11-01-2013, 12:52 PM | #181 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: Roller |
11-01-2013, 03:34 PM | #182 |
| Re: SkaldidDog's "Buck-Nasty" Wraith |
11-01-2013, 04:16 PM | #183 | |
| Re: Rewiring done Quote:
11-01-2013, 05:20 PM | #184 | |
11-01-2013, 05:34 PM | #185 |
Thanks, that's what I thought. Swapping my HS7955TG to my 1.9 Honcho and installing HS7950TH to my Wraith and will re-do my bec at the same time.
11-01-2013, 10:05 PM | #186 |
11-02-2013, 07:19 PM | #187 |
This right here is what this hobby is all about. Thanks for sharing your build as it progresses |
11-02-2013, 11:11 PM | #188 | |
| Re: SkaldidDog's "Buck-Nasty" Wraith Quote:
J Last edited by SkaldidDog; 11-02-2013 at 11:24 PM. | |
11-04-2013, 08:31 AM | #189 |
| New Hood and Siped TSL's
After a month or so in the shop I finally got to drive the new suspension setup. Holy crap the rig handles so much better. Kyosho shocks with HPI and Losi springs work very well. I beat the crap out of it for a about three miles of rocky gulley climbs and had no failures other than a skid plate screw backing out. I just couldn't stand the chopped off shovel looking stock hood so I made my own. I like the stumpy, boxy look. For some time I've wanted to sipe my TSL's. The central lug band pattern is way too dense. So I aired it out a little bit and man these tires have come alive. Significant improvement. Now if they were just 0.250" larger OD...like the Mickey Thompson Baja Claws. These will arrive soon and I'll sipe them too. Siping is always messy. The tire on the right has the lug sectioning done with a dremmel and the tire on the left has the lug section removed (with scissors). I really like the pattern because they hook so much better. You can appreciate the new lug pattern more by looking at the driver tire in the articulation shot above (pic #2). Well she's parked again until I make HD universal bushings sometime this week or so. They are totally shot. New ones will be a significant improvement over stock. J |
11-04-2013, 10:36 AM | #190 |
Rock Stacker Join Date: Mar 2013 Location: Victoria
You don't happen to have plans for your servo mount do you? Or the CF brace? |
11-04-2013, 02:10 PM | #191 |
11-04-2013, 06:48 PM | #192 |
11-04-2013, 07:22 PM | #193 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
Nicw rig!!! How did you mount your 3 link on front axle? It looks clean & truss out of the way! after looking I see the custom mount...NICE!!! Last edited by sic1to; 11-04-2013 at 07:26 PM. |
11-05-2013, 08:22 AM | #194 | |
J | |
11-05-2013, 08:35 AM | #195 |
11-05-2013, 09:20 AM | #196 |
11-06-2013, 08:05 AM | #197 |
| Mickey Thompson [big arse] Baja Claws I'm sure someone will produce one of my trinkets for sale. This happens from time to time. So I finally got my hands on some MTBCs and boy they are tall and narrow, which I really like. They dwarf my Swampers. Foam tuning will take some effort but I'm sure I'll find something that works. The compound is super soft and sticky. They will wear faster than my Swampers for sure but will provide better GC and grip. To improve grip I removed the alternating small inner lugs. See below for before, going and gone views. As you can see the siping really helps them breathe. Once I get my HD bushings made I'll beat on these some. Foams first. More later. J |
11-06-2013, 08:39 AM | #198 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
the middle pic, switch the small inside lugs to large inside lugs, really woke mine up. Oh, and run them backwards ;) Last edited by Erin; 11-06-2013 at 08:43 AM. |
11-06-2013, 09:34 AM | #199 | |
I thought about using that siping pattern for a second but then I realized that if I pulled the larger inner lugs, alternating rows would would be comprised solely of that tiny outer lug. Given the soft compound and expected shortened life, I wanted to open up the pattern without taking out too much material. I will run them back'erds. Cheers, J | |
11-06-2013, 10:18 AM | #200 |
True, mine are 1.9 as well, but they work 100% better, and almost unstoppable on loose hill climbs now. They have worn pretty good, but they have had a hard life to
SkaldidDog's "Buck-Nasty" Wraith - Similar Threads | ||||
Skaldiddog's "Progress" | SkaldidDog | EnRoute Berg | 1181 | 12-11-2018 09:05 AM |
The "Nasty" Pajero!!!! | TattooKenny | Tamiya XC/CC01 | 40 | 11-30-2009 12:00 PM |
Wheres the "bang for the buck" tapping sets | TLTCrawlin | Tools, and Procedures | 13 | 01-04-2007 12:26 PM |
