01-06-2013, 10:19 PM | #161 |
Rock Crawler Join Date: Nov 2008 Location: missoula
| Re: Szczerb'a Wraith Build, of sorts
They are cool handle very good
01-07-2013, 08:49 AM | #162 |
Quarry Creeper Join Date: Apr 2008 Location: SHADYSIDE
MTGRIZZLYMN, hows the front diff holding up running the 100000 wt diff oil? does it crawl okay? I went with the hr hd diff locker in mine with 2 orings per cup so far okay, but not so good on turning going slow, thinking the 100000 diff oil would help with turning an still have traction when crawling.
01-07-2013, 12:47 PM | #163 |
Yes it's holding up great! The fluid when I change it I'm going to try even a little heavier but it turns great and on our hills with rocks that aren't under snow it uses both tires climbing I was thinking a little heavier just to try it but for methis is the way to go, it will hold up to insane power if I want. You won't be disappointed if your setup fails and u try this. I put that gcm piece for the gears in and it's a quality piece of aluminum to keep any flex out of that area.
01-07-2013, 02:14 PM | #164 |
COOL thanks, making a shopping list for the exowraith, heavier diff oil is now on the list.
03-05-2013, 12:21 AM | #165 |
Guys ran this for prob 45 minutes today no breaking down just racing climbing doing doughnuts in the snow. This runs and drives great. I converted it back to the exo alum diff awhil back and put 100000 weight oil in I now am positive I can use 200000 at least. When it gets ran awhile when crawling u can make just one front spin if light on throttle hit it and all four are going but for drawing thicker ill be better, no breakdowns now I can just drive and enjoy.
03-05-2013, 05:04 PM | #166 |
How would I set up the rear shocks to have slower rebound when on rough stuff gets bouncy in rear a little for sure could be better?
03-07-2013, 12:22 AM | #167 |
No suspension guys?
03-07-2013, 07:45 AM | #168 |
Thicker shock fluid? Limit the shock travel a little? |
03-07-2013, 11:11 AM | #169 |
Szczerba was the fluid in rear 35 wt?
03-07-2013, 11:13 AM | #170 |
| Re: Szczerb'a Wraith Build, of sorts |
03-07-2013, 04:33 PM | #171 |
Will do. Thanks
04-08-2013, 10:31 PM | #172 |
Ttt
05-02-2013, 02:33 PM | #173 |
Just to let everyone know this rig is still running awesome! Very happy |
Szczerb'a Wraith Build, of sorts - Similar Threads | ||||
My wraith build so far | wraith89 | Newbie General | 3 | 02-02-2012 09:44 AM |
all sorts of problems :( | DapperDan | Newbie General | 9 | 06-19-2009 03:15 PM |
.PDF or Blueprints or some sorts of measurements please | Kingofthehill | 2.2 Scale Rigs | 6 | 02-19-2007 12:00 AM |
trials rig of sorts.... | sparko | General Crawlers | 24 | 12-07-2005 09:10 AM |
