07-20-2012, 04:58 PM | #61 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
Got the remote reservoirs done. Clear Eyes, Full Hearts, Can't Lose |
07-20-2012, 05:05 PM | #62 |
RCC Addict Join Date: Mar 2010 Location: Yelm
| Re: W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM |
07-20-2012, 05:24 PM | #63 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
07-20-2012, 06:42 PM | #64 | |
You can't be scared all your life! Hahaha Let me know Carter Fab & Machine: Hand Made Customs | |
07-20-2012, 07:19 PM | #65 |
Looking for new Trails Join Date: Dec 2008 Location: GPS locating signal.....
I love the new King shocks they look great, chassis looks awesome can't wait to see it rolling...
07-20-2012, 09:55 PM | #66 |
Rock Crawler Join Date: Sep 2011 Location: Sandusky, Ohio
Where did you get the brass fittings for the rubber hose? And what size is it?
07-20-2012, 10:08 PM | #67 | |
The "brass fitting" is actually a 2mm screw bolted into the cap. Ran a brass nut down on it. Cut the head of the screw off. The "rubber hose" is actually a piece of silver solder wire wrapped with heat shrink used on wiring. I drilled and tapped the reservoir, installed a 2mm screw, then sleeved a piece of solder that would leave enough on each end to be glued on to the screws of the cap and reservoir. Let dry. Heat the heat shrink and TA-DA!! Just crap I had laying around that looked the part when assembled. Chose the "rubber hose" method over normal electrical wire due to the fact that I can shape it and it will hold. Used a 2mm scale hex bolt for the schrader valve on the reservoir. Clear Eyes, Full Hearts, Can't Lose | |
07-21-2012, 12:09 AM | #68 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
Looks awesome
07-21-2012, 12:22 AM | #69 | |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| Re: W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM Quote:
I actually made them so they are adjustable up and down. Works really well. | |
07-21-2012, 02:07 AM | #70 |
Quarry Creeper Join Date: Oct 2010 Location: roswell
Wow on the bump stops! How much! Lol
07-21-2012, 03:44 AM | #71 |
Rock Crawler Join Date: Jan 2007 Location: UK
07-21-2012, 08:02 AM | #72 |
I was wondering when Tum was gonna say something. Im pretty sure both him and I were the first with Functional Bump Stops. But his were made right. Ohh and correction on the size. I need 90mm's With remotes. Last edited by team3six; 07-21-2012 at 08:04 AM. |
07-21-2012, 01:52 PM | #73 |
Yeah Tim, thats along the lines I was thinking. Gonna have to add some Teflon bumpers to mine though, can't be having metal on metal. Did you just weld the caps on once together?
07-23-2012, 06:42 PM | #74 |
Updated the front axle with some beef Carter Fab & Machine: Hand Made Customs |
07-25-2012, 09:47 PM | #75 |
Chassis is home at last. Bolted up the Titan 60 axles just to get an idea. Gonna make a few tweaks and figure out how to get the rear Ultimate 9 axle in there. Would like to run scale links but these rod ends are pretty sloppy. Any suggestions? Might have to be happy with just scale hardware. Got the "?" brand hubs modified the same way as LockedUp RC makes there's. Bored out the back side enough so that a normal lock nut still holds the actual wheel, then these screw down with the remaining threads from the shaft. Man I got a lot of work to do and wife has me busy doing other stuff till next week. GAH!!! Clay Carter Fab & Machine: Hand Made Customs |
07-25-2012, 10:20 PM | #76 |
Rock Stacker Join Date: Feb 2006 Location: Williamstown
I must say that this rig looks spectacular.. fighting the urge to break out the credit card for one lol. great job.
07-25-2012, 11:37 PM | #77 |
This thread gives me wood.......... |
07-25-2012, 11:51 PM | #78 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
The heims I have on one of my trucks are nice and tight. Side to side sitting in the link mounts, I shimmed with small conical washers though. Yours look different than mine. The chassis looks sick! |
07-26-2012, 12:30 AM | #79 |
RCC Addict Join Date: Nov 2006 Location: burlington
07-26-2012, 08:12 AM | #80 |
Rock Crawler Join Date: Oct 2009 Location: 6512 Elevation
Man CRAWLER PORN can't turn away!
W.O.D. inspired family 4 seater buggy, "Southern Comfort" by CFM - Similar Threads | ||||
"Southern Comfort" by CFM | CarterFab | Axial Wraith | 687 | 08-13-2014 06:28 AM |
"riddler" southern buggy build | ROLANDROCKSHOP | Axial Wraith | 147 | 10-25-2013 01:54 PM |
RECON G6 Challenge "The Superlift Southern Showdown G6" & "Outlaw Terra-X" | DRIVNMF | Recon G6 | 227 | 10-19-2012 10:26 AM |
mg200 southern buggy build "HEADCASE" | ROLANDROCKSHOP | Axial Wraith | 187 | 03-04-2012 06:35 PM |
