![]() | #1 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
Im noticing a fair amount of play (slop) in the pinion at the diffeential which seems to be coming from the bearing inner race. Im sure this is common on any pinion/ring gear combo but how are you guys combatting this one?
![]() | #2 |
up/down//left/right play or in/out? Are there two bearings and both are good? I put a Traxxas teflon 5mm washer between the outer bearing and MIP shaft to keep the pinion out away from the diff where the mesh seems happiest and left it at that. |
![]() | #3 |
in/out which i beleive is fine, its up/down making the driveshaft wobble signifigantly by hand (manual) and the bearings are both still relatively new. Just got the wraith a month or so ago and have only a dozen runs on er'
![]() | #4 |
RCC Addict ![]() Join Date: Oct 2011 Location: British Columbia
I've got the overdrive ring and pinion in my Wraith and there is a little up/down play, but it doesn't seem to affect the balance of the drive train. Stock WB driveshafts with inserts for strength. Maybe your driveshaft(s) have a bit of a twist making them run out of balance? |
![]() | #5 |
Rock Crawler Join Date: Apr 2012 Location: Chattanooga
| ![]() What driveshafts are you running? My MIPs have a little slop in em. The pinion is actually not where most of the play is coming from. If you have MIP driveshafts I have heard that the play can be helped by using Traxxas style driveshaft set screws with a small shoulder. Haven't tried it because the play doesn't seem to be bothering anything.
![]() | #6 |
the only stock parts left on my axles are the lockers (Fr/Rr) and the drive-shafts. Eventually ill get the VP lockers and MIPs but for now...itll have to do! this Wraith is one helluva moneypit *jeesh* ![]() |
![]() | #7 |
20K Club ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
Just run it. It will be fine.
![]() | #8 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
I had in out slop so i just installed some 5mmx8mmx.05mm durango shims on the outside of the pionion shaft. No more play ![]() |
Slop!!! | kredfearn | Venom Creeper | 7 | 03-31-2012 09:42 AM |
slop | redcatguy | Axial XR10 | 12 | 09-15-2010 12:40 AM |
pinion slop??? | haynesn12 | Tamiya TLT Crawlers | 8 | 02-16-2008 02:14 PM |
Is this the differential for the WK?? | GUERO4X4 | HPI Wheely King | 7 | 06-29-2007 05:46 AM |
Differential | DKNguyen | General Crawlers | 7 | 03-03-2007 01:15 PM |
