Thread: Super Slow Wraith
Old 09-08-2012, 03:45 PM   #1
Default Super Slow Wraith
Tried search; didn't find anything.
My newly-built Wraith is ridiculously slow and I'm not sure where to start looking for answers. Here's a (very) short video:
Slow Wraith
- MMP, lights flash yellow after tones, green when forward, red in reverse
- Tekin Pro4 3,300
- Motor to ESC: 12g wet noodle/CC 4mm bullets
- 32p 54T spur with / RR hardened .8mod 14T pinion
- Hyperion 3S, 35C, 4,200
- Sensor cable plugged in, ESC set to SmartSense
- Battery/BEC in front, ESC/Receiver in the rear
- Stock tires/Axial Beadlocks (non-metal)
- Radio settings unchanged from new profile: 100% travel, no DR, etc...
I don't suspect the battery (makes my E-Revo Brushless fly); I tried several others.
malekia is offline   Reply With Quote
Old 09-08-2012, 04:23 PM   #2
Default Re: Super Slow Wraith
get a castle link and play with the settings
bongrips420 is offline   Reply With Quote
Old 09-08-2012, 05:10 PM   #3
Did you calibrate the ESC to your radio? You may not be getting full throttle. Like Bongrips said,get a Caslie Link if you don't have one. You will want it to get all the features the ESC has to offer!
Good luck!!
Radron is offline   Reply With Quote
Old 09-08-2012, 05:17 PM   #4
I joined the Band!
Good luck!!
yeah i know i noticed at times i had so little fwd but tons of reverse... had to re-calibrate it..
then all good
RootBreaker is offline   Reply With Quote
Old 09-08-2012, 05:21 PM   #5
Great to hear all is good,now go break something & upgrade, LOL!
Old 09-08-2012, 06:27 PM   #6
Thanks for the suggestions. I have already re-calibrated (a few times) without any improvement.
Also, I do have the Castle Link, but don't think I should have to change anything to get reasonable performance.
Old 09-08-2012, 08:05 PM   #7
Take it off smartsense and see if that makes a difference. May just try rebooting the settings to the ESC too.
You could also try switching two of the motor wires and reversing the ESC settings.
Old 09-09-2012, 09:07 AM   #8
Thanks, I'll try a different setting, but I'm curious: Is the performance on my video even close to what my hardware produce? I hope not!
I've seen many mentions of the Tekin Pro4's power and tendency to break parts. I'm not seeing anything close to that. It's not even breaking a sweat!
I know my video sucks, but does my Wraith sound normal?
I'm not expecting the same speeds I get out of my E-Revo Brushless (6S), but considering how much lighter this is, I expect it to be fast.
Old 09-09-2012, 01:49 PM   #9
Check the timing on the motor and through the castle link. I got mine set to 4 degrees with the castle link and it is stupid fast
rollincoal3500 is offline   Reply With Quote
Old 09-10-2012, 06:16 PM   #10
I changed from SmartSense to Sensored Only without improvement. I'll try your suggestion next!
Old 09-11-2012, 12:08 PM   #11
When i got my wraith from a guy it went way faster in reverse... then i flipped my gears in the diffs around to the right direction and Bam its fixed... make sure everything is going the right way
BoardN88 is offline   Reply With Quote
Super Slow Wraith - Similar Threads
Slow ass super build CREEPERBOB Superclass Crawlers 426 06-27-2022 05:29 AM
Super slow build! silentbeatdown Axial SCX-10 5 09-15-2012 02:50 AM
BuckImod's Super Slow Build BuckImod Superclass Crawlers 6 11-19-2011 10:42 PM
super super slow speed question. srkhahou Newbie General 14 03-12-2011 02:05 PM
