09-08-2012, 01:24 PM | #1 |
Newbie Join Date: Aug 2012 Location: Humboldt County
| Drive goes out then goes back in?
Noob here with more problemos. I installed VP universals, Chubs, knuckles, and the HR link kit. Went to take it for a drive and it ran fine for a minute then stopped. I could hear the motor still moving but no forward or reverse. I grabbed the tires and manually spun them forward and backwards and then it would drive for a minute. Then cut out again. I assume the Universals are not installed correctly? Any advice is appreciated.
09-08-2012, 01:37 PM | #2 |
RCC Addict Join Date: Mar 2010 Location: Yelm
| Re: Drive goes out then goes back in?
Hmm. Tighten the slipper clutch? The tires move freely when you aren't pulling the trigger? Motor runs but the tires dojn't move....hmmm...Something may be stripped out..... Maybe you broke a locker?
09-08-2012, 02:05 PM | #3 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
Also check the pinion gear, the set screw may have backed off a little.
09-09-2012, 09:19 AM | #4 |
Pebble Pounder Join Date: Mar 2010 Location: Orlando
I agree with both of the above, either stripped locker or (and my bet) you didn't locktite the set screw on the pinion. I neglected the locktite on my first couple rigs, and it cost me many frustrations.
09-09-2012, 09:35 AM | #5 |
You shouldn't need to loctite the pinion. I never have and never had one loosen. If it wasn't tightened properly though it needs to be checked.
09-09-2012, 09:47 AM | #6 | |
| Re: Drive goes out then goes back in? Quote:
Any metal to metal threaded part should have loctite on it, vibrations cause things to come loose. A loose set screw on the pinion or driveshafts is a pretty common problem. | |
09-09-2012, 01:42 PM | #7 |
Thanks for all the input. Truck was a RTR so I'm sure there was no locktite on the pinion. I'll have some time this afternoon to work on it some more. Will keep you posted.
02-22-2013, 06:40 PM | #8 |
Decided to try to fix the wraith after six months of it sitting. The set screw had backed out of the pinion gear. Real easy fix. Thanks for everyone's help. I added a little loctite to it. Now to build a little backyard crawl space.
02-22-2013, 06:58 PM | #9 |
damn dude you let a 400 dollar rig sit for 6 months and the fix was damn near free reminds me to go check craigs list. glad you got it fixed |
02-22-2013, 07:39 PM | #10 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
ummmmmmmmmmm maybe he was busy with life not worrying about the toys! |
02-22-2013, 07:44 PM | #11 |
yeah probly.
02-22-2013, 07:56 PM | #12 | |
02-23-2013, 11:35 AM | #13 |
Yeah. LOL. I've been busy with kids, work, other toys, etc etc. Hope to get back into it now.
02-23-2013, 12:04 PM | #14 |
Yeah I hear you about loctite on some tiny grub screws. Losi 370 motor ones in particular are very small and I stripped the hex when trying to tighten the screw down so I could only imagine trying to remove it with blue loctite on it. I got it out by jamming the smallest flat blade in the hex hole and using my cordless screw driver for torque. It worked awesome and I was very relieved...well unfortunately or maybe fortunately the Losi Insane 370 I had got cooked and died dead. End of my Losi motor days..lol. That was a different project but just wanted to share a story about pinions. :P
Drive goes out then goes back in? - Similar Threads | ||||
AX10 MIP C Drive dig drive shafts in stock! | RPP Hobby | RPP Hobby | 1 | 12-03-2009 10:50 PM |
***MIP C-Drive Drive shaft for the AX10...GIVEAWAY*** | Rockpiledriver | RCP Crawlers | 153 | 07-01-2008 11:18 AM |
How to lock back tires and only use front wheel drive | jlnash | Newbie General | 4 | 02-16-2007 07:09 PM |
