Thread: SkaldidDog's "Buck-Nasty" Wraith
Old 03-07-2014, 04:09 AM   #261
Default Re: SkaldidDog's "Buck-Nasty" Wraith
Originally Posted by SkaldidDog View Post
I need to mill a personal cinematographer and get on that.
J
fabricate a mount for a gopro
rumnyc is offline   Reply With Quote
Old 03-08-2014, 08:19 PM   #262
2013 2.2P Nat. Champion
SkaldidDog's Avatar
Making progress.
SkaldidDog is offline   Reply With Quote
Old 03-08-2014, 09:03 PM   #263
Wow. That's heavy-duty!
New uppers?
rob_b is offline   Reply With Quote
Old 03-08-2014, 10:13 PM   #264
SkaldidDog's Avatar
Getting my sway on.
Old 03-08-2014, 11:05 PM   #265
I assumed, just thought the two long rods might be new uppers. Interesting things that you do...
Old 03-09-2014, 08:47 AM   #266
SkaldidDog's Avatar
Default Sway Cool
The sway bar arms are Ti and the brackets and bar guides are heavenly75. I was going to make the guides out of Ti but changed my mind. Hopefully I can finish it today.
Mounting brackets.
Ti rod for the risers that attach the arms to the axle.
This is going to be cool...if it works.
Old 03-09-2014, 09:59 AM   #267
Looks sick! Awesome work
polcyn1030 is offline   Reply With Quote
Old 03-09-2014, 06:16 PM   #268
SkaldidDog's Avatar
Default Sway V1 Done
Works well. Still need to put it through its paces. V2 arms drawn. Hope to knock them out this week. Overall I like the performance. I couldn't tap Ti so I cranked out 7075 arms.
J
Old 03-11-2014, 08:55 AM   #269
SkaldidDog's Avatar
Default Let's try this again, again...V3 sway bar arms
I really didn't like the first iterations of my sway bar arms for several reasons. These suit me better. I'm sure they are overkill (7075) but I'll put them through the paces before putting them on a diet.
I like that they match my shock upper mounts.
The seats are out for the install process. I still haven't driven it properly with a bar...yet. Hope to soon.
J
Old 03-11-2014, 01:15 PM   #270
I like your packaging!
Old 03-12-2014, 08:31 AM   #271
SkaldidDog's Avatar
Default Put a rear sway bar on your Wraith now!
Why thanks...I guess.
Update!
Go buy a rear sway bar for your Wraith here now. You won't regret it. I can not believe how much better the rig handles on fast flat ground and crawling/climbing. It puts down traction so much better. Run the softest springs you can get away with for your ride height and start there. My tires will pay the price...and did yesterday.
Cosmetic weight reduction.
I took 0.050" off of the trailing end of the arms where the links mount. This allowed the top of the links to move inward on the axle and stand vertically. I also shortened the links by 0.1" to parallel the arms with the ground at ride height. Like Erik says, square and straight.
This tire compound is very soft. Good in some cases but not in others. Hence the large material-missing hole from yesterday's run.
Nothing a little bit of a silver Voodoo comp tire can't fix.
J
Old 03-12-2014, 09:52 AM   #272
MEOW
Natedog's Avatar
Default Re: Put a rear sway bar on your Wraith now!
Update!
J
Very nice! Bought a rear swaybar, but have not installed it yet...looks good!
Old 03-12-2014, 11:19 AM   #273
Wanna get? Gotta want.
Erik D_lux's Avatar
Looks great Joel! I appreciate your dedication and love for all aspects of the hobby!
Once people look past the stereotype that a sway bar is for limiting flex they will then be able to use one and tune with it. It will just take time to get people to understand. All you really have to do is run a proper setup for 5 sec and you see a huge gain.
What is the name for that "10 flute countersink" in your picture above?
Erik D_lux is offline   Reply With Quote
Old 03-12-2014, 11:34 AM   #274
SkaldidDog's Avatar
Thank you sir for your assistance and for tech that works well and looks good.
I can't remember what it's called. My machinist knowledge is limited to drill bit and end mill. I'll find out for you.
J
Old 03-12-2014, 03:03 PM   #275
Chamfer mill.
Calderwood is offline   Reply With Quote
Old 03-12-2014, 03:26 PM   #276
SkaldidDog's Avatar
Originally Posted by Calderwood View Post
Chamfer mill.
Thank you Sir.
J
Old 03-12-2014, 06:33 PM   #277
Erik D_lux's Avatar
They dont come cheap.....
Old 03-13-2014, 12:17 AM   #278
D-Wray 4 Prez!
Frankenwheely's Avatar
I love seeing all these gentlemen of great creativity show off their work and they are not sure how they did it. Means I have a chance to be some body in this hobby.Keep drilling, milling and hacking boyz.
Frankenwheely is offline   Reply With Quote
Old 03-13-2014, 09:48 AM   #279
How ya liking the MT claws so far??? I'm looking for a taller tire for just a touch more clearance. I have been running swampers & BFG's which work great...but want taller tire. I see you done a lil cutting here & there is that pattern working well for ya? Ty champ!!!
sic1to is offline   Reply With Quote
Old 03-13-2014, 11:39 AM   #280
SkaldidDog's Avatar
I picked these up for the height as well. Compound wears very fast. Very soft and very grippy though. My cut pattern improved them a lot but also shortened their lives further. TSLs last a lot longer and work well with the cut pattern I tried. Cut your TSL's and try them before you drop bank on these. You may change your mind. But if you just want tall, get these. You'll like them. I'll run them into the ground...literally. Hope this helps.
J
SkaldidDog's "Buck-Nasty" Wraith - Similar Threads
Skaldiddog's "Progress" SkaldidDog EnRoute Berg 1181 12-11-2018 09:05 AM
The "Nasty" Pajero!!!! TattooKenny Tamiya XC/CC01 40 11-30-2009 12:00 PM
Wheres the "bang for the buck" tapping sets TLTCrawlin Tools, and Procedures 13 01-04-2007 12:26 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
