09-14-2012, 06:52 PM | #101 | |
Quarry Creeper Join Date: Apr 2012 Location: Talladega, AL
Sent from my DROID RAZR using Tapatalk 2 | |
09-25-2012, 08:03 PM | #102 |
| Re: Szczerb'a Wraith Build, of sorts
Got the new gears in it last week and all I can say is wow. Fast, smooth and jumps pretty good also. I almost have everything for rear steer just need to get one more long side wraith universal and a servo mount. I probably will only use it while crawling around the house and maybe in the trails when out in the 1:1 or rzr while waiting for someone to fix something. Hopefully a 7954 or 7955 will keep the rear straight when going fast. If not I guess I'll have to buy another 7950 or something. Or make lock out links and disconnect the servo linkage when not using the rear steer, we have done that on 1:1 stuff when a comp doesn't allow rear steer and it has worked extremely well. I'll put up a short video from behind my office where our pool was.
09-25-2012, 08:08 PM | #103 |
Short video. Throttle is set at 60% until I can control it a little better. YouTube - Messing around with my Exo wraith |
10-30-2012, 12:12 AM | #104 |
Rock Crawler Join Date: Nov 2008 Location: missoula
I just bought this from irock and the front gears are bad anyone have any recommendations on what i can do to keep this from. Happerning
10-30-2012, 03:09 AM | #105 |
I run a mamba monster 2200 on. 4s in my exo no problems with front or rear or center gears runs like a scalded cat
10-30-2012, 10:07 AM | #106 | ||
| Re: Szczerb'a Wraith Build, of sorts Quote:
I think the 4S and the combined weight of this rig might be the issue. When I had it, 3S was almost too much and I had to be easy on the throttle or stuff would break I am sure. | ||
10-30-2012, 10:20 AM | #107 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
It has new machined HD gears in the rear.
10-30-2012, 11:09 AM | #108 |
| Re: Szczerb'a Wraith Build, of sorts do you think a set of heavy duty exo gears will fix it? do you remember the gear rartio of the rear guys?
10-30-2012, 11:22 AM | #109 |
| Re: Szczerb'a Wraith Build, of sorts |
10-30-2012, 11:32 AM | #110 |
10-30-2012, 11:36 AM | #111 |
| Re: Szczerb'a Wraith Build, of sorts "Stock" ratio. Should be back a few pages in the build but I might have failed to list it. I didnt want to run different ratios and only had one good set of HD gears and those went the front. The rear was a non-HD metal gear turned down by CarterFab but didn't last long. irokcrawl replaced the rear gears with HD turned down by CarterFab |
10-30-2012, 11:43 AM | #112 |
ive read threw a few times but get distracted looking at it awesome build!!!
10-30-2012, 11:57 AM | #113 |
turning down the rear gears was the spur just to big for housing?
10-30-2012, 12:00 PM | #114 |
The housing itself is shaved for clearance. You have to trim down the od to clear the belly of the axle case.
10-30-2012, 12:13 PM | #115 |
thanks carter just getting some info so i know.
10-30-2012, 12:33 PM | #116 |
10-30-2012, 01:37 PM | #117 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
FWIW, I have found that the exo plastic gear cases have alot of flex. I added some preload to the ring gear with some 10mm shims behind the gear bearing to tighten up the mesh.
10-30-2012, 03:52 PM | #118 |
sounds good and thanks guys i appreciate the help!
11-20-2012, 11:32 AM | #119 |
Newbie Join Date: Nov 2012 Location: Madison, AL
I was eyeing this thing on Pirate4x4. It's the first thing that comes up when you Google "IFS Wraith" Custom IFS Wraith with lots of upgrades F/S - Pirate4x4.Com : 4x4 and Off-Road Forum |
11-20-2012, 11:35 AM | #120 | |
Sent from my DROID RAZR HD using Tapatalk 2 | |
Szczerb'a Wraith Build, of sorts - Similar Threads | ||||
My wraith build so far | wraith89 | Newbie General | 3 | 02-02-2012 09:44 AM |
all sorts of problems :( | DapperDan | Newbie General | 9 | 06-19-2009 03:15 PM |
.PDF or Blueprints or some sorts of measurements please | Kingofthehill | 2.2 Scale Rigs | 6 | 02-19-2007 12:00 AM |
trials rig of sorts.... | sparko | General Crawlers | 24 | 12-07-2005 09:10 AM |
