07-30-2012, 03:42 PM | #81 |
| Re: Dlux Wraith Build I guess so. That sounded like a PITA, so I ordered the regular hardware HLC lockers. Seriously though, when I built that front diff, I used plenty of loctite on those little screws. When I pulled it apart the other day, they were all loose. Not backed out too bad, but loose. |
07-30-2012, 04:34 PM | #82 | |||
| Re: Dlux Wraith Build Quote:
I am really digging the rear steer at this point. Quote:
I was actually going to ask if people thought the failure would be from the screws backing out, figured people either would not know or would not want to admit. | |||
07-30-2012, 04:42 PM | #83 |
I only have blue or red....so it was one of those. I really cant see myself using the red though...
07-30-2012, 04:53 PM | #84 |
Whats up with the lack of commitment? I never use blue. |
07-30-2012, 04:53 PM | #85 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Mine werent loose, the locker partially spun and the screws gave the rest. Im pretty hard on my sporty so I figured it was a good idea. Ill take the dnf next time lol Granted all the breakage I used to get was from that damn puller motor. She drove thru parts at 1/4 throttle |
07-30-2012, 05:14 PM | #86 |
| Re: Dlux Wraith Build |
07-30-2012, 05:41 PM | #87 |
07-30-2012, 07:57 PM | #88 |
The plastic locker spun or the cast locker? That pulller was pretty sick eh? Think its got more power and high end then brushless? I have never been around one. |
07-30-2012, 08:38 PM | #89 |
Idk never ran brushless in my old shafties, only big outrunners, brushed and that puller. I would say it seemed stronger then the big hyperion outrunners but way smoother. I still have it, not sure what to put it in though
08-22-2012, 02:01 PM | #90 |
Newbie Join Date: Jan 2007 Location: Washington DC
Great thread, as I've read through a few of them in my first week here. Can you explain this whole locker design? Yours looks so straighforward I can't understand why the stock one looks like a regular gear diff filled with a metal "cross" slug of metal to hold drive the two axle shafts. Since I don't have an axial yet I'm just guessing from the posted pictures of the failed stock units. A few post back you also had sand paddles mounted on your wheels, which required huge spacers to work. Also not familar with your products, wouldn't you just rather make up a set with the correct back spacing? Keep up the posts, I like the milled, drilled and turned parts. |
08-22-2012, 03:04 PM | #91 | |
The only other way to make my wheels with the "correct backspacing" would be to flip the wheel around and put the face on the back. The wheel would need to have an extreme negative backspace. Doing it the way I did makes the wheel stronger and I also dont like the look of an extreme negative backspace wheel and it also would allow a ton of dirt/sand inside. On another note,... I am considering selling this car off. I think I may have been looking for something more along the lines of a Revo? I cant stand owning cars that just sit on the shelf. | |
08-22-2012, 03:12 PM | #92 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
"I'll give you two cheerios and a fiver" Most are prob to young to remember that. |
08-23-2012, 05:32 PM | #93 |
RCC Addict Join Date: Apr 2009 Location: Behind the wheel
I believe they make the lockers like that so that they can use the same spider gear carriers as they use in the open diffs, thus saving money since axial uses them on multiple rigs. Ive also used hpi nitro rs4 carriers and they fail when the little pins on the axial iron cross locker fail. A word on the maxx shafts, I run them on my pig of a wraith, 14t puller on 6s lipo.They will hold up just fine. I don't remember the part numbers but one of the maxx yokes has a smaller hole in it, it was for the tranny outputs on the tmaxx iirc. Then all u gotta do is drill them out to fit. DONT SELL IT. DRIVE IT!!! |
09-03-2012, 03:55 AM | #94 | |
Quarry Creeper Join Date: May 2012 Location: Italy
I am just about to order new driveshafts, and am actually down to MIP vs. Junfac What do you suggest? MIP or Junfac120-155? Or JF standard length for wraith? Thanks a lot! Sent from my iPad using Tapatalk | |
09-03-2012, 10:59 AM | #95 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
Awesome build, my wraith is heavier than Roseanne bar at a free pie eating contest ! I need to put her on a diet. I think that I may drill my stock seats out see if I can make em light. Thanks for the inspiration!
09-03-2012, 11:09 PM | #96 | |
I ran the MIP and Junfac in my Losi comp crawler. I liked the Junfac so much better that it made my decision easy for this build. Thanks! | |
Dlux Wraith Build - Similar Threads | ||||
Dlux Berg Build | Erik D_lux | EnRoute Berg | 1696 | 05-22-2018 10:10 PM |
DLUX super build | Erik D_lux | Superclass Crawlers | 578 | 07-20-2016 09:13 AM |
My First build the wraith | redneckrampage | Axial Wraith | 5 | 04-18-2012 09:44 PM |
Dlux mini build | Erik D_lux | Losi Mini-Rock Crawler | 92 | 09-22-2011 05:28 PM |
