Thread: HD Differential gears binding.
Old 10-19-2012, 10:15 PM   #1
Default HD Differential gears binding.
So, I just got HD gears for my axial wraith and scx10, and they seem to start getting stuck to each other. On the wraith in the middle of a run it completely jammed, and would not spin at all. On my scx it has the same effect, where it doenst spin smoothly like it should. Any suggestions, am i doing something wrong?
sullivanscx10 is offline   Reply With Quote
Old 10-19-2012, 10:24 PM   #2
Scale Detail Engineering
Default Re: HD Differential gears binding.
Try removing the gasket between the locker and ring gear.
Or bad bearings?
johnnyh66 is offline   Reply With Quote
Old 10-19-2012, 11:23 PM   #3
You got enough lube in there? A nice marine grease works good. Otherwise not sure what could cause the jam. Are things all nice and aligned and carrier holders tight.
ZippoMan is offline   Reply With Quote
Old 10-20-2012, 12:22 AM   #4
Make sure you didn't install the diffs backwards. That will tend to cause binding issues . Check your manual and pull off the diff cover, look at what side the ring gear should be on. Flip around if needed
MeadowMuffin is offline   Reply With Quote
Old 10-20-2012, 12:47 AM   #5
I actually had this same prob with a set i got for a scaler and come to find out they where defective. the teeth where to long and the actually diff was too thick making it impossible to use them because of the binding.
2006Shelby is offline   Reply With Quote
Old 10-20-2012, 10:43 AM   #6
Wow defective! That is a bummer. I guess Axial has quality control issues! They have had many problems in general...little ones but when added up they are BIG!! It sucks.
Old 10-20-2012, 11:54 AM   #7
Alright i dont think its a defect, but just to give an example i will make a video
Old 10-21-2012, 12:43 AM   #8
Here you go Axial HD diff gears binding - YouTube
Old 10-21-2012, 12:48 AM   #9
Did you install the correct pinions ?? UNder drive to under drive and overdrive to overdrive,? 14T in front and 13 tooth in the rear....
scottanthony is offline   Reply With Quote
Old 10-21-2012, 12:40 PM   #10
Well i have the same gears and ratios in front and back, would that make a difference?
Old 10-21-2012, 03:05 PM   #11
I also notice that is not a Wraith.....might wanna ask in other sections..or did ya??
That is a bizarre situation you got going on.
Old 10-21-2012, 03:59 PM   #12
OP.. do the diffs sit nice and snug in the axle? the caps aren't stretched are they?
And what brand did you buy? Hot Racing or Axial?
This is what I was initially thinking... but in all reality diff orientation really shouldn't have an affect on anything as the front is the rear switched and vice versa.
monkeymagic9 is offline   Reply With Quote
Old 10-21-2012, 05:18 PM   #13
The gears are all going in the right direction, the lockers are made by hot racing and the gears them selves are made by axial.
Old 10-21-2012, 06:11 PM   #14
How about the diff holders? Are they stock plastic or upgraded aluminum? I use STRC diff holders. STRC STA80070BK Alum Internal Diff Holders Axial Wraith
Old 10-21-2012, 07:16 PM   #15
I would remove the rear section of the case so you could spin the yolk and witness the ring gear spinning. If it spins free, move to see why it binds when put together. If it happens when apart you should be able to feel/see it happening.
Propane is offline   Reply With Quote
Old 10-21-2012, 07:38 PM   #16
i will try that, and let you know if it works
Old 10-21-2012, 07:49 PM   #17
Old 10-21-2012, 08:15 PM   #18
Are your ring screws flush with the ring? I know on mine they are not because I am using cap heads and they stick up a bit. I was worried about clearance issues but so far mine are awesome!!
Old 10-22-2012, 06:34 AM   #19
i can see the crown wheel screw heads prodruding in that pic. how close do they come to the cap and housing?
forbnmad1 is offline   Reply With Quote
Old 10-22-2012, 08:00 AM   #20
they are pretty close, but i dont think they hit.
HD Differential gears binding. - Similar Threads
Differential Gears tecboy Axial AX-10 Scorpion 12 02-06-2010 11:15 AM
Differential gears for a SCX-10 shambrick Axial SCX-10 10 12-12-2009 04:09 PM
Metal or alloy tranny and differential gears??? illz302 HPI Wheely King 3 08-20-2009 03:24 AM
