07-18-2012, 08:33 PM | #21 | |
RCC Addict Join Date: Nov 2004 Location: union
| Re: Dlux Wraith Build Quote:
Gun drill - Wikipedia, the free encyclopedia You probably already know this but some people may not be familiar. Sorry to get so off topic. You really do some nice work and offer a lot to the crawling community. Keep up the good work! | |
07-23-2012, 09:25 PM | #22 |
I was easily talked into up grading my trans gears. I really am trying not to add weight to this car but ya gotta do what ya gotta do. Stock plastic idler gear 0g And then the super heavy for what it is, steel idler gear 5g. I couldnt see a way to reduce the weight on this. I am looking into aluminum idlers now... And then the final gear I replaced with aluminum. Stock plastic 3g Aluminum replacement was not too bad at 4g. I accidentally deleted the picture... Here is the milled out aluminum final gear. It comes in the same as a stock plastic, 3g |
07-23-2012, 09:34 PM | #23 |
I was lucky and got my driveshafts the night before our Ultra 4 comp. I was sweating using the stock shafts! I went for the Junfac shafts. I think the MIP may be better quality and be a bit more durable but they weigh a TON. I remember when I switched from the MIP to Junfac when I ran my Losi that I lost quite a bit of weight and its rotating weight none the less. I opted for the longest set that Junfac had (120mm-155mm) since I read on here that the ones that are intended for Wraiths did not have much engagement. I figured I could shorten the longer ones if needed. Come to find out, I think I would have been just fine with what they suggest. Here are some comparasion pics of the 120mm-155mm shafts against the stock long Wraith shafts. Fully compressed Fully extended |
07-23-2012, 09:36 PM | #24 |
Besides the weight, another huge advantage the Junfac shaft has over the MIP is the little clip that goes around the pin. Even if you took your retaining set screw out, the pin would stay in. I had to take these rings off a couple times and they were really stubborn. |
07-23-2012, 09:38 PM | #25 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Have you looked into CI's maxx shaft adapter? I would think those are much lighter plus you get beefed up front output. And they are cheap to boot. My full size rear weighs 25g. I never wayed the front output. Last edited by Erin; 07-23-2012 at 09:45 PM. |
07-23-2012, 09:38 PM | #26 |
I knew the Junfac shafts were smaller in diameter and I had read on here that people were able to use a 32p spur with 60t. I wanted to go with as big of a spur as I could so I was hoping that the shafts would fit a 62t spur. They did. I took a bit off the edge and beveled it so they would fit. I think that you could get away with not beveling it and just a TINY bit of self clearancing would happen. |
07-23-2012, 09:43 PM | #27 |
And of course I was going to all I could to lighten these up. Drilled, milled, shortened and the works. Stock Wraith shaft 28g Stock 120mm-150mm Junfac 47g Modified Junfac 43g, which I am not sure I believe. I took over .5 inches off the length and drilled the center and milled the ends. Whatever. I found an old picture of an MIP when I ran the losi. It was AX10 length so it should apply. 63g |
07-23-2012, 09:43 PM | #28 |
Is this the first light weight wraith project? Good work on the details!! I'm surprised you haven't hacked at the plastic cage yet. Its pretty low hanging fruit in terms of weight reduction, that sucker is heavy! |
07-23-2012, 09:45 PM | #29 |
Got the rear steer installed. This brings up the fun value in a serious way IMO. |
07-23-2012, 09:46 PM | #30 |
I got some spring cups from Crawler13. These things are my favorite! You can see them installed if you look really closely above. He also hooked me up with a sick D ring and snatch block. I cant believe he made these by hand! Awesome! |
07-23-2012, 09:48 PM | #31 |
Still waiting on knuckle weights so I decided to add my Dlux slugs to the wheels. Nice and easy and you get to reap the benefits of the open wheel and breathable foam. |
07-23-2012, 09:50 PM | #32 |
According to 801 Ultra 4 rules you cannot eliminate a stock item from the car. If the car comes with seats, you need to have seats. There was no way I could get myself to throw in those stock seats! I am pretty sure I weighed them in at 4oz each or HALF A POUND for both. Thats crazy talk. So, I went to the thrift store and found some ballin seats. I just happened to find a one eyed surfer guy too. What luck! I think I should have extra points for seat belts. |
07-23-2012, 09:53 PM | #33 |
How is the rear steer at speed? Any odd handling quirks? It seems people either love it or hate it. Also, any issues wiring the novak motor to mamba? That's what I 'm using as well. Last edited by Erin; 07-23-2012 at 10:03 PM. |
07-23-2012, 09:54 PM | #34 |
Thats pretty much all I have up to this point. I went to my first Ultra 4 comp on Saturday. There was a lot to learn and I was caught by surprise on how everything worked. Finishing the car at 2am the night before and having never driven rear steer on this car hurt me too. I cant wait for the next one though! Out of 26 competitors only 14 finished the race, including myself. I am pretty happy with just finishing while having a brand new build! Oh, I got 6th overall too. Here are a couple pics. Nothing too flashy, just the basics. |
07-23-2012, 10:09 PM | #35 | |
Think the Maxx shaft is as strong as metal? Do you have a weight on them? I am surprised at how much the stock Wraith shafts weigh being plastic and all. Just looked at CI's website. Looks interesting. I might have to look into it. I saw a couple output shafts broken this last weekend too so I am worried about all of it. LOL. Not that CI's prices are bad but the Junfac are still a bit cheaper at $34 for a pair of shafts compared to $50. Maybe the output makes it worth it though? HMM. This is one spot I knew I would have to take a hit on weight but I wanted the strength. I eventually ended up with dog bone shafts on my losi (LNC driveshafts) and they were my favorite. They were light and I never had a problem. That is where I would like to end up with this. | |
07-23-2012, 10:13 PM | #36 |
Quarry Creeper Join Date: Sep 2010 Location: Deus est mortuus, logica obtinet.
i'm running maxx shafts on mine without the adapter, so they're a little wobbly but i haven't had any issues with them other than the fact that i cut them too short so they occasionally pop apart. i'm not running a super high power brushless system like a pro4 or anything.
07-23-2012, 10:14 PM | #37 | |
I have only taken a couple bars out so far. I am foaming at the mouth to take out more and have had to really hold back. Since there is only one shot, I want to put some time thinking about it and make sure I do the right mods to the cage. But yeah, I weighed an almost complete cage with no skid or anything besides the round plastic parts and it was close to 12oz Other obvious things will be aluminum/TI screws and AL rod end balls. Oh, I forgot to mention... when I put Revo ends on my links I did not like how they had slop at the skid. I found out that you can put the stock plastic balls in the Revo ends and they are a perfect fit. After this last weekend, the plastic now has some slop, not as bad as a Revo ball did though. Still working on this as I hate ANY slop in my suspension. | |
07-23-2012, 10:19 PM | #38 | ||
No issues from MMP to ballistic. I am not much of a fan of Novak but I really do like their ballistic motors. Swapping a stator is just $30 and easy to do. I ran this combo in my Losi and if I didnt have issue there then I dont think I ever will. Quote:
07-23-2012, 10:19 PM | #39 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
What about drilling holes through the female side of the drive shaft?
07-23-2012, 10:20 PM | #40 | |
25g full length uncut. I never weighed output. Ive best the piss out of these on old comp rigs with no problems, but never on a 13.5 on 3s so we will see. | |
Dlux Wraith Build - Similar Threads | ||||
Dlux Berg Build | Erik D_lux | EnRoute Berg | 1696 | 05-22-2018 10:10 PM |
DLUX super build | Erik D_lux | Superclass Crawlers | 578 | 07-20-2016 09:13 AM |
My First build the wraith | redneckrampage | Axial Wraith | 5 | 04-18-2012 09:44 PM |
Dlux mini build | Erik D_lux | Losi Mini-Rock Crawler | 92 | 09-22-2011 05:28 PM |
