08-12-2012, 11:26 PM | #61 | |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| Re: Szczerb'a Wraith Build, of sorts Quote:
The O-rings go in the drive cup, where the dogbone of the axle shaft goes. That keeps the drive cup pushed into the locker. If I remember right, I ran O-rings in both cups (at the diff and at the wheel axle) to keep the front dogbones in place. Of course I never ran it, but it worked well while building. | |
08-13-2012, 08:23 AM | #62 | |||
08-16-2012, 12:00 PM | #63 |
Rock Stacker Join Date: Aug 2011 Location: Calexico
Have you thought of putting the rear shocks on the links??
08-17-2012, 08:59 AM | #64 |
| i was going to try the rear RC4WD trailing arms cause i used them on my 4x4 trophy truck build but for ease of getting this running soon i didnt. they would need modification. teardown for upgrades. |
08-17-2012, 08:41 PM | #65 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
nice tranny... |
08-17-2012, 08:49 PM | #66 |
| Re: Szczerb'a Wraith Build, of sorts |
08-17-2012, 11:56 PM | #67 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Just heads up.. The servo to steering rack turnbuckle will pull apart when you beat on it. I used a piece of 8/32 all thread and revo rod ends to fix the issue. |
08-18-2012, 08:07 AM | #68 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
Mega awesome build! Siskel and Ebert give it two fingers up JK I've been wanting to use that for a minute. Really though I like the way you have done this from the centered custom rear 60 to all the strc goodies up front and the incorporation of both chassis's! Super cool that pro 4 will be squealing all 4 tires every time you shift gears wow |
08-18-2012, 12:08 PM | #69 | ||
08-21-2012, 08:02 PM | #70 |
Got in the remaining parts today and wired up the electronics to go for a test run. Whew! Tekin Pro4 Power! (even on a old EFlite 3S) Cut a 5mm shim "disc" to take the play out of the top shaft in the trans. This trans is solid, thanks to Crawler Innovations for the 5mm outputs, BWD for the motor plate and supershafty.com for the metal spur and top shaft. |
08-21-2012, 08:37 PM | #71 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
Sure is a cute transmission, my step daughter would love it. Haha Carter Fab & Machine: Hand Made Customs |
08-21-2012, 08:58 PM | #72 |
08-22-2012, 12:27 PM | #73 |
Rock Crawler Join Date: Nov 2010 Location: roanoke
that is bada$$!
08-26-2012, 09:13 PM | #74 |
| Re: Szczerb'a Wraith Build, of sorts Thanks, that is what I say when i hammer down with that Pro4! I knew the cheap aluminum locker (i know, I know) wouldn't last long up front in the Exo case. Lasted about 10 minutes. O-rings shimming the dog bones in to hold the drive cups is working just fine. New locker upgrade will be next. Couple pictures. Uploading some short videos. 3 wheel drive. Added JeepInDoug spring retainers to the springs. |
08-28-2012, 11:47 PM | #75 |
Quarry Creeper Join Date: Oct 2011 Location: Livermore Ca.
This rig is bad! I like the black alum from CFM! What size rear shock are you running?
08-29-2012, 01:24 AM | #76 |
Lookin' good. I might have to get some of those CFM panels for mine. Would help keep crap out of the electronics.
08-29-2012, 06:30 AM | #77 | |
Mud digger has them on his Crawlmaro also. And just sent out several mor sets that will be popping up soon. Lookin good Shane. Carter Fab & Machine: Hand Made Customs | |
08-29-2012, 07:11 AM | #78 | |
RCP*Crawlers*Stainless... $17 each. Stainless steel so you add weight low in the rig. Each locker weighs 1.8oz (49g) compared to the stock locker/diff housing that weighs .6oz (17g). Replaces the locker and diff case. Ring gear bolts directly to the locker. These are what I'm using in mine. | |
08-29-2012, 09:41 AM | #79 |
Newbie Join Date: Mar 2012 Location: Whittier
Awesome man!!
08-30-2012, 09:26 PM | #80 | ||||
This truck is meant to run a body so I was just wanting front inner protection. Installed the rear CFM panel tonight. Quote:
I bought the HR locker to replace this front. And ordered another RCP steel locker for backup. I was going to have a buddy weld the RCP locker to the drivecup outputs but the bearing prohibited that on the diff gear side. Thanks. Quickly wired up some LED lights. I ran out of light buckets to no rear taillights, no rock lights and no "headlights" for now. Just running them into the Rx right now. | ||||
Szczerb'a Wraith Build, of sorts - Similar Threads | ||||
My wraith build so far | wraith89 | Newbie General | 3 | 02-02-2012 09:44 AM |
all sorts of problems :( | DapperDan | Newbie General | 9 | 06-19-2009 03:15 PM |
.PDF or Blueprints or some sorts of measurements please | Kingofthehill | 2.2 Scale Rigs | 6 | 02-19-2007 12:00 AM |
trials rig of sorts.... | sparko | General Crawlers | 24 | 12-07-2005 09:10 AM |
