03-04-2015, 08:28 AM | #441 | |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: SkaldidDog's "Buck-Nasty" Wraith Quote:
J | |
03-04-2015, 08:32 AM | #442 |
RCC Addict Join Date: Feb 2012 Location: UK
Understood. My slashes use the flat ones too. Edit: Well the 2wd does....The 4wd has a different type of motor mount. |
03-04-2015, 08:49 AM | #443 | |
Traxxas rocks. J | |
03-04-2015, 09:34 AM | #444 |
I have a Castle 2400Kv sat waiting to go in the Sl4sh. It's nippy on the 3500Kv HW 4 Pole though so I have not put it in yet. Had to add some MIPs to the rear mind. The 2wd slash is even faster. Light so nothing heavy needed. Running a Castle SV3 with 5700kv....it is quick! |
03-04-2015, 12:01 PM | #445 | |
Holy crap...5700. I fried a CC4700 in my S42 in a single 100M full speed run once. Went back to my Traxxas 3500 and never changed it again. Now it's in an even lighter Bandit buggy. I'm entertaining a sensored 4 pole for my S44 but know if one will be an improvement over my Neu motor. I think the lack of a sensor in my current motor makes my on/off throttle attacks worse on my batteries than they should be. I'm gearing down a little to get some more stall torque out of turns. I used to run a CC2200kV in my S44 and it was too heavy and low kV. Batteries were not happy. Last edited by SkaldidDog; 03-04-2015 at 01:48 PM. | |
03-08-2015, 11:38 PM | #446 |
Newbie Join Date: Dec 2014 Location: Northern Ca
Scaldid: Where did you source the "flat cap...of 0.325" 7075"? Any particular part #?
03-09-2015, 09:26 AM | #447 |
| Re: SkaldidDog's "Buck-Nasty" Wraith |
03-09-2015, 05:52 PM | #448 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
Do you have any video of this beast moving?
03-12-2015, 07:45 AM | #449 |
05-02-2015, 03:26 PM | #450 |
Quarry Creeper Join Date: Sep 2014 Location: UK
In some early posts Rowdy asked you what the length of your Kyosho W5198V shocks were, eye to eye - did you ever measure them? I've read through the thread and couldn't see any dimensions...?
05-05-2015, 01:11 PM | #451 |
05-06-2015, 07:49 AM | #452 |
Fronts 3.7" Rear 4.3" (longest kyosho velvet) Hope this helps. J |
05-07-2015, 02:46 AM | #453 |
Yeah good man - thanks
05-09-2015, 10:20 PM | #454 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
Finally made it all the way through. Love your build and your your eyeball skills with the mill, very impressive. Keep up the good work. I know I learned a lot
05-11-2015, 09:30 AM | #455 | |
J | |
05-11-2015, 09:34 AM | #456 |
Another question about the shocks - I've ordered the same ones for my Yeti (46mm rear and 38 for the front), but I've only found a limited selection of springs for them on Amain.com. 3 spring rates for front and rear. Do you know of any other alternative springs either from Kyosho or otherwise that fit these shocks? thanks! |
05-11-2015, 01:07 PM | #457 | |
05-11-2015, 02:03 PM | #458 |
Excellent, thanks for that it's going to be extremely useful! Where did you get this list from??
05-12-2015, 10:39 AM | #459 |
05-19-2015, 05:48 PM | #460 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Awesome thread and awesome rig.. you got some talent, I got some good idea's and learned a lot from this thread, thanks. Didn't see anything about what your runnin on the pinions? Bearings or bushings? Stock 5x11x4? The power you have, you have to be destroying them. Or do you just swap out new bearings/bushings daily? On the rear lockouts, are you just runnin 4 bolts with no jb weld lookin stuff (cant remember what you called it)? Also, any updates on this beast? |
SkaldidDog's "Buck-Nasty" Wraith - Similar Threads | ||||
Skaldiddog's "Progress" | SkaldidDog | EnRoute Berg | 1181 | 12-11-2018 09:05 AM |
The "Nasty" Pajero!!!! | TattooKenny | Tamiya XC/CC01 | 40 | 11-30-2009 12:00 PM |
Wheres the "bang for the buck" tapping sets | TLTCrawlin | Tools, and Procedures | 13 | 01-04-2007 12:26 PM |
