Thread: Differential ~ Slop @ Pinion (36/14)???
Old 08-25-2012, 04:10 PM   #1
Default Differential ~ Slop @ Pinion (36/14)???
Im noticing a fair amount of play (slop) in the pinion at the diffeential which seems to be coming from the bearing inner race. Im sure this is common on any pinion/ring gear combo but how are you guys combatting this one?
SwampDawg is offline   Reply With Quote
Old 08-25-2012, 04:18 PM   #2
Jus
Default Re: Differential ~ Slop @ Pinion (36/14)???
up/down//left/right play or in/out? Are there two bearings and both are good?
I put a Traxxas teflon 5mm washer between the outer bearing and MIP shaft to keep the pinion out away from the diff where the mesh seems happiest and left it at that.
Jus is offline   Reply With Quote
Old 08-25-2012, 06:31 PM   #3
in/out which i beleive is fine, its up/down making the driveshaft wobble signifigantly by hand (manual) and the bearings are both still relatively new. Just got the wraith a month or so ago and have only a dozen runs on er'
Old 08-25-2012, 07:10 PM   #4
I've got the overdrive ring and pinion in my Wraith and there is a little up/down play, but it doesn't seem to affect the balance of the drive train. Stock WB driveshafts with inserts for strength.
Maybe your driveshaft(s) have a bit of a twist making them run out of balance?
Solitaire is offline   Reply With Quote
Old 08-25-2012, 07:53 PM   #5
What driveshafts are you running? My MIPs have a little slop in em. The pinion is actually not where most of the play is coming from. If you have MIP driveshafts I have heard that the play can be helped by using Traxxas style driveshaft set screws with a small shoulder. Haven't tried it because the play doesn't seem to be bothering anything.
Jeepfixer1 is offline   Reply With Quote
Old 08-25-2012, 08:32 PM   #6
the only stock parts left on my axles are the lockers (Fr/Rr) and the drive-shafts. Eventually ill get the VP lockers and MIPs but for now...itll have to do!
this Wraith is one helluva moneypit *jeesh*
Old 08-25-2012, 10:32 PM   #7
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Just run it. It will be fine.
Harley is offline   Reply With Quote
Old 08-26-2012, 04:51 AM   #8
I had in out slop so i just installed some 5mmx8mmx.05mm durango shims on the outside of the pionion shaft. No more play
Cableman is offline   Reply With Quote
Differential ~ Slop @ Pinion (36/14)??? - Similar Threads
Slop!!! kredfearn Venom Creeper 7 03-31-2012 08:42 AM
slop redcatguy Axial XR10 12 09-14-2010 11:40 PM
pinion slop??? haynesn12 Tamiya TLT Crawlers 8 02-16-2008 01:14 PM
Is this the differential for the WK?? GUERO4X4 HPI Wheely King 7 06-29-2007 04:46 AM
Differential DKNguyen General Crawlers 7 03-03-2007 12:15 PM
