08-09-2012, 10:09 AM | #81 |
Pebble Pounder Join Date: Apr 2010 Location: Norway
| Re: Jyri's Wraith
Wow! This rig looks better and better!
08-14-2012, 01:38 PM | #82 |
Rock Stacker Join Date: Jun 2012 Location: Finland
| Re: Jyri's Wraith Thanks! The hood mod wasn't that difficult to do, actually it was rather easy, once I decided to use the extra piece from roof light bar and neodym magnets. Super easy to use no tools needed, no parts to loose. The Driver needed some dremel as did the seat, I must have taken out at least 15mm from the back of sam, but now he fits the seat ok. 20120814-164257-Wraith Tuning by Jyri Laitinen, on Flickr 20120814-164309-Wraith Tuning by Jyri Laitinen, on Flickr 20120814-164318-Wraith Tuning by Jyri Laitinen, on Flickr 20120814-164325-Wraith Tuning by Jyri Laitinen, on Flickr 20120814-164333-Wraith Tuning by Jyri Laitinen, on Flickr Got the spare parts for the Savöx, the CA fix didn't hold too long. 20120814-164420-Wraith Tuning by Jyri Laitinen, on Flickr 20120814-164819-Wraith Tuning by Jyri Laitinen, on Flickr 20120814-211225-Wraith Tuning by Jyri Laitinen, on Flickr 20120814-211241-Wraith Tuning by Jyri Laitinen, on Flickr 20120814-212143-Wraith Tuning by Jyri Laitinen, on Flickr 20120814-214341-Wraith Tuning by Jyri Laitinen, on Flickr |
08-15-2012, 03:37 PM | #83 |
| Re: Jyri's Wraith
Finally got the driver seated and seat installed. Had to lengthen the steering wheel post by 18 mm turned out quite nice. 20120815-160318-Wraith by Jyri Laitinen, on Flickr 20120815-160842-Wraith by Jyri Laitinen, on Flickr 20120815-160852-Wraith by Jyri Laitinen, on Flickr 20120815-223843-Wraith by Jyri Laitinen, on Flickr 20120815-224506-Wraith by Jyri Laitinen, on Flickr |
08-18-2012, 01:32 PM | #84 |
| Re: Jyri's Wraith
Damn, had slight bump to front wheel and servo is gone, took it apart, few wheels were ripped, but even when I replaced those, it is still gone, feels really hard to turn it by hand, and not working with receiver. Time to get new servo... ...I guess I'm done using Savöx servos, at least without servo saver that is, any suggestions for the servo or to use servo saver and if so which one??? |
08-19-2012, 06:26 AM | #85 |
Quarry Creeper Join Date: May 2012 Location: Italy
Hi Jyri I was also thinking at a servo saver and had this in mind but did not try it actually.... Sent from my iPad using Tapatalk |
08-19-2012, 09:25 AM | #86 |
| Re: Jyri's Wraith I was thingking tjat as well, already when I ordered my last set from Junfac, but it has beel sold out all the time, any idea where get one?
08-20-2012, 08:37 AM | #87 |
| Re: Jyri's Wraith
Sorry Jyri, first I live in Italy.... second I am also looking around in order to find a place to buy it... but was not successful so far... should I have any news I will post you.. ;( |
08-20-2012, 10:31 AM | #88 | |
| Re: Jyri's Wraith Quote:
08-20-2012, 10:57 AM | #89 |
Quarry Creeper Join Date: Aug 2009 Location: Brooklyn, New York
| Re: Jyri's Wraith
Very nice build. I was wondering how the EXO lights would look on the Wraith. Love the vids as well.
08-21-2012, 03:56 AM | #90 | ||
OK, PLS let me know if you find those somewhere available. | ||
08-21-2012, 08:47 AM | #91 |
Newbie Join Date: Jun 2012 Location: Salem, WV
| Re: Jyri's Wraith
Jyri Where did u get the resevoir shocks for your wraith ? They look sweet ! Also did your aluminum panels come in that color or did u paint them yourself ? Thanks Scott |
08-21-2012, 08:56 AM | #92 |
| Re: Jyri's Wraith
The panels he got of Ebay in the UK. I found them in the us Ebay as well cause that seller ships to the usa.
08-21-2012, 11:30 AM | #93 | |
Shocks are Gmade from junfac.com. The aluminium panels came as natural, all I have done is some sanding with 400 waterpaper (w/o water). | |
08-22-2012, 05:42 AM | #94 | |
Aluminum Axial Wraith Body Panel Kit (Cut Rate Shipping on International Orders) | eBay | |
08-22-2012, 05:45 AM | #95 | |
08-22-2012, 06:24 AM | #96 |
Yup, totally right! Indeed I like yours much more 'cos of that little feature of the bent fenders....
08-22-2012, 07:16 AM | #97 |
Pebble Pounder Join Date: Feb 2012 Location: Freakville
| Re: Jyri's Wraith
GREAT Build!!! Jyri would you be able to explain your wiring on your LED Lightbar? What power subbly are you ising? Which resisters did you use? I appreciate your help! Thanks |
08-22-2012, 07:28 AM | #98 | |
If I only could remember. I used online calculator for parallel LED wiring and tested the setup with current meter. So google for LED parallel wiring and give it the voltage, LED specs + amount, check how much power they will consume and choose the resistors accordingly. I am running mine from MMP ESC at 7V, my servos and receiver are run from CC ESC at 8V. Hope this helps. | |
08-22-2012, 08:45 AM | #99 |
| Re: Jyri's Wraith
Ive been using this wizard to determine the wiring in either Series or Parallel. LED series parallel array wizard Looking at your pictures the install is so clean and didnt see where you placed the resistors. Knowing your power supply helps me with what source to use now. I just need to figure out how you got your install so clean. Thanks for your help!! |
08-22-2012, 09:34 AM | #100 | |
