08-09-2012, 06:05 AM | #41 |
Pebble Pounder Join Date: Aug 2012 Location: Home
| Re: My Wraith "Standard Issue UEP" Thanks for fixing my thread!!
08-09-2012, 06:25 AM | #42 | |
| Re: My Wraith "Standard Issue UEP" Quote:
08-09-2012, 06:46 AM | #43 | |
08-10-2012, 06:57 AM | #44 |
I did a little playing today.. i realized that my Holmes Hobbies 27t motor is taking a dump.. this a temp trail fix.. swapped out my motor for a 45t Novak just to get some wheel time.. not a good choice! but at least im rolling no comments on the wire nuts please! got some decent pics so.. we are gonna make a sand berm type jump here one of the off camber downhills on the track didnt see the big hole after the drop off...so my buddy said i had to post it Looking back i should have done a series of pics from the top, down into the creek, then around the valley floor and back up the other side leading to a huge wire bridge but my phone died... |
08-10-2012, 07:08 AM | #45 |
Random thought.. I need to invent a pill that makes you crap money! .. Anyway my buddy sucks at taking pics!! its hard to get rolling shots of any quality while driving and taking pics. Im gonna have a nephew, who is an awesome photographer, come down to the track and take some really good shots and video.. multiple rigs and a good day of running. I have to get my motor issue straight.. Can the stock Esc take a Titan 12t? |
08-10-2012, 03:22 PM | #46 | |
Quarry Creeper Join Date: Sep 2010 Location: West Linn
08-10-2012, 03:32 PM | #47 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
your using household twisties to connect your wires? oooF! invest in some Deans or PowerConnectors bud' |
08-10-2012, 03:56 PM | #48 | |
Quarry Creeper Join Date: Oct 2006 Location: Tehachapi
08-12-2012, 01:34 PM | #49 |
| Re: My Wraith "Standard Issue UEP" Thanks Aaron .. like i said this was a quick trail fix.. my HH 27t crapped out and i stole the motor outta my scaler.. it was a Novak 45t.. i really wanted to play!! when i put my scaler together i put the connectors on backwards so hence the wire nuts... The Novak 45t sucked in my Wraith
08-16-2012, 10:13 PM | #50 | |
Quarry Creeper Join Date: Sep 2011 Location: Columbus, Ohio USA
I'm kinda curious to what gearing your running, still stock? that's alot of dead motors. I switched to brushless as my fourth or fifth brushed motor was on it's way out. Fwiw mine weighs not quite 8 pounds with a 4000mah 3s pack. It spends a good bit of time in the air, so I keep it on a diet Later Speed | |
08-17-2012, 04:42 AM | #51 | |
Your rig so sick!! id love to get mine to the same point ... yes im still running stock gearing... i guess my final ration depends on the motor i have. im torn as to which motor esc combo i should buy.. money is very limited and i need to get my choice right the first go round... The VXL system is awesome, i like it after seeing you videos!! but you change you gearing for the terrain you run?... i want more speed than my HH 27t but i still wanna be able to crawl... suggestion welcome!!!!... i have a Castle SV2 esc and a CM36 5700KV 3.5t brushless from my 1/16 revo... keep think of dropping it in the Wraith for fun!!! Last edited by Crash1388; 08-17-2012 at 04:59 AM. | |
08-17-2012, 04:51 AM | #52 |
i had a buddy re surface my HH 27t commentator and brushes and it seems to be working great again...for now. Maybe i'll get a HH Esc/20t motor combo, when i can no longer keep my 27t running |
08-17-2012, 10:04 AM | #53 | |
The stock gearing only works with stick packs... lol throw an 87 spur on there and you'll double it's lifespan. You really need to gear down and volt up as they say. You gain torque through the gearing and reduce strain but get the top end back through shear RPM. I'd run 16/87 and 3s with your 27t. The AE-2 will run 3s all day with a BEC, honestly I think the 27-35t and 4s would be a hot setup for a crawler guy. Yep sometimes I change gearing for terrain, 16/87 is used 90% though, 12-14/87 for rocks and 18/87 for open areas. 20/87 overheats the motor with the swampers on, I can run a 20t with my Hammers though... 12/87 will give you some drag just from the motors unwillingness to spin but there are days I miss having a drag brake. It's not that it cogs either the problem is with above 14t doing heavy crawling I have to run a 65c pack since the motors pulls so much juice on lesser packs it trips the voltage cutoff in the VXL. I crawl on 3s too but use noob mode on the esc. You get twice the resolution on the trigger and still have ample power to twist off driveshafts w/o all the RAWR!!! of 3s wide open. Oh I have 43/13 diffs too so I'm geared a little lower than what my pin/spur suggests. If you try that cm36 gear it super low, like 90/10 might have to dremel your mounting slots. My vote for esc's would be the Holmes BRXL, water proof, a built in badass BEC, castlelink flexibility, only drawback is the lack of brushless ability. Your SV-2 is a fine choice but with a 3500ish kv brushless and stock gearing the current draw might smoke the esc, I think it has a 100amp limit, needs a BEC too. I talk too much | |
08-17-2012, 01:29 PM | #54 | |
Okay my Holmes 27t is working for the moment and i have a 32 Pitch 54t Spur and a 14t pin from CKRC .. so 1st off should i get a new armature from Holmes or just get one of their ESC/Motor combo deals since i was planning to upgrading to a 3s. Maybe a 19t or20t for the motor? 2nd what does the 32 pitch cross over to in 48 pitch ratios, example being 16/87 vs 14/54.. and i wanna keep my drag brake so the sv2 will stay in my Revo... its the only RC that holds together when i really pound on it! 6ft air, trip backfilp off a table top meant for stadium trucks...no damage God bless RPM...any ways back to the Wraith. I dont wanna be 1st in the race but i wanna be damn close. In my diffs, stock gearing also.. im running the 2.2 iroks and i dont usually change tires.. so what do you think i should go with for them using the above Holmes combo? | |
08-17-2012, 11:47 PM | #55 | ||||
I think a 20turn is too low, I'd stay 27 or go 35 turn and run a minimum of 3s. If I were brushed you can bet your *** I'd be running 4s only drawback is high V's wears out brushes faster but boohoo right? gotta pay to play. Quote:
54/14=3.86 87/16=5.44 Higher numbers go slower... 3.86 is pretty fast for comparison my 8lb losi SCTe runs 40/13, that's 3.07:1 So your actually geared closer to my race truck than my basher, and you call yourself a crawler hehe Quote:
I'd grab a 27ish turn motor and get on the waiting list for a BR-XL. When you want to go faster run more voltage. I've never seen a 27T on 6s but I bet it's pretty retarded Other option is the RX8/MMP esc with either a 10.5turn tekin or the pro 4 3300. Not really an apples to apples deal though, the brush route is way cheaper but sensorless brushless is the shizzel for mud and water. You could do a Sidewinder with a Velineon for similar $ of the brushed setup but the Sidewinder isn't the most robust esc and you'd still want a BEC. The Velineon will start to cog above 18/87 Food for thought, geared 14/87 on 3s my Wraith is just about as fast as it was geared 20/80 with the stock brushed motor on 3s... difference is now it's like Grave Digger on crack and the motor never goes over 140 degrees F the esc stays cool and I can bash til parts fly or I get tired. Gear down, volt up! google it... there's tons of threads. A 3500kv brushless motor spins 29,400 on 2s, 44,100rpms on 3s. I know the gearing seems low at 5.5:1 but you get to run 30% less gear and go just as fast. Ok starting to ramble. Speed out | ||||
08-21-2012, 11:50 AM | #56 |
Okay i picked up a 3400mah Racers-edge 3s lipo and im gonna be robbing my Scx 10 (Brutus) of his 16/87 pin /spur combo... wish me luck!!!
08-21-2012, 04:02 PM | #57 |
okay 14/87 is no good for what i wanna do... to slow...even with the 3s... i have a 18 pin lying a round, but will a couple or teeth really make that big of a difference... im trying to get a 16pin from a buddy's stampede
08-21-2012, 07:59 PM | #58 |
i put the 18/87 on and it is much better... 3s way better but i should've gone for a 4s... think im gonna go back to the 18/20 combo tomorrow and see how it works... side note the Wraith is 9.76lbs with the batteries... im good with that!
08-22-2012, 10:03 PM | #59 |
You can run as much gear as the motor can handle, just watch your motor temps closely. If you get past 150 F it's overgeared... what you want and what you can have may not be on the same page but 4s would be the **** |
08-23-2012, 05:39 AM | #60 | |
so i think im done with the combo for the spur/pin 18/87... i dont know maybe i'll try the 16t pin...so now i wanna play with the axle ratios.. any suggestion? had a good test run around the yard and bashing over my test rock pile.. motor temp was about 135 F.. thats a little higher than i wanted.. im headed over to the track today for some more testing..i think the temp will go up but hopefully not much! | |
My Wraith "Standard Issue UEP" - Similar Threads | ||||
Scx10 "the green machine" | gymjunkie23 | Axial SCX-10 | 12 | 10-03-2010 11:38 PM |
Awesome new Tuber/AX-10-the "Mean Green" machine! | birdie_in_texas | Axial AX-10 Scorpion | 11 | 07-23-2008 12:28 PM |
"Green machine" hustler | G-crawler | General Crawlers | 23 | 07-15-2007 02:44 PM |
"Green Machine" Lots of pics | brudmike7 | General Crawlers | 1 | 03-07-2006 09:18 PM |
project "GREEN MACHINE"mini-giant | Jt | Tamiya TLT Crawlers | 14 | 01-19-2005 02:51 PM |
