Thread: Hot bodys sway bar kit, does it work??
Old 11-05-2012, 01:01 PM   #1
Default Hot bodys sway bar kit, does it work??
Do you loose some or alot of articulation running it, the rig I'm building might get to much body sway so I might need to run one front and rear. I just don't want to loose the travel. It will weigh about what a
Wraith does maybe a little more.
The Doc is offline   Reply With Quote
Old 11-05-2012, 01:35 PM   #2
Default Re: Hot bodys sway bar kit, does it work??
I've used the Axial kit in the front of my wraith (with the softest bar installed) and the difference is comparable to running a 1:1 completely discoed vs an AntiRock. Some travel is lost, but it will feel quite a bit more stable.
JeremyH is offline   Reply With Quote
Old 11-05-2012, 01:51 PM   #3
BTW, you could always use different OD's of rod (just cut and flat spot them) to adjust the firmness of the sway bar. The axial one comes with three, but I couldnt imagine using the medium or firm bar in there...
Old 11-05-2012, 02:17 PM   #4
Thanks, I'll see if I can find spec's on the axial ones and compaire them to the HB weigh ratings.
Hot bodys sway bar kit, does it work?? - Similar Threads
Sway bar kit ax10tn Axial Wraith 3 01-03-2012 04:21 AM
sway bar muddeprived General Crawlers 9 09-12-2007 09:57 AM
