06-06-2013, 06:04 PM | #81 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Been getting her ready for axialfest. I lengthened the chassis by about 3/4 of an inch, went with a SS bulletproof trans, switched to an rx8 and 4000kv pro4, new wheels and all new bearings. The wheelbase is just about 13 3/4 Chris M |
06-24-2013, 08:09 PM | #82 |
Switched to Boss Claws for Axialfest Terra X.. The rig took a beating and worked perfectly!! Chris M |
06-25-2013, 01:38 PM | #83 |
| Re: Terra-Wraith now with MIP mod
It looks like you don't like those OMF's with Pitbulls on them. I'll do you a favor and take them |
06-25-2013, 08:58 PM | #84 |
07-23-2013, 07:15 PM | #85 |
I got tired of the plastic gear cases deflecting under load and I had to replace the wasted r&p so in goes more aluminum.
07-23-2013, 08:43 PM | #86 |
Getting closer.. My goal is to have the most expensive wrexo out there.. lol Last edited by frdtrkguy; 07-23-2013 at 08:55 PM. |
07-23-2013, 09:31 PM | #87 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
That is one wicked looking rig. I just went and looked at my wraith and exo. And if I didn't race my exo I would probably be in there tearing the wife's wraith apart. And then sleeping on the couch. Again. Nice job.
07-23-2013, 10:47 PM | #88 |
RCC Addict Join Date: Dec 2012 Location: Crookston
Damn. That is really nice. Wish MIP made shafts for the Exo. I would get a set. Can't wait to see more progress.
07-23-2013, 11:32 PM | #89 |
Pebble Pounder Join Date: Dec 2009 Location: Highlands Ranch
Did you run MIP's in the rear too...or just the front?
07-24-2013, 07:08 AM | #90 |
| Re: Terra-Wraith now with MIP mod |
07-24-2013, 06:01 PM | #91 |
Maybe I missed it, but what did you have to do to make the MIP stub axles fit the Exo knuckles? I assume your using Slash 4wd stub axles, correct? Looks like you've got it so bulletproofed all you'll break are diff carrier and pinion bearings. |
07-24-2013, 06:37 PM | #92 |
| The knuckle needs to opened up a little to clear the huge CV bell, I used a carbide burr. And, you need some 10mm shims behind the inner knuckle bearing for proper spacing. The durability is WELL worth the effort.
07-25-2013, 08:00 PM | #93 |
My old front brace wouldn't work due to the new front bulkhead holes being a little different so I had to improvise. |
07-25-2013, 09:18 PM | #94 |
I ran into a problem while disassembling the rear. The screw pin head broke off in the mip hub and it won't come out with a punch. Looks like I may have to take angle grinder to it and replace em with new ones. Never mind, I was able to drill it a little and punch it out. The only casualty was the screw pin. Last edited by frdtrkguy; 07-25-2013 at 09:27 PM. |
07-26-2013, 08:32 AM | #95 |
Rock Crawler Join Date: Oct 2011 Location: Vertical Junkie
Its lookin good big Chris, I think you have perfected the EXO into the ultimate G-ride... Whens the rear steer mod coming out? ****Axial, Plz take note, You NEED to Hire this guy***** |
07-26-2013, 10:30 AM | #96 | |
| Re: Terra-Wraith now with MIP mod Quote:
I have contemplated rear steer and dig. The only way I would do rear steer is if I added a 4 link solid rear then this rig would be just like every other wrexo out there and I like being a little different Dig would be a good mod but would add more moving parts to fail. She's no comp rig and reverses are free so Ill probably just keep it as is. | |
07-26-2013, 03:25 PM | #97 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
Nice build so far, it looks like it would be fun to drive. You can use a soldering iron to heat up those small screws and pins to help the loctite let loose so you can get them out without breaking allen wrenches inside them. |
07-26-2013, 03:42 PM | #98 | |
The allen tip didn't break, it was the screw pin it's self that broke just past the threads. I suspect it was already cracked from the torque load since it snapped with very little effort. Good tip, using the soldering iron though. | |
07-26-2013, 08:32 PM | #99 |
I got the rear back together. |
07-26-2013, 10:28 PM | #100 |
And ready for the topper. I didn't mean to get my fugly toes in the pic Last edited by frdtrkguy; 07-26-2013 at 10:45 PM. |
Terra-Wraith now with MIP mod - Similar Threads | ||||
6 X 6 terra-pup | bl4derr1 | Tamiya Clod Buster | 14 | 09-23-2012 09:14 PM |
Terra-Nova | hotrodsonoma | Chit Chat | 108 | 12-24-2011 11:26 PM |
