10-20-2014, 08:55 AM | #421 | |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: SkaldidDog's "Buck-Nasty" Wraith
[QUOTE=sic1to;4922481] Quote:
J | |
10-20-2014, 03:08 PM | #422 | |
| Re: SkaldidDog's "Buck-Nasty" Wraith Quote:
http://www.axialracing.com/products/ax30197 Last edited by Natedog; 10-20-2014 at 03:21 PM. | |
10-21-2014, 07:52 AM | #423 | |
10-21-2014, 08:37 AM | #424 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
A real man would start with 2" 7075 bar stock!
10-21-2014, 09:53 AM | #425 |
| Re: SkaldidDog's "Buck-Nasty" Wraith |
11-10-2014, 08:10 AM | #426 |
| De-bead no mas!
It's always annoyed me slightly that my SLW's outer bead don't hold my VooDoo U4's as snugly as I'd like. The inner beadlocks never see the lateral stress that the outers do so they are not a problem. So, I spun off 0.010" on the outer attachment surface to increase the bite the beadlock has on the tire. After a many mile jaunt all is well in the Land of Canaan. Man this rig is a blast. I feel sorry for the tires...sorta. J |
12-26-2014, 12:41 PM | #427 |
RCC Addict Join Date: Jul 2008 Location: San Diego
Joel do you run the same gears front and rear? Or under drive the rear?
12-29-2014, 08:14 PM | #428 |
01-02-2015, 09:00 PM | #429 |
| No slip
Finally got to deleting my Revo slipper and upgrading my Super Shafty top shaft. Made the spur lockout out of 7075 and the top shaft out of G5 Ti with monster M6 threads just for coolness. Overall weight savings was ~20g. Shortened the motor plate spacers by 0.095". Backup motor for tomorrow. Glory dirt testing. |
01-02-2015, 09:30 PM | #430 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
01-02-2015, 10:07 PM | #431 |
Guess my 1.5" stock falls just shy of manhood.
01-04-2015, 03:34 PM | #432 |
Holy overkill Joel, I like! Man I was starting to think that you lost the keys to your garage |
01-04-2015, 05:14 PM | #433 | |
Gotta sort out some electrical bugs now. ESC switches from sensors to sensor less after it warms up. Motor and sensor wire were not the problem. J | |
01-05-2015, 08:30 PM | #434 |
Nice work again Joel. House work can be draining. |
01-06-2015, 12:51 PM | #435 |
01-21-2015, 08:43 AM | #436 |
| Re-brained |
03-03-2015, 12:28 PM | #437 |
| Ne, new ESC
Well that new brain was a pain. Turns out that it had a bad component on the board. After much troubleshooting I eliminated all other possibilities and they quick shipped me a new, new one. One thing I did (re)learn was that cooling is king. My previous MMP was fan-less. Fan died and I chopped it off. I became very familiar with how far a given battery could go under specific driving conditions. With this new-new ESC, I left the fan on. Yes it makes noise, but the drive time is significantly improved per pack. I'll never run a MMP without a functioning fan again. All of this harps back to my comp crawler and the need to cool my ESCs for optimum conversion of volts and amps into wheel-speed. Quick mod: after snapping the head off of a motor screw and causing much work, I decided to use only socket cap screws (SCS) for motor attachment. There is a lot more beef around the base of the driver hole in a standard SCS than a big, flat cap traditional motor screw. The driver hole is deeper in a SCS than the traditional screw as well. But I need that big, flat cap...of 0.325" 7075. This should hold up. J |
03-03-2015, 01:06 PM | #438 |
Making an awesome rig better. What voltage battery you run? |
03-03-2015, 01:17 PM | #439 |
12.6 (3S MaxAmps 3300 150C). 16/56 gearing with under-drive (13/43?) in both ends.
03-04-2015, 04:50 AM | #440 |
RCC Addict Join Date: Feb 2012 Location: UK
All my Axial rigs have come with socket cap screws (SCS) for the motor attachment. I guess Axial agrees with you. |
SkaldidDog's "Buck-Nasty" Wraith - Similar Threads | ||||
Skaldiddog's "Progress" | SkaldidDog | EnRoute Berg | 1181 | 12-11-2018 09:05 AM |
The "Nasty" Pajero!!!! | TattooKenny | Tamiya XC/CC01 | 40 | 11-30-2009 12:00 PM |
Wheres the "bang for the buck" tapping sets | TLTCrawlin | Tools, and Procedures | 13 | 01-04-2007 12:26 PM |
