Thread: SkaldidDog's "Buck-Nasty" Wraith
Old 09-13-2013, 08:57 AM   #101
2013 2.2P Nat. Champion
SkaldidDog's Avatar
Default Re: SkaldidDog's "Buck-Nasty" Wraith
Originally Posted by MotoSoul View Post
Looks good. I wish I had a hobby sized mill to work with. It takes forever to cut everything out by hand.
Been there done that mang. I feel you pain. Contrary to popular belief it does not build character.
J
SkaldidDog is offline   Reply With Quote
Old 09-13-2013, 09:50 AM   #102
That depends on how straight you can cut free hand. It might build character into the parts lol.
MotoSoul is offline   Reply With Quote
Old 09-13-2013, 11:42 AM   #103
MEOW
Natedog's Avatar
Default Re: Panharder mount
Originally Posted by SkaldidDog View Post
At Nats in Prescott last weekend I noticed my rig doing strange things with regard to steering. I noticed the panhard mount was loose so I tightened it up. Last night I again noticed it loose and this time looked closer. D'oh! Looks like I've been a little abusive. Such is evolution. So I spent an hour and made a new one from two layers of 7075 plate (0.125" total). I added beef along the transverse mount to further prevent a similar failure. Gotta give props to the VP mount. It was tough but I'm a 1%er when it comes to breaking stuff.
Enjoy.
J
Nice, I run axle mounted steering for strength and simplicicty...is there room to do double shear setup on yours? Looks like it might hit front axle truss on compression if you did.
Old 09-13-2013, 11:56 AM   #104
SkaldidDog's Avatar
It hits the truss. That's what broke it. The large hole that the chassis member goes through allows rotation around the LHS top screw and that snapped the transverse plate. I can live with it bottoming out now with the added strength. It bottoms on the rod end so it's plastic on metal which works OK. I like the look of the naked axle. It's a trade off. Next time I remove the truss I'll mill it off a little an install a butyl rubber bumpstop.
J
Old 09-13-2013, 12:43 PM   #105
One of these days when you aren't dominating the world of rock crawling, I'm gona get you to run a G6 with this thing......
Erin is offline   Reply With Quote
Old 09-13-2013, 12:53 PM   #106
SkaldidDog's Avatar
I'd love to but she just ain't scale and got no winch. Maybe I can work out a winch with some instruction.
J
Old 09-13-2013, 01:10 PM   #107
J
I just installed the VP CMS/Panhard and I have that issue as well. I am considering buying one of the aluminium versions and cutting it up for some more clearance. I think if you can loose the top mount screw (the one that goes into the pumpkin.) With that part cut off you can gain a few more mm of travel for the passenger side if ground down all the way across.
I don't think the plastic version would have enough meat left to supply though.
Old 09-13-2013, 03:01 PM   #108
SkaldidDog's Avatar
I thought about that too. I just filed the back corner off the truss end on the pumpkin and the rod end drops down behind it a little better now. If I get motivated I'll devise a work-around. But it's really not an issue.
J
Old 09-16-2013, 01:42 PM   #109
SkaldidDog's Avatar
Default Tranny bearings after one year...
I finally opened up my VP tranny after one year. The larger output bearings were worn but rotating nicely. The bearing on the spur shaft distal to the spur was worn but still usable. The idler bearins were brand new. I replaced them all but they all could have gone another 3-4 months.
Take home point...VP tranny is hard to kill and is great on bearings.
J
Old 09-27-2013, 08:32 AM   #110
SkaldidDog's Avatar
Default New Rear Clip
I've grown tired of the Rock Wagon look so I'm chopping off everything rear of the rear shocks and building my own rear clip. The bent piece is made of 6061 (because 7075 snaps) and the rest is/will be 7075. I lack welding skills and tools so this will be all mill, drill and screw assembly. It'll look clean and be stout. Got many days of work left.
I made some alignment blocks to help with some of the tricky hole angles down the road.
Junctions look nice and clean.
Overview of progress. Thats's a drill blank for alignment purposes.
Enjoy.
J
Old 09-27-2013, 11:06 AM   #111
D-Wray 4 Prez!
Frankenwheely's Avatar
So is this why you got the blue star? I'll take one.
Frankenwheely is offline   Reply With Quote
Old 09-27-2013, 12:47 PM   #112
TSK
Shelf queen
TSK's Avatar
Das kewl
Joel, I see you always mention running UD geaers front and rear. i'm actually building a Wraith as we speak. i'm running a RS & sensored 13.5t Redline on 3s.. I was planning on the OD/UD combo with it, but do you think I should just run stock ratios up front, as I still want a bit of overdrive fronts to help it crawl a bit better.
TSK is offline   Reply With Quote
Old 09-27-2013, 12:53 PM   #113
J
Its a wraith, scale enough in my book ;)
And the winch is simple, with all the cool stuff you've made, shouldn't be a challenge at all. You ever want some points, send a pm
Old 09-28-2013, 03:44 PM   #114
Was the jb weld the permanent fix for the front vp housing? Mine are whored out as well and are being held on my shoe goo and lock tite
FRENCHBLUE72 is offline   Reply With Quote
Old 09-30-2013, 07:54 AM   #115
SkaldidDog's Avatar
Default Cage Match
Originally Posted by TheSCorpionKing View Post
Das kewl
Give it a try. I'd like to know how it works for you.
Will do. Thanks.
JB weld was a permanent fix. Do it. You'll love it. Just let it set up 24hrs with a day in the hot sun and it'll never move again. Your panhard mount will be permanent if you run one.
Made some progress on my rear clip this weekend. Put about 16 more hours into it. Sloooooow going. Maybe another 10 and it'll be done. Lots of boring and tapping. Kocked out the cross brace that'll stop chassis twist.
My alignment blocks created artificial facets on the rod so I could align and drill properly.
More later.
J
Old 09-30-2013, 01:35 PM   #116
TSK
Shelf queen
TSK's Avatar
Nicely done. Looks real sturdy
Old 09-30-2013, 10:22 PM   #117
SkaldidDog's Avatar
Thanks man. I'm hoping it holds up.
Old 10-01-2013, 08:10 AM   #118
SkaldidDog's Avatar
Default Making progress...
Made a delrin jig to hold the cage in the appropriate orientation so I could drill the final holes to complete the equilateral triangle that is the core structure.
Success.
Shock mounting points turned out nice and clean.
Looking good but still several hours of work to go.
More later.
J
Old 10-01-2013, 11:24 AM   #119
Woooow
thats an awesome set of skills you have to do this so cleanly.
mad skills
Rock-Lockster is offline   Reply With Quote
Old 10-01-2013, 11:34 AM   #120
MEOW
Natedog's Avatar
Wow, very clean as usual.
SkaldidDog's "Buck-Nasty" Wraith - Similar Threads
Skaldiddog's "Progress" SkaldidDog EnRoute Berg 1181 12-11-2018 09:05 AM
The "Nasty" Pajero!!!! TattooKenny Tamiya XC/CC01 40 11-30-2009 12:00 PM
Wheres the "bang for the buck" tapping sets TLTCrawlin Tools, and Procedures 13 01-04-2007 12:26 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
