Thread: W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM
Old 07-13-2012, 07:24 AM   #21
Metal shaper
Thanks everyone for the positive feedback, it's what keeps a build like this going and the money spending. Hahaha
Got the shocks ordered this morning and fixing to box up the rear axle to get sent off for some tiny Tig welding.
Dang rear axle link mounts are 2" wider apart than a stock housing and the offset diff will make for an interesting problem for link placement. Not looking forward to that part.
Carter Fab & Machine: Hand Made Customs
CarterFab is offline   Reply With Quote
Old 07-14-2012, 12:16 AM   #22
Default Re: W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM
As mentioned before, work of art, can be wrapped in glass and stared at all day.
Modbug is offline   Reply With Quote
Old 07-16-2012, 10:42 AM   #23
Metal shaper
Well the axle housing is sent off to be Tig welded. I also made a blueprint of the shafts and sent it off to have some titanium shafts cut for the rear as well. Just didn't feel comfortable using a lesser grade material on an axle shaft that is 7.4375 long, plus I get to have two more Vendors of the site included on this build.
Thanks to Bill @ BGR Fab and Bob @ CBRB
Clay
Old 07-16-2012, 04:22 PM   #24
Metal shaper
Scale bolts, yea please!!
Will be changing everything that can over to the new style.
Clear Eyes, Full Hearts, Can't Lose
Old 07-16-2012, 06:10 PM   #25
Very fine craftsmanship man keep it up. This makes my custom axles look stupid!!
darkmanx is offline   Reply With Quote
Old 07-17-2012, 02:13 PM   #26
Metal shaper
New engine arrived. Functional butterflies and braided fuel line.
Can anyone electronic savy tell me if I can wire a servo inline with the throttle to make the butterflies function while driving?
Old 07-17-2012, 02:39 PM   #27
Didn't want to hijack your thread. I bought two sets of the LockedUp proto hubs and painted them up this weekend. Used Model Masters Brass #1782 to give them the Warn Premium Hub look.
spankbomb is offline   Reply With Quote
Old 07-17-2012, 08:21 PM   #28
Metal shaper
Very nice detail on the hubs
Old 07-18-2012, 12:35 AM   #29
Thumbs up Re: W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM
I don't see why not. It shouldn't hurt any thing, the speed control may not get the full voltage it needs though. I'm not sure if you could use a CC BEC for it if it takes away to much power from the esc. Also if you use a multi channel radio with mixing and a multiple outputs on your receiver would work also.
ngward79 is offline   Reply With Quote
Old 07-18-2012, 07:19 AM   #30
Fan of wheelspeed
I know that with the Novak escs they have a deal for lights on there. They are supposed to brighten and dim as you drive. I wonder if this type of power would be enough to operate a micro servo? The only downside would be that you had a Novak esc though, so the benefit probably wouldnt outweigh the negative.
Hoosierdady is offline   Reply With Quote
Old 07-18-2012, 08:31 AM   #31
Clay, thank you for the compliment. The detail on your axles is amazing. It is great seeing the products being put out by Texas vendors such as yourself, TSS and Locked Up.
Later,
Jon D.
Old 07-18-2012, 10:43 AM   #32
Metal shaper
Well how's about this for some scale axle detail porn. Might have to put a poll up on which axles should finally go under this rig. This is the rear BlackRock 60 housing complete minus link mounts.
Old 07-18-2012, 01:47 PM   #33
~THE SCALE SHOP~
looking forward to link mounts.
STANG KILLA SS is offline   Reply With Quote
Old 07-18-2012, 02:10 PM   #34
PapaGriz Yo
Grizzly4x4's Avatar
Easy. All you need is a Y servo cable. Connect one end to the RX, one of the Y leads to the ESC, and the other Y lead to the "throttle" servo. The servo will move according to how much throttle input you give.
Microgoat used this technique to make a working tachometer.
Ryan's Scout Comanche: Goat's BigBaller Buildoff Entry
Grizzly4x4 is offline   Reply With Quote
Old 07-18-2012, 02:25 PM   #35
Metal shaper
So this plug I have should work? It has a male end on one and the other has a dual female socket. Just plug male in to RX where the esc was and then the esc and servo into the other? Or have to be the y harness you listed?
Old 07-18-2012, 02:50 PM   #36
PapaGriz Yo
Grizzly4x4's Avatar
That cable should work. It looks like it is the same idea as a Y cable.
You could just test it with 2 servos and make sure they turn together.
Old 07-18-2012, 02:52 PM   #37
Metal shaper
Good deal. I pulled it off an old TLT that was running dual servos through this. I guess now the only concern is voltage?
Old 07-18-2012, 03:04 PM   #38
PapaGriz Yo
Grizzly4x4's Avatar
If it was running dual servos then it should work perfect for you.
How many volts do you run to your RX to run the speed control? Even most micro servos are rated for 6.0V.
Old 07-18-2012, 03:14 PM   #39
Metal shaper
I believe it's probably 6v. Eddie(novasark) usually sets all my electronics up for me, it's the last piece of the puzzle I still haven't gotten really comfortable with. Electronics that is. I really need to learn that end of the spectrum better.
Thanks for the help thus far
Old 07-18-2012, 03:25 PM   #40
PapaGriz Yo
Grizzly4x4's Avatar
It's not that bad once you have done it a few times.
I hope to see it working when I get back from the lake.
W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM - Similar Threads
"Southern Comfort" by CFM CarterFab Axial Wraith 687 08-13-2014 06:28 AM
"riddler" southern buggy build ROLANDROCKSHOP Axial Wraith 147 10-25-2013 01:54 PM
RECON G6 Challenge "The Superlift Southern Showdown G6" & "Outlaw Terra-X" DRIVNMF Recon G6 227 10-19-2012 10:26 AM
mg200 southern buggy build "HEADCASE" ROLANDROCKSHOP Axial Wraith 187 03-04-2012 06:35 PM
