Thread: W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM
Old 07-18-2012, 03:38 PM   #41
Metal shaper
Originally Posted by Grizzly4x4 View Post
It's not that bad once you have done it a few times.
I hope to see it working when I get back from the lake.
Gonna be there for a while? Haha
I need to get the stuff to be able to program servos and esc's now that there is a pc in the house(Mac snob) courtesy of my new bride. I haven't used a windows based system in forever so I'll have to relearn that garbage of a system.
Carter Fab & Machine: Hand Made Customs
CarterFab is offline   Reply With Quote
Old 07-18-2012, 05:47 PM   #42
PapaGriz Yo
Grizzly4x4's Avatar
Default Re: W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM
Nice!
Grizzly4x4 is offline   Reply With Quote
Old 07-18-2012, 06:42 PM   #43
Metal shaper
Chassis is done! Ty did another great job.
Old 07-18-2012, 11:32 PM   #44
Wow, the chassis turned out killer. So which axle is it going to be?
Bulldog is offline   Reply With Quote
Old 07-19-2012, 06:27 AM   #45
Metal shaper
Good question. The ultimate 9 is all welded up and will be heading home soon. I got 3 different styles of very scale axles to use, I'm just gonna wait till I get everything in front of me and see what fits. Axles will probably be the very last item.
Old 07-19-2012, 01:35 PM   #46
Very nice platform!
Desert Rc is offline   Reply With Quote
Old 07-19-2012, 04:44 PM   #47
Metal shaper
Shocks showed up. Love these! Feel really nice. Extreme detail. SCX-10 springs fit perfect. Much larger bodies than original dual spring design, should be good for the bigger rigs.
Old 07-19-2012, 09:26 PM   #48
Those shocks are sick let us know how they work. Rigs looking good so far
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
adamargue is offline   Reply With Quote
Old 07-19-2012, 11:47 PM   #49
Where didyou find the shocks
89lxmorepower is offline   Reply With Quote
Old 07-20-2012, 12:25 AM   #50
" SCX-10 springs fit perfect"...What part of the springs will fit on the king shocks? I'm confused. Please post up
Old 07-20-2012, 01:09 AM   #51
X2 on were you got the shocks from. They would go perfect on my zone off-road project mj build.
matt_22 is offline   Reply With Quote
Old 07-20-2012, 01:24 AM   #52
RC4wd has them.....
https://store.rc4wd.com/mobile/home.asp?#page-68
ScaleReady is offline   Reply With Quote
Old 07-20-2012, 06:16 AM   #53
Metal shaper
Yes, rc4wd is the place. The cool springs can replace the blue springs these come with. That way you can tune them better.
Clear Eyes, Full Hearts, Can't Lose
Old 07-20-2012, 08:39 AM   #54
Metal shaper
The option to run them remote reservoir or as an emulsion shock. More detail to come
Old 07-20-2012, 08:44 AM   #55
So do these shocks use oil? Is there room to internally spring them?
BTW, I absolutely love this build and your axles. I really wish I had the capability to build what I want like you......someday.
Can't wait to see this rig finished, keep up all the custom machined stuff, it turns me on .
War Pig is offline   Reply With Quote
Old 07-20-2012, 09:06 AM   #56
Metal shaper
The machine work and axles are all I can do to separate me from you guys putting so much detail in your rigs. I just have to tell my self to slow down and take the time, I get to impatient when I have a bunch of parts in front of me and have always just put a rig together so I can start having fun. The machine work on this is keeping me plenty occupied though.
On to the shocks.
Yes they hold oil.
Shock body OD is .393" or 10mm
Each coil is 1.600" or 40.5mm
The shafts are .138" or 3.5mm
Shock body ID is .298 or 7.5mm (this would be the max diameter of an internal spring)
Length of bore w/shaft extended is 1.625 or 41mm (max length of an internal spring)
Hope that helps
Clay
Old 07-20-2012, 10:11 AM   #57
I know they may be a little on the big side, but maybe run the reservoirs that you removed, as air bumps? Just a thought
Old 07-20-2012, 10:23 AM   #58
Metal shaper
Yeah these are a bit big in every dimension. If I start turning them down, I will loose all the lettering. I will be machining my own that will be scale to size and "functional".
Old 07-20-2012, 10:28 AM   #59
Yeah, I thought so....
I am very surprised that nobody offers anything like that yet. Wish I had the machines capable of turning out some cool "airbumps" Just put a small internal spring in there or a piece of soft rubber. hmm...
Old 07-20-2012, 10:49 AM   #60
Metal shaper
I think the reason being is that there is not really a format where they just bolt up like shocks or wheels. Only way to make them scale is to have the cans welded on and most people just aren't up for that.
I was thinking a pin spring inside to make it return to extension.
W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM - Similar Threads
"Southern Comfort" by CFM CarterFab Axial Wraith 687 08-13-2014 06:28 AM
"riddler" southern buggy build ROLANDROCKSHOP Axial Wraith 147 10-25-2013 01:54 PM
RECON G6 Challenge "The Superlift Southern Showdown G6" & "Outlaw Terra-X" DRIVNMF Recon G6 227 10-19-2012 10:26 AM
mg200 southern buggy build "HEADCASE" ROLANDROCKSHOP Axial Wraith 187 03-04-2012 06:35 PM
