12-25-2012, 01:28 PM | #21 |
Rock Stacker Join Date: Jan 2012 Location: SK, Canada
| Re: Scale Wraith KOT style
I'm speachless. This thing is just soooo cool, and such attention to scale detail so far, I love this build! It's making me think of redesigning my Wraith! Keep us updated buddy! |
12-25-2012, 03:40 PM | #22 |
Rock Crawler Join Date: Oct 2011 Location: Canada
Subscribed for the hydraulic steering.. looks like it will be incredibly awesome, or super finiky and never work right for more than 2 minutes. My kind of project!!! Love it!
12-26-2012, 02:11 AM | #23 |
Rock Stacker Join Date: Jul 2008 Location: Austria close to Vienna
| Re: Scale Wraith KOT style It must be a well working steering system. These kits are proven a thousand times in trucks, excavators, loading cranes, dump trucks, wheel loaders, etc. They usually working without fail. |
12-27-2012, 08:01 PM | #24 |
Quarry Creeper Join Date: May 2012 Location: Baja, Mex / Calexico, Ca.
this things looks sooo good!!! love the 1.55 wheels |
12-27-2012, 08:54 PM | #25 |
Rock Stacker Join Date: Oct 2012 Location: dfw
Nice wraith man!! You gotta post up a video of that steering in action love the scaleness of it
12-28-2012, 02:13 PM | #26 |
Certainly I will post videos when ready.
12-28-2012, 02:57 PM | #27 |
RCC Addict Join Date: Nov 2006 Location: burlington
this is coming out great. the new wheels look alot nicer on it over the walkers. the hydro is putting this over the top. it looks close but is there any chance that the rod ends on the shafts of the shock and ram can be swaped. so the ram does not have to be perfectly level throught its cycle in and out. |
12-29-2012, 11:15 AM | #28 |
| Re: Scale Wraith KOT style Quote: |
12-29-2012, 11:20 AM | #29 |
Rock Crawler Join Date: Aug 2011 Location: Kingsland, GA.
cant wait to see where this goes.
12-29-2012, 11:34 AM | #30 |
Quarry Creeper Join Date: Dec 2011 Location: The land of snow
sub'd to this... what an awesome build
12-30-2012, 02:38 PM | #31 |
| Re: Scale Wraith KOH style
Little changes been done. Put the aluminum skid on, made a mount for the steering cylinder, cut the cockpit rear section which will hide all the hydraulik stuff such as motor, tank, control block and electronics. Changed the rod end of the cylinder to a RC4WD shock end. The cylinder mounts directly to the 4-link bracket. The position of the 4-link bracket is just perfect for mounting the cylinder. I used RC4WD scale screws. I did a quick mockup with tires to have a better imagination about the size of the cylinder. Going to make a test run of the hydraulic system this week hopefully. The hydraulic hose to the cylinder will be a smaller one later than this on the picture. |
12-30-2012, 06:13 PM | #32 |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
Wow! will be following this |
01-02-2013, 11:57 AM | #33 |
Put everything together today and made a test-run. Steering works fine. Just need some fine adjusting of zero-point and a o-ring needs to be replaced. It is leaking at the tank from return hose. That is why hydro-fluid starts frothing. More to test in the field later when everything is ready to fix hydro-system into chassis. Another point, pump, motor and tank is getting very warm. I need to make a cood cooling system. Here some quick pictures. And here is the video Hydro-Lenkung.MOV - YouTube Sound will change once it is built in. It is because it is laying on aluminum cross members. Last edited by ThomasR; 01-02-2013 at 12:04 PM. |
01-02-2013, 12:17 PM | #34 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
Watched the vid very cool. How's the response time of the ram? Quick?
01-02-2013, 12:51 PM | #35 |
| Re: Scale Wraith KOT style You mean from turning the wheel on the sender to movement of the ram? Well it is a little delay in it because the micro servo turns the valve and then the ram gets impule to move. But it is okay as it is a slow model. Once you are used to it it is fine.
01-02-2013, 01:36 PM | #36 |
Newbie Join Date: Apr 2012 Location: Alma,mi
Thats cool.
01-02-2013, 10:09 PM | #37 |
Newbie Join Date: Sep 2012 Location: In a House
Man that thing looks tough, have u used the hydraulic steering on anything else? How does it perform?
01-03-2013, 01:20 AM | #38 |
| Re: Scale Wraith KOT style This is the first try to make a working hydro steering. Performance is as can be seen on the video but have not tested it off road yet. What I learned is, it is pretty fast.
01-03-2013, 12:33 PM | #39 |
| Double post edit
01-03-2013, 12:35 PM | #40 |
| Exactly. I bet it's strong though. Should sort out any weakness quick.
Scale Wraith KOT style - Similar Threads | ||||
Racing Style Wraith | RcStud5 | Axial Wraith | 15 | 10-01-2012 08:19 PM |
Island Style Wraith | guahan911 | Axial Wraith | 10 | 05-29-2012 12:58 AM |
KoH style Wraith | Mad4Rnr | Axial Wraith | 60 | 04-14-2012 05:13 PM |
My Ultra 4 style AX/Wraith | jeepinkid83 | Axial Wraith | 36 | 02-27-2012 09:32 PM |
