Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Wraith
Thread: SkaldidDog's "Buck-Nasty" Wraith
Old 10-13-2012, 08:58 AM   #41
Default Re: SkaldidDog's "Buck-Nasty" Wraith
Thanks Joel - I've bookmarked their home page! What a selection of, stuff... I'm practically drooling, must contain slobber... mmmm, tools...
Cheers,
Todd
doc.hamilton is offline   Reply With Quote
Old 10-15-2012, 11:32 AM   #42
2013 2.2P Nat. Champion
SkaldidDog's Avatar
Default SkaldidDog's "Buck-Nasty" Wraith
Yeah man they rock. Since they are out of LA I get orders overnight for standard rate. Nuts. Beware ordering delrin sheet >0.250" in the warm months as it will likely be slightly warped when it arrives. A chronic problem with no solution I've found yet.
UPDATE:
Changed gearing to 15/56 and have found the sweet spot. I beat the shite out of it on hillclimbs yesterday and put 2+hrs on each MA 5420 3S. Insane runtime and tough as heck aside from the broken front bumper (custom one in the works). I have a Tekin RSPro and will evaluate but I don't think it'll take the heat like the cooled MMP will. We'll see. Switched chub hardware to black steel as the Ti with locktite kept coming loose. TSL SS's are the bomb. Pro4 motor never crossed 120 (85F and sunny out) and I was not being nice. Maxx shafts are show no signs of wear or stress. They are overkill.
J
SkaldidDog is offline   Reply With Quote
Old 10-15-2012, 12:44 PM   #43
I love the VP gray color. I plan on getting the same for my Wraith too.
KillerBlackbird is offline   Reply With Quote
Old 10-15-2012, 03:37 PM   #44
Joel,
Thanks for the update.
Say, how's the tranny housing and BWD engine plate holding up? I gather you did that as a preemptive? I've been acquiring pieces for my bombproof wraith - a Tekin 13.5 Redline w/MMP & RRP gears etc.
Cheers,
Todd
Old 10-16-2012, 01:28 PM   #45
SkaldidDog's Avatar
Cheers,
Todd
I build in overkill mode and often find it insufficient...not in this case. Tranny and motor plate are not going anywhere any time soon. Great stuff. Bearings are the weak link now. All RRP parts and CI outputs with the Maxx shafts leaves little room for failure. The slipper works really well. Crank it till you can't and back off 1/4 turn. I love the motor. Stays cool and sips mAh's due to the low gearing. Max Amps packs rock...2hr runtime of abuse!
J
Old 10-16-2012, 03:19 PM   #46
Yikes - 2hrs runtime, that's awesome! So bearings aren't quite up to snuff? I was going to get a wraith kit from fasteddybearings - is that a good kit?
Cheers,
T
Old 10-16-2012, 04:27 PM   #47
SkaldidDog's Avatar
Cheers,
T
T,
Bearings are up to snuff they are however a wear component while the others are not as much. Unless you spec ceramics, all bearings (Avid, FE, Boca etc.) will be similar $1 each chinese wonders.
J
Old 10-17-2012, 03:04 PM   #48
SkaldidDog's Avatar
Default Updates: SkaldidDog's "Buck-Nasty" Wraith
Hey y'all,
Just a couple shots of the final battery install. "Snug 'nads" as Beavis would say. No wiggling around under long tumbles downhill. From the underside you can see the battery resting on the carbon rod just above the spur shaft. The velcro straps are gooped to the rod so they stay put and don't require complete install each time. I did have to take 1" off of the battery wires to get the THCC to mate just between the velcro straps. Man this thing is a blast...the rare times I get to drive it. I still can't get over the hours per pack run time.
It ain't scay-uhl but it's cool as hay-uhl!!!
J
Old 10-17-2012, 03:36 PM   #49
Hey,
i put a third topshaftbearring in my gearbox...
works very well...
Greetings
Martin
mattin is offline   Reply With Quote
Old 10-17-2012, 04:06 PM   #50
SkaldidDog's Avatar
Originally Posted by mattin View Post
Hey,
i put a third topshaftbearring in my gearbox...works very well...
Greetings
Martin
Ooooooh dayuuuummm Good idea Martin. Gonna put that on the somethingtomakewhenImboredintheshopdrinking list.
J
Old 10-18-2012, 09:40 PM   #51
Joel,
Thanks for posting the detailed pics of your battery and electronics.
" the rare times I get to drive it". I know what you mean; too busy at work, kids, life in general. Just not enough time to get out and drive... (I did today at lunch) But hey, tomorrow's Friday just in time for MrM (martini's or manhattan's)
Cheers,
T
Old 10-19-2012, 01:57 PM   #52
SkaldidDog's Avatar
"Send wire, main office, tell them I said "ow"....nngotcha."
A Christmas eve classic during my childhood.
No. 6
Old 10-19-2012, 03:11 PM   #53
Its a HARDKNOCKZ Life...
HARDKNOCKZ's Avatar
I think I just pooped a little. Yup...I pooped.
As usual...sick work, machining is badass blah blah blah.
I'm sure I can fill the page with props but instead will leave it at...SICK. JUST PLAIN SICK!
HARDKNOCKZ is offline   Reply With Quote
Old 10-22-2012, 10:22 AM   #54
SkaldidDog's Avatar
Default Has anyone epoxied/JB welded chubs to axle housings?
Thanks JD.
Question to all: Have you tried JB weld/epoxy to attach aluminum hubs to aluminum axles. This weekend I put two additional screws on all four corners (chubs and lockouts) to stop the floppy slop. This is the only weak point of the rig I can find and I'm gonna fix it...dammit.
Thanks in advance.
J
Old 10-22-2012, 08:30 PM   #55
I'm slipping for sure. Must be that pesky old age creeping up on me... I need to watch it again. This'll date me, but it was the first R movie I saw. I was 11... good times!
Cheers,
T
No. 6
Old 10-22-2012, 08:43 PM   #56
Love the way you did your electronics looks clean.
Etmonta is offline   Reply With Quote
Old 10-23-2012, 01:18 AM   #57
D-Wray 4 Prez!
Frankenwheely's Avatar
Default Re: Has anyone epoxied/JB welded chubs to axle housings?
Thanks JD.
Thanks in advance.
J
Long shot here but what about silicone? JB weld/epoxy seems too permanent.
Frankenwheely is offline   Reply With Quote
Old 10-23-2012, 10:05 AM   #58
SkaldidDog's Avatar
For the chubs permanence is not a problem since they don't hold the bearings in. Only other downside is that the panhard mount is permanent as well. It's too late now. Both chubs are welded on nicely with 4 screws per chub. Can't do the rears because you need to remove the lockouts to change the bearings...that died by session 4 on the rig. I think my chub problems are gone. Will reassemble tonight and maybe test if I have daylight. If the rears continue to piss me off I'll mod the axles and make my own 7075 lockouts that are press fit with a separate bearing cap. We'll see.
J
Old 10-23-2012, 01:54 PM   #59
I have a lot of slop in the splines of my vp axles and chubs. I had stripped out 3 of the screws and ended up tapping them for 4mm buttonheads. Still don't trust the sloppy fit so I fill the gap with shoegoo. Not permanent and hold it nice and snug.
BurnLatex is offline   Reply With Quote
Old 10-23-2012, 02:08 PM   #60
Joel,
How much slop are you experiencing? I'm curious as I'm contemplating VP axles, chubs et al for a truggy build?
T
SkaldidDog's "Buck-Nasty" Wraith - Similar Threads
Skaldiddog's "Progress" SkaldidDog EnRoute Berg 1181 12-11-2018 10:05 AM
The "Nasty" Pajero!!!! TattooKenny Tamiya XC/CC01 40 11-30-2009 01:00 PM
Wheres the "bang for the buck" tapping sets TLTCrawlin Tools, and Procedures 13 01-04-2007 01:26 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
