10-21-2012, 05:31 PM | #1 |
RCC Addict Join Date: Nov 2010 Location: nashville
| KJ's Heavy Chevy"
Rebuilding one of my favorite truck so I figure I'll piggyback of the original thread New build Wraith chassis with dc blazer body. Bgr front shock towers Bgr rear shock towers Bgr koh custom rear cage Front axles-Beeftubes, overdrive hd gears ,locked up spools, axial universals, vp c-hubs, vp knuckles, strc shock/lower link mounts, strc bearing cap, vp diff covers, vp steering links, vp truss, vp panhard Rear axles-Beeftubes, underdrive hd gears, locked up spools, vp lockouts, vp truss, strc shock/lower link mounts, strc bearing cap, vp diff covers Built trans-hot racing metal gears and aluminum case and dmg trans spacer Vp Kmc 795s with .600 hubs Custom cut Proline tsl xls with ci dueces wild custom foams Mmp Castle bec Hitec 7950 @ 7.4 volts Pro4 4600 geared 11/56 vp titanium links Custom wraith/summit Mips Interior with recaro Seats Gmade piggyback shocks. 93mm/103mm Duuuuuude front and rear link risers Scale accessories Dc blazer body Vp limiting straps Rc4wd inner fenders original build from a couple years back I started Building this a week ago, just havent been able to use a cpu to post it up on here parts list Wraith chassis Axial wraith axles Hr knuckle Hr c-hubs Hr diff covers Vanquish Cms Vanquish Panhard Hr metal trans gears Robinson Racing hd trans outputs Axial HD overdrive gearing Axial HD underdrive gearing Axial cvd's 2.2 Mayhem remachined monsters 2.2 Proline Tsls Mmp Castle bec Novak 17.5 ss motor Jr 9100 servo Wildboars shafts Dynamic concept blazer body Recaro seats. Diny's drop box how i got it got to test this beast out yesterday and it did awesome, easily the best crawler ive ever owned, and its not even done yet lol i was the only one to climb this stump hiding in the woods almost strait vertical crazy flex poser shot got pulled over by car Ram-rod tight squeeze Last edited by King James; 12-01-2014 at 02:23 PM. |
10-21-2012, 05:46 PM | #2 |
Quarry Creeper Join Date: Aug 2012 Location: Nebraska
| Re: KJ's Heavy Chevy"
Great looking rig there jimmy.
10-21-2012, 06:03 PM | #3 |
Thanks man, I got the wraith bug again as soon as I sold my axles and had to build another set.
10-21-2012, 09:23 PM | #4 |
Newbie Join Date: Feb 2010 Location: fullerton
What shocks are you running? Looks great man.
10-21-2012, 09:53 PM | #5 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: KJ's Heavy Chevy" |
10-22-2012, 07:11 AM | #6 |
10-22-2012, 07:15 AM | #7 |
10-22-2012, 07:29 AM | #8 |
RCC Addict Join Date: May 2008 Location: Southern,WV
10-22-2012, 11:53 AM | #9 |
Hey jimmy....I was thinking about getting this body.Do you like it? Does it fit ok or do the tires rub a lot? And do you think it could be made to have a opening hood? Thanks in advance.
10-22-2012, 12:39 PM | #10 |
I like it better that the dynamic concepts jeep body I had on my first wraith, just because its one piece, I've seen some Modded to have a opening hood, I'm going different route withthis one, its gonna have a hinge up.front that'll allow the while body to swing up after removing 4little screws.
10-22-2012, 12:45 PM | #11 |
Front rubs a little but I'm using narrow hubs on the mayhems and its got a low stance. Doesn't rub enough to negatively effect anything
10-22-2012, 02:48 PM | #12 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
damn that paint is killer! tamiya copper? i want a narrower stance on mine i think i have the .650 hubs on my monsters, whats the narrowest hub mayhem has or i can use on my monsters? |
10-22-2012, 03:07 PM | #13 |
ive got the .450 hubs and will probably swap to the .650 or .750(whichever is just sitting on my buddies work bench), they look great but the do rub a little the color is a Pactra Polycarb Fiery Orange started with atomic rust on the inside then silver then black, then i removed paint mask and hit the outside of the body with a silver coat and finished with the fiery oranges, so hopefully the more it gets scrathed, the more old and rusted itll look |
10-22-2012, 04:41 PM | #14 |
look great bro, i think ill try that on my rubi body im getting for my wraith, nice trick, pretty crafty |
10-22-2012, 04:46 PM | #15 |
10-22-2012, 05:10 PM | #16 |
Lol I always trim less than I need like about 1/2" from the actual body line and paint a little extra then fine trim afterwards lol Sent From Outerspace Using my HTC-Freeze Ray Gun |
10-22-2012, 05:12 PM | #17 |
Quarry Creeper Join Date: Nov 2011 Location: Cookeville
Seen this beast in action and yes it is so wicked and looks awesome he did a great job on this thing.
10-22-2012, 05:25 PM | #18 | |
| Re: KJ's Heavy Chevy" Quote:
That's definitely needed with the dc jeep body, it looks real nice if done right | |
10-22-2012, 05:27 PM | #19 |
10-25-2012, 08:13 AM | #20 |
Dinky drop box is on the way for it, also set up a different grill and mounted the recaro seats for this weekend run.
KJ's Heavy Chevy" - Similar Threads | ||||
KJ's JK "Black Beast" | King James | 1.9 Scale Rigs | 115 | 04-20-2013 09:07 AM |
KJ's XJ "The Chief" | King James | 1.9 Scale Rigs | 31 | 09-07-2012 08:29 AM |
KJ's "The Incredible Hulk" | King James | Large Scale Rigs | 5 | 09-07-2012 03:34 AM |
4link bruiser "heavy Chevy" | dankycrawler | 2.2 Scale Rigs | 8 | 12-13-2006 05:15 PM |
