10-07-2012, 04:54 AM | #21 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
| Re: Solid axle Ultra4 build
Did a little more work on this one today. Made a rear firewall for it, will have to make more for the other Ultra4s. The RX and ESC are mounted on the center of the rear firewall. They fit inside the hump of the Wraith interior so they're tucked out of the way. Makes wiring a little easier as well. Aside from decals and maybe a light kit, it's pretty much ready to go. At least major construction/fabbing of parts is done and over with. Also got DTP's wrapped up tonight. He's running a Tekin RS Pro and a 3300kV Pro4. We turned the drag brake off with the RC4WD AX2 transmission. This allows for good jumps at speed in 2nd and the transmission holds the rig nice when crawling. We took both rigs out tonight and the IFS rig is just so much better at speed than the SA rig and it doesn't seem to have any huge weaknesses in the rocks. A comparison shot of the two. DTP's IFS rig has flipped lower shock mounts in the rear so the rear sits lower than the SA rig. Notice how the IFS rig has larger tires and still sits lower. Mean! The SA rig on the right is fun too. Just need to do some suspension tuning. Last edited by JasonInAugusta; 10-07-2012 at 04:56 AM. |
10-07-2012, 09:01 PM | #22 |
Quarry Creeper Join Date: Jun 2006 Location: Aurora, CO
I believe that lizard is a Crested Gecko. They're commonly kept in captivity and are fairly simple to care for, if you're interested in keeping it; Crested Gecko Care Sheet |
10-08-2012, 10:31 AM | #23 |
Newbie Join Date: Jul 2012 Location: crestline
Thas looks Bad a$$
10-08-2012, 02:26 PM | #24 |
RCC Addict Join Date: Aug 2007 Location: Burbank
Looks bad ass..........great job so far |
10-14-2012, 07:17 AM | #25 |
Three in the morning and I'm done. Got everything buttoned up and ready to go crawl with Badger tomorrow. The opening in the RTR interior turned out perfect for programming the Novak ESC. The "transmission shift lever" turns the ESC on/off. Opened up the headlights in the Dynamic Concepts Rubi body and installed a couple of lights from the stock Exo light bar. (I was out of the individual housings) Also notice the Carter Fab & Machine Ultimate Inner Fenders. I like how they cleaned up the front end. Looks even better with the flares on the DC Rubi body. Plucked some decals from the Wraith decal sheet, the Exo decal sheet, and from Traxxas and Parma sheets I had here. Rear shot. Shows off the Carter Fab & Machine centered Wraith axle. I removed the steering bits that I had on it from the IFS buggy. This rig won't ever see rear steer, it's just a go out and have fun ride. If you're wondering about the LEDs, it's a 3Racing kit. The orange LEDs in the center are on 100% all the time and the red LEDs are normally 50% brightness. Hit the brakes and the red LEDs go to 100%. I was hoping to have the new tires for this rig before we hit the rocks, but it looks like I'll have to wait until Monday. Last edited by JasonInAugusta; 10-14-2012 at 07:20 AM. |
10-14-2012, 12:17 PM | #26 |
Quarry Creeper Join Date: Dec 2009 Location: Honolulu
Looking good! The lights and rear end makes this rig stand out.
10-15-2012, 01:52 AM | #27 |
Pebble Pounder Join Date: Apr 2010 Location: Norway
Looks killer! Now we want some videos. :p
10-15-2012, 05:22 AM | #28 |
Some comparison shots. Ultra4 and a stock Wraith. |
10-16-2012, 12:41 AM | #29 |
Care package arrived from Pitbull tires. |
10-16-2012, 01:00 AM | #30 |
Nice! Got weight of Wraith vs your creation with same electronics, tires, and wheels for comparison?
10-16-2012, 01:08 AM | #31 | |
| Re: Solid axle Ultra4 build Quote:
This blue SA rig is 7lbs, 8oz RTR as pictured. My IFS rig is 9lbs, 1oz RTR. That's with two batteries (Thunder Power 5400mAh 2S and TP 850mAh 3S, four servos, two BECs, Pro4, RX8... | |
10-16-2012, 01:19 AM | #32 |
Your IFS front, solid axle rear rig rtr minus battery versus stock Wraith rtr minus battery. |
10-16-2012, 01:29 AM | #33 |
| Re: Solid axle Ultra4 build |
10-16-2012, 01:35 AM | #34 |
| Re: Solid axle Ultra4 build Just weighed the batteries in my IFS rig. 13oz. That puts the RTR weight of my IFS rig at 8lbs, 4oz. and it will shed weight soon. Swapping the seats out for a set from Team3six.
11-24-2012, 01:39 PM | #35 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
How are you liking those Rock Beasts, hooking up well?
11-24-2012, 05:49 PM | #36 |
Went crawling with it and my wife was taking all the hard lines and taking about how easy it was to just "point and shoot". They hook up very well. Wet or dry. I put some random foams (from RC4WD 2.2 TTC Bajas, I think) and she loved how easy the rig was to drive. |
11-24-2012, 06:56 PM | #37 |
RCC Addict Join Date: Sep 2011 Location: Peoria, AZ
Man!! those wraiths look Bad ASS and those Pit bulls also look sweet nice work... |
11-24-2012, 10:30 PM | #38 |
If one was to take on a project like such, Would this be all I need? Axial EXO Cage Passenger Side AX80114, Terra Buggy | eBay Axial EXO Cage Driver Side AX80113, Terra Buggy | eBay Axial AX80109 Cage Center Rear EXO | eBay Axial Rear Light Bezel/Radiator Set EXO AXI80103 | eBay NEW Axial Aluminum Rear Shock Tower Brace Set EXO (2) AX30802 | eBay Also where could I get the lenses for rear light bar? Thanks for all the help! |
11-24-2012, 10:45 PM | #39 | |
I've got the parts list for the conversion here somewhere, will have to dig it up. | |
11-25-2012, 11:28 PM | #40 |
Solid axle Ultra4 build - Similar Threads | ||||
Solid axle prerunner 1st build | koltkarle | General Scale Talk | 3 | 03-01-2012 09:37 AM |
New member with CC01 solid front axle build | BigSwede | Tamiya XC/CC01 | 29 | 02-02-2011 02:33 PM |
Solid Axle Short Course Build | sourdojack | Non Crawler RC's | 6 | 12-01-2009 08:37 PM |
My Solid Axle Build Up | standupjetskir | Traxxas Crawlers | 27 | 01-17-2006 09:18 AM |
