10-24-2012, 11:25 PM | #61 |
Quarry Creeper Join Date: Apr 2011 Location: Denver
Some of the last wiring done, the end of the tunnel is in sight! |
10-25-2012, 12:17 AM | #62 |
Interior pics! Now that this is in I can add all the details! |
10-31-2012, 07:33 AM | #63 |
Decals added then clear coat Who is that shadowy figure? I removed the axial aluminum shocks and want to go with some 120mm shocks for more travel. I have HR shocks on my crawler and they work great anybody have other suggestions? Funny car action |
10-31-2012, 07:34 AM | #64 |
Almost forgot, got a snorkel too! |
11-16-2012, 02:48 AM | #65 |
These just showed up in the mail! |
11-16-2012, 06:59 AM | #66 |
Rock Stacker Join Date: Oct 2012 Location: Connecticut
| Re: Trazh's Wraith Build
OK this is my officialy my favorite wraith I've seen. How is the paint in the frame holding up? The way the body tilts up is a very nice touch. *subbed |
11-16-2012, 07:53 PM | #67 |
This has been in the build garage for 4 months, hasn't seen a single run yet, but it is close to being done!
11-17-2012, 11:31 AM | #68 |
Newbie Join Date: Nov 2012 Location: Arvada
Really nice build! Can't wait to see it in action and what driver you've got hiding. The Stig?! |
11-18-2012, 05:57 PM | #69 |
| Installed Novak 20t brushed tonight. Stripped of the decal to match the silver. |
12-17-2012, 10:34 AM | #70 |
Newbie Join Date: Nov 2012 Location: SoCal
| Re: Trazh's Wraith Build |
12-30-2012, 10:27 PM | #71 |
Finished up the wiring, next up, connection of the electronics! Got the shocks filled and mounted. Bottom skids attached, interior finished and driver installed. Busy day and a lot done. Still some more to go though. Last edited by Trazhcan; 12-30-2012 at 10:35 PM. |
01-02-2013, 11:38 PM | #72 |
Getting the electronics all to fit in this box...hmmmmmmm |
02-28-2013, 12:26 AM | #73 |
Late Night Bender!!!!! Just have to attach to hood to the hinge panel. Added some accessories I have been storing up. |
02-28-2013, 12:27 AM | #74 |
02-28-2013, 12:43 AM | #75 |
02-28-2013, 01:26 AM | #76 |
Rock Crawler Join Date: Oct 2011 Location: Vertical Junkie
| Re: Trazh's Wraith Build Pretty Nice Bro.... Even your driver is off the Hook!!!
04-09-2013, 12:25 AM | #77 |
Bullit proofed the tranny last night! One tough retrofit! |
04-09-2013, 12:26 AM | #78 |
Got some more work done tonight. Removed the chassis mounted servo for starters. I was getting all kinds of binding int eh suspension even with removing one of the upper links, plus I feel the axle mount servo will give me more strength. I bolted down the hood to the panel I used for the hinged hood. Added some decals and changed the socks and shoes. I took these from another build I am currently working on. Mickey Thompsons. I ran it a little around the living room and the bedroom. I tried to climb some small area and had no strength. Its geared 80/20 at this point with a 20t motor. I got some blue smoke from trying to make it climb a small matress. Think I need to gear down or go to a 35t motor instead. Thoughts? Suggestions? |
04-09-2013, 12:27 AM | #79 |
So I lost the wheels for now with the mickey thompsons and went back to the original tires and wheels. I think the blue wheels I had are really cheap and dont hold the tire in the bead very well. I also lost the axle wideners as in just basic testing of operation I found the larger tires really hard to steer. Even with 7v going to the steering servo it still struggled and was a day and night difference after I removed them. I burned up a Novak 20t motor so I installed an RC4WD 35t and changed the pinion from 20t to 16t. The whole drive system is really solid and I am impressed with the strength. I waterproofed the servo and installed that. Oh yeah and added some side view mirrors. I am for now going to call this done, but its never really done, I already have some ideas for it but I need to get this thing dirty and on the rocks already! |
04-09-2013, 12:29 AM | #80 |
So I finally got it out on the rocks. My complex has some great spots to crawl on next to the lake. Performance was overall great. I did however fry the servo, which is weird because I have used this same servo on my AX10 with no issues. Maybe it was just a defective one. I am pumping 7v from a Castle BEC and the servo is rated to 7.4. ( I have learned from the past to not push the high rating because they seem to over rate things in this industry) I have to tear into the vehicle and snake out the old servo then install the new one. This time I will make it easier to remove by adding a connector closer to the servo location. I also need to maike it easier to access the electronics so I am looking at the rear cage mod that is made by BGR fabrications that hold the spare tire. I will be loosing the roof rack and a majority of my accessories but I prefer the ease of use over the looks. Anyways here is a pic of it on the rocks! |
Trazh's Wraith Build - Similar Threads | ||||
1.9 Wraith build | rckjeep | Axial Wraith | 25 | 07-07-2012 02:47 AM |
New Wraith Build | Savage121 | Axial Wraith | 1 | 06-03-2012 02:03 PM |
My Wraith Build | acesal | Axial Wraith | 29 | 05-02-2012 09:59 PM |
My First build the wraith | redneckrampage | Axial Wraith | 5 | 04-18-2012 09:44 PM |
Wraith build | pwrwgn2000 | 2.2 Scale Rigs | 2 | 10-17-2011 07:27 AM |
