07-20-2012, 05:39 PM | #41 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| Re: Szczerb'a Wraith Build, of sorts |
07-20-2012, 06:10 PM | #42 | |
Rock Crawler Join Date: Jul 2011 Location: north little rock
| Re: Szczerb'a Wraith Build, of sorts Quote:
07-20-2012, 06:12 PM | #43 |
| Re: Szczerb'a Wraith Build, of sorts Now ya' tell me. Didn't even cross my mind. It will be covered up anyways. Possibility. Decided on "Daytona Yellow" but it won't be here for 7 days. Good ol' air shipping ban on aerosols. |
07-20-2012, 06:21 PM | #44 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
I got tons of led's. Let me know what you need. They are just the led but I have red, orange, blue, white, and green. Bought them in bulk when I did my Ultra 4 light bar setup. Carter Fab & Machine: Hand Made Customs |
07-20-2012, 06:22 PM | #45 |
Oh yeah, when you join those tubes with the sleeved rod, another way to keep it together and make it removable is to drill each side and put set screws looking down on the rod. Or for added security. Carter Fab & Machine: Hand Made Customs |
07-21-2012, 09:24 PM | #46 | |
Quickly painted the body and threw it on the truck. Not mounted yet. Detailed out the radiator and added a couple washers to the fans to dress em up a bit. Not sure I a like it or not. Still need to add some detail to it here and there. I know the WB of the body is kinda short for this setup but oh well. Tips, comments or suggestions? Last edited by Szczerba; 07-21-2012 at 09:28 PM. | |
07-22-2012, 08:45 AM | #47 |
I didn't mean use a set screw in place of the rod, just drill the OD of the chassis bars and then put a small set screw in that tightens down on the rod. Like the way it's done on a driveshaft attaching to diff gear. Clear Eyes, Full Hearts, Can't Lose |
07-22-2012, 09:04 AM | #48 |
| Re: Szczerb'a Wraith Build, of sorts Ahhh. I'm pickin' up what your puttin' down. I put epoxy in the chassis holes I drilled out with a 1/8" drill bit and then on the joints before I pushed them together. I think it will hold.
07-22-2012, 09:12 AM | #49 |
Split the roof and then taper the doors in to march the cage. Might look cool. Only thin I don't like about "bodies" on these chassis is the front end is so pushed out. Clear Eyes, Full Hearts, Can't Lose |
07-22-2012, 09:16 AM | #50 | |
I think, once I actually screw the body to the side of the chassis to mount it, it should pull the sides in just enough. | |
07-22-2012, 09:36 AM | #51 |
The yellow and white came out really nice. The white stripe is the perfect accent. As for the front fender, I think if you squared the front out more it will take away from the off wheel base. If the front edge isn't radiused then there is no real reference for it being disporpornate. With that being said I think it looks kick ASS just like it sits. |
07-22-2012, 08:30 PM | #52 | |
.................................................. .................................................. ............................... I ordered up about $50 in panels from CarterFab. Wraith body panels . Rear chassis floor, boat sides, front inner fenders and some custom inner fender guards. On another note. I hooked up a Holmes Hobbies TorqueMaster BR-XL , Old P2K Copperhead I had sitting around and a 3S lipo and took it for a spin around the yard. This truck is a blast to drive. It handles great. Almost zero chassis roll and when you gun it, the front rises a little and the rear swats. I ran it on a 14tooth pinion. Motor isn't the best for slow crawling, especially with no front end weight but it gets by. Truck is ~ 6lbs 10oz right now. ... Last edited by Szczerba; 07-22-2012 at 08:33 PM. | |
07-22-2012, 09:03 PM | #53 | |
Clay Carter Fab & Machine | |
07-25-2012, 10:19 PM | #54 |
Got in the panels from Carter Fab & Machine - Home Front inner panels, cut down side/inner 1/4 panels, boatsides and a rear floor. All the panels were a direct fit, minus the inner panels under the hood area due to the exo front graft. And I'll have to drill some holes in the rear floor to accommodate my rear exo graft. I really like the look of the inner 1/4 panels. I asked Clay to shorten up his normal side panels because I didn't want a full side panel. Got exactly what I asked for. Good inner chassis protection and looks good too. Been test driving the truck with a 27turn on 3S with a Holmes Hobbies BR-XL. Hence the swashed down light bar. It handles really good. I was surprised. More parts soon... Last edited by Szczerba; 07-25-2012 at 10:25 PM. |
07-25-2012, 10:23 PM | #55 |
27t on 3s is about my favorite speed of brushed motor in the Wraith(ish) rigs. Any faster and they start eating brushes like crazy and becoming more space heater than motor, any slower and it isn't much of a rock racer.
07-25-2012, 10:30 PM | #56 | |
I was able to release a bit of magic smoke from it on the rocks a couple times. I have been running it really hard just to see how long it will make it. New motor and ESC on the "to buy" list. I'm thinking Pro4 with MMP for fast setup. I really liked the 35 turn geared down a bit for crawling, with the BR-XL. That will probably be my "crawling" electronics setup but I don't see this rig crawling too much. It's way too much to drive fast. | |
07-25-2012, 10:49 PM | #57 |
That motor is fixed timing, yeah? Way too much advance at low speed, I don't doubt you let some smoke out! Pro4's are awesome, you would be very happy with the combo. |
08-12-2012, 09:20 PM | #58 | |
Awesome picture of parts in their packages. I've been on vacation 1.5 weeks and pretty busy getting ready for vacation. Some parts were waiting for me when I got home. Got (not pictured) LED's from RolandRockshop, 19 total. Mamba Max Pro and Tekin Pro 4 3300kv brushless motor. From www.holmeshobbies.com Supershafty AX10 Top Shaft from AXAIL BOMB PROOF MODS BilletWorksDesigns AX10 Motor Plate. FOFF Motor Plate More parts on the way. | |
08-12-2012, 09:57 PM | #59 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
To keep the light bar from pushing down when you rollover I put a couple little 2.5mm screws through the lower clamp into the "A" pillar. Rig looks nice!! |
08-12-2012, 11:01 PM | #60 |
Pebble Pounder Join Date: Aug 2012 Location: repentigny qc
how do u like ur combo im looking to get the same ? do u have a gd hi speed whit it for bashing ? and is it gd in mud/crawling thx im new into the wraith world lol |
Szczerb'a Wraith Build, of sorts - Similar Threads | ||||
My wraith build so far | wraith89 | Newbie General | 3 | 02-02-2012 09:44 AM |
all sorts of problems :( | DapperDan | Newbie General | 9 | 06-19-2009 03:15 PM |
.PDF or Blueprints or some sorts of measurements please | Kingofthehill | 2.2 Scale Rigs | 6 | 02-19-2007 12:00 AM |
trials rig of sorts.... | sparko | General Crawlers | 24 | 12-07-2005 09:10 AM |
