08-26-2012, 05:34 AM | #1 |
Rock Stacker Join Date: Nov 2005 Location: American Fork
| Stance
So I have lowered my wraith with a shorter shock and mounted me on the middle hole of perch. I'm not super low but I bottom out on everything and scratch the crap out of my belly. Am I just a crappy driver or is it normal to scrape bottom when crawling? I'm also not getting a ton of articulation, I'm using the stock spring just a tiny bit shorter shock I got from a buddy.
08-26-2012, 07:24 AM | #2 |
| Re: Stance
You're more likely to drag the belly when you're lower to the ground. Careful driving will avoid it sometimes but not always. Less articulation is better so that's not necessarily a bad thing. If it crawls well and suits your driving style leave it alone.
08-26-2012, 10:03 AM | #3 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
| Re: Stance
It's called a skid plate for a reason.
08-26-2012, 10:10 AM | #4 |
Rock Crawler Join Date: Apr 2009 Location: bend
| Re: Stance
It's a skid plate us it. I have mine with the stock shocks super soft springs. Then i moved to the innermost upper mount. I like a 3/4 droop set up. When you hit your skid the front will drop and you can get some traction.
08-27-2012, 01:40 AM | #5 |
| Re: Stance
word. Im scratching the hell out of my lower links too. Ill have to post some pics of my rashings so far. I painted my frame and its getting scraped off along the sides, anyone got advice on some good sliders?
08-27-2012, 04:32 PM | #6 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: Stance
The lower links will get scratched because they are exposed pretty easily to rocks, etc... Get the tallest tire you can and that will help bring the Wraith up a bit! |
Stance - Similar Threads | ||||
Stance,,,,front and rear | mgauger | Axial XR10 | 6 | 02-27-2012 01:30 PM |
Wider Stance? | The Jackalope | Redcat Crawlers | 6 | 05-01-2011 06:07 AM |
Weird Stance | MaverickMatt | Newbie General | 9 | 12-26-2010 05:34 PM |
Wider Stance | GIXXER | Losi Mini-Rock Crawler | 2 | 12-27-2009 10:13 PM |
widen there stance? | topdog909 | Axial AX-10 Scorpion | 5 | 06-18-2008 07:10 PM |
