it on the shelf this morning,...and cried as I left for work. I miss her. :(
03-01-2013, 08:03 PM | #60 |
Rock Stacker Join Date: Dec 2012 Location: rochester
Just orderedsome bgr sliders and bgr v2 rear bumper. Gor a bgr stinger front bumper a couple days ago. Good stuff!
What did you do to your Wraith today? - Similar Threads | ||||
Got My Wraith Today... | NFA Fabrication | Axial Wraith | 63 | 12-07-2011 07:37 AM |
Got my Wraith today | 98sierra | Axial Wraith | 15 | 06-27-2011 01:58 PM |
