11-05-2012, 08:21 AM | #1 |
Newbie Join Date: Sep 2011 Location: Toronto Ontario Canada
| Project Ninja- KOH IFS Wraith
I was inspired to do this build after I saw JIA's build so at first I turned to him to build mine. Just after I ordered my Exo Terra Kit, my 1:1 had to go into the garage to get fix which made short of the $250 needed to pay JIA for the build so I have to do it myself with alittle help from the guys over at Pinnacle Hobby here in Toronto Canada... Parts List so far: Exo Terra Kit Exo Terra Front CV Kit Wraith Cage RC4WD AX2 2 Speed Transmission RC4WD Aluminum Centered Axle RC4WD Aluminum Shock/Link Mount Ballistics Fab Diff Cover Gmade Wraith Drive Shafts Blue Monkey R/C Delrin Suspension Links and Revo Rod Ends Traxxas VXL 3S and 3300kv BL Waterproof ESC and Motor Savox 1256TG to be Plasti Dipped ALOT of screws! More to come! Last edited by XterraTrax; 02-11-2013 at 12:32 PM. |
11-05-2012, 08:23 AM | #2 |
| Re: Project Overkill - KOH IFS Wraith
So I have already gotten started on the project so this is what I have so far done (which is quite a bit) I got all my stuff from Pinnacle Hobby tonight and ordered all the screws for the cage...there are 50+! Love the box art BTW! Smells like good old Axial Factory Plastic mixing with factory air! Found an Assault Rifle in the parts tree! Even though I am not using the tires...I have to point out how realistic they are! All the plastics that complies the cage! Awesome Diff Cover reminds me of the one on the 1:1! |
11-05-2012, 08:24 AM | #3 |
Got this in the mail today. Its the RC4wd Centred Rear Axle and Aluminum Shock/Link Mounts. Still waiting for the the links to come. Somehow I got my links today so the build begins! |
11-05-2012, 08:25 AM | #4 |
I got the front end almost wrapped up but then I was missing 10 screws so gotta run to the LHS to get some tomorrow. Also got some concerns... For here is some pics.... My set up: Keeping open diff in the front to see how that goes might lock it. Heres how it looks assembled... Diff Case put together with alot of Marine Grease! Front End Done... One of my concerns is that the set screw holding the Pins is stressing the plastic...going to strengthen that with CA This set screw doesn't hold the suspension pin in very well...also the plastics very soft so I don't want to strip the hole... |
11-05-2012, 08:25 AM | #5 |
Got more stuff from Pinnacle Hobby yesterday and I had sometime to do more stuff today so here it is! First up is I got a servo for the beast which is a Savox 1256TG that I will be Plasti Dipping. Also got the Front CVs, Lockers for the Wraith and 50+ Screws CVs all assembled and coated with Marine Grease... The screws the kit provides for the steering rack as you can see so I switched them for some longer ones. (Short one are left and new one are right) The front is all done and this is all I am using out of the Exo Terra. Only other thing I am taking is part of the cage. Wraith Cage almost fully assembled...putting the halfs together... Cage assembled and place on the Exo Terra. This is the ROUGH location of it and obviously I need to cut the Exo Terra chassis. I think its going to be awesome! |
11-05-2012, 08:41 AM | #6 |
Quarry Creeper Join Date: Apr 2011 Location: Grillin & Chillin
Bud I'm so glad your doing this im wanting to do the same an didn't have a clue of how to do it keep up tha good work
11-05-2012, 08:51 AM | #7 |
Rock Stacker Join Date: Apr 2009 Location: topeka
Looking good so far! I'll be checking progress on this one
11-05-2012, 02:49 PM | #8 |
11-05-2012, 03:45 PM | #9 |
Quarry Creeper Join Date: Dec 2011 Location: Fayetteville, AR
Loving this. You should look into BGR Fabrications' KOH Sport Roofcage - would look badass on there. Fink |
11-05-2012, 06:05 PM | #10 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
Project overkill? Is this going to have 4 motors, dual transmissions, dual receivers and a stretched chassis? Lol
11-05-2012, 06:48 PM | #11 |
| Re: Project Overkill - KOH IFS Wraith Took me a second there but I just realize what your saying! I by accident named this project after Medics project! whoops! Don't think I will change it unless I can think of another name! |
11-05-2012, 09:39 PM | #12 |
DJ Medic FTW! Go Alberta go!
11-11-2012, 01:34 PM | #13 |
Quarry Creeper Join Date: Oct 2011 Location: Livermore Ca.
I started this and sold it a couple months ago... The Wraith cage will line right up to the EXO belly pan holes if you cut the lower cage off. It will give it a lower profile as you can see if you like that. I had alot of idea's on this build but got too many stacked up on other Wraiths I have so I sold this one. Nick |
11-12-2012, 05:37 PM | #14 | |
| Re: Project Overkill - KOH IFS Wraith Quote:
Anyways UPDATE! Got more stuff today. Gotta find more time to work on the project! | |
11-13-2012, 04:09 PM | #15 |
Gotta little box in the mail...I wonder what it is? Its a my ESC back from warranty... |
12-25-2012, 12:48 AM | #16 |
Ok so I have been quite busy lately and I have been waiting for parts. First off, I got my 2 speed which came in this awesome little box... Sooo finally here it is! Merry Christmas to Me! I also got some progress done on the project itself and currently the whole thing is off to get the chassis cut and milled. I assembled the RC4WD Centered Rear Axle...great quality BTW... I also used Axial's HD gear set in the rear.... Used this to pack the axle tubes with marine grease...quite messy method though The guts all installed and slathered with Marine Grease.... Links all attached and figure out for that matter....lol |
12-25-2012, 03:35 PM | #17 |
Pebble Pounder Join Date: Feb 2012 Location: Riverside
Looking forward to this build!
12-25-2012, 11:44 PM | #18 |
Rock Stacker Join Date: Sep 2012 Location: canton, ga
I would love to do a build like this. so you cut the exo terra bottom plate and then screw the wraith cage into it? anyways it is interesting.
12-26-2012, 03:51 AM | #19 |
Pebble Pounder Join Date: Jul 2008 Location: 808
looking good! ive seen a few built just like this and they perform very well.
12-26-2012, 10:41 PM | #20 |
| Re: Project Overkill - KOH IFS Wraith |
Project Overkill - KOH IFS Wraith - Similar Threads | ||||
JIA's IFS KOH Ultra4 Wraith Conversions | JasonInAugusta | Chassis and Suspension | 77 | 11-10-2012 10:27 PM |
CC-01 IFS KoH Buggy | tHeo | Tamiya XC/CC01 | 6 | 10-29-2012 02:18 PM |
IFS KOH Rig | bigtiresrbetter | Large Scale Rigs | 7 | 01-26-2011 12:49 PM |
1/6 CAMPBELL KOH IFS RIG all stainless | gadge | Large Scale Rigs | 32 | 07-17-2009 09:43 PM |
