07-24-2011, 07:07 PM | #1 |
Quarry Creeper Join Date: Sep 2008 Location: Australia
| Tekin T8 into Wraith
I'm a little strapped for time right now, so I don't have a lot of spare time to just try doing this mod so I'll ask you guys. Has anyone fitted a Tekin T8 into their Wraith? I'm not wanting to butcher the floor pan. Trying to keep the "scale" looks but add a little more boost. |
07-24-2011, 07:19 PM | #2 |
There will be all kinds of issues trying to fit that. Motor is too long, doesn't bolt onto an Axial transmission and interference with the interior. Not many of us have all the time in the world, do some work and make it fit if you want. Nobody's going to do it for you! |
07-24-2011, 07:45 PM | #3 |
Rock Crawler Join Date: Jul 2010 Location: youngstown , Hillbilly heaven
You can buy me the system and then I'll tell you how.
07-24-2011, 11:38 PM | #4 |
RCC Addict Join Date: Nov 2004 Location: union
I am running a summit trans with wraith axles, a t8 1550kv t8 motor on 4s and 6s. So far the axles are holding up fine. |
07-25-2011, 12:06 AM | #5 |
Pebble Pounder Join Date: Jan 2011 Location: augusta
You can make anything work. But there's not a t8 kit you cam buy. I got a t8 mounted to my axial trans with no more than a drill bit and patience. Good luck
07-25-2011, 12:27 AM | #6 | |
I guess I'd better go build something new to put the T8 into Thanks for the help | |
02-14-2013, 04:18 PM | #7 |
Newbie Join Date: Aug 2008 Location: space
| Re: Tekin T8 into Wraith
I know this is an old thread but has someone come up with a solution. What did you need to do to fit the T8 into the wraith? |
02-15-2013, 03:44 PM | #8 |
Quarry Creeper Join Date: Sep 2009 Location: Detroit
I swapped it for a pro 4 since I didnt want to run more than a 3s and I wasnt looking forward to doing what needed to be done in order for it to fit into the wraith belly.
02-15-2013, 08:01 PM | #9 |
Damn dude it works. Just got a clearance the skid plate for length and shim the tranny up. Looks like I'm still the only one running a 1/8 scale motor. 2100 kV 2250 watts yeah baby |
03-05-2013, 01:46 PM | #10 | |
| Re: Tekin T8 into Wraith Quote:
Is there drop trans plate available for this swap? Who makes them? | |
03-05-2013, 04:08 PM | #11 |
i think theres a motor plate available that works. i reworked my motor plate with a dremel. ill work on the pics clearenced into the link mount quite aways. also took the ribbs out of the inside of the skideplate. didnt realy need to could have to just shimmed tranny up. used 5.5mm bulletts also removed some cooling fins so the motor would sit closer to the tranny. with 60 spur this wouldnt be neccesarry. ive ran 66 and 56 spurs this motor is super smooth on 66 spurr. 66 spurr took some modding to get on to. motor and esc combo was 100 bucks shipped so i wanst scared to grind the fins off the motor. with 0 timing this motor runs cold and has seen probly 10 hours or more of run time with no issues. 150 track star esc also works awesome. heres how my wraith sits after the last 6s run. so far this combo has stripped all the tranny gears broke a few drivelines and smokked both diff lockers. ive been getting into crawling latly and running scale comps and on 3s this motor does pretty dang well. its not smoothest or most ideal setup but it does pretty dang good with the trackstar drag brake set at 100% and good 3s battery is surprisnly smooth for being sensorless Last edited by evan03; 03-05-2013 at 04:42 PM. |
03-05-2013, 04:27 PM | #12 |
Rock Crawler Join Date: Nov 2008 Location: missoula
It's gotta fit I put mamba monster in my exo clearances a few areas 2100 kv motor huge on 4s that baby flew and the drive train held up great very tough those wheels would spin 30 yards until I had to let off very stable to.
03-05-2013, 04:43 PM | #13 |
anything fits if you want it to bad enough
03-05-2013, 04:49 PM | #14 |
What part of the lockers failed?
03-05-2013, 04:51 PM | #15 |
the plastic part. carrieres i guess theyd be called hot raceing lockers should be on my door step tommorrow |
03-06-2013, 11:52 AM | #16 |
snagged a pic of the hood off the 150 trackstar esc |
04-07-2013, 01:37 AM | #17 |
Rock Stacker Join Date: Feb 2012 Location: Kelso,wa
Looks good. Thanks for the pics that helps me too. Got a wraith yesterday, and have a tekin rx8/T-8 that I want to put in. Looks like its only a few grinds away!!!
04-07-2013, 09:27 AM | #18 |
Might need to mod the motor plate to bolt it on
