01-03-2013, 06:13 PM | #41 |
Pebble Pounder Join Date: May 2011 Location: under a bridge
| Re: Scale Wraith KOT style
That hydro set up let alone the 1.55 set up is WOW! Awesome job!!!!
01-16-2013, 04:49 PM | #42 |
Rock Crawler Join Date: Nov 2012 Location: Charlotte
Very cool hydro system. What's your opinion of the stubby bumper and winch on the wraith? I've been considering that very direction. |
01-17-2013, 12:07 AM | #43 |
RCC Addict Join Date: May 2008 Location: Southern,WV
Does it self center?
01-17-2013, 01:38 AM | #44 |
Newbie Join Date: Nov 2010 Location: brisbane
how strong is it ? you don't seem to get much steering angle ?
02-11-2013, 02:45 PM | #45 | ||
Rock Stacker Join Date: Jul 2008 Location: Austria close to Vienna
| Re: Scale Wraith KOT style Quote:
Nope. Just as a real car does not either. It is now really scale by all means Quote:
Today I can presend some minor progress. I made a rear bottom plate with mounting of the hydro pump and filter. After some experiments with different materials, I have chosen 0,8mm steel plate. Easy to work with and best heat absorbing. Because the pump will become quite hot when running. Have to recut the metal sheet at the shock section and a storage compartment will be made either of steel or styrene. | ||
02-11-2013, 03:18 PM | #46 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
I built a hydro steer rig in 2004 with two cylinders per axle because the cylinders are stronger when extending than retracting. With two per axle I had a constant force in both directions. I used all Leimbach stuff as well. If you need help to get it to work properly let me know. There's a really simple way to locate your mounting point (at the axle) for the hydro cylinder. Just get a compass, turn the knuckle in one direction, measure the eye to eye of the cylinder (either fully retracted or fully extended) for that direction, and set your compass to that measurement. Swing an arc on your mounting material at the axle. Repeat the process for the other direction. Where the two arcs intersect is THE point to mount your cylinder. That will give full steering with full cylinder movement. Basically setting EPA for the cylinder. Also, keep an eye on that clear cap/window for the reservoir. I had two of those crack on my rig and the res was well protected by the cage. I think temperature played a role in the cracking. Also, Ric Murphy at gardentrucking.com (for those of us in the US) can hook you up with a return-to-center setup for your rig if you want it. Down side is that you'll only have full left/right, not proportional control. Last edited by JasonInAugusta; 02-11-2013 at 03:23 PM. |
02-11-2013, 08:49 PM | #47 |
| Re: Scale Wraith KOT style My hydros self center on my 1:1.In fact all of my buddies do too. I know a cars doesn't but your setup isn't like a cars. Not even close. It's more like hydro steering. That's why I was wondering if is self centered.
02-11-2013, 11:24 PM | #48 |
| Re: Scale Wraith KOT style Okay. But real cars only self center when driving, not while standing. Rc cars self center also while standing (servo). But basically you are right, no self centering in the Wraith. It is theoretically possible, but not nesessary for a slow crawler.
02-12-2013, 01:12 PM | #49 |
| Re: Scale Wraith KOT style Got ya....Your going to be going slow so no need for it....Maybe after you run it awhile you might give it a shot. I know before mine on my 1:1 did it drove me crazy constantly turning the wheel.....lol
02-12-2013, 04:48 PM | #50 |
RCC Addict Join Date: Aug 2012 Location: Philippines
Following. Very interesting. |
02-13-2013, 03:19 PM | #51 |
| Re: Scale Wraith KOT style Lol.... I can imagine. Problem is really the endpoints. There is no way to tell the hydro-system the actual position of the piston. For wheel loaders with articulated steering cor instance, Leimbach does have electronic to center steer. We'll see.
02-13-2013, 04:25 PM | #52 |
| Re: Scale Wraith KOT style Ours is ran be a computer type box.It has sensors inside the tube letting it know where the piston is at. But then again I'm talking about a 6,500 setup too......lol
02-18-2013, 01:36 PM | #53 |
Just a little progress. Some styrene work. I started the hydro-set compartment. Will be alot more work still. Also next step is to cut the rear floor and attache the winch and fairlead and start the rear storage compartment. naked |
02-19-2013, 07:26 AM | #54 |
Today I was cutting the rear floor to match the shape of the rear compartment and make space for the shocks. Just a raw cut. After little afterwork and filing and grinding. Fairlead for rear winch fit into rear section. Now started with the styrenework for the rear compartment. Hope I can post some progress soon. |
02-19-2013, 07:34 AM | #55 |
Looks pretty sweet. Can't wait to see what it looks like finished.
02-19-2013, 07:38 AM | #56 |
Rock Stacker Join Date: Jan 2013 Location: St George
The hydro steering is a awesome idea. This is one of my favorite builds. I can't wait to see what else is store.
02-19-2013, 08:56 AM | #57 |
Thanks all for your positive comments. That cheers me really up!
02-22-2013, 01:19 PM | #58 |
Spent another some hours to modify the cockpit and to start the front compartment for the battery and the electronic parts. First felt like 237 times measuring and crosschecking if everything will fit as I planned. The compartment must be removeable by taking away just the three front crossmembers in one piece. First start with the base. Drawing, cutting, sanding until it fits. Made a small bend to have a nice angle towarts the nose. Snug fit as planned. Measured the max. hight and then cut the side walls. Firewall installed. Will modified further. Sidewalls glued together. The whole box is fastened by 4 screws. I use the stock mounting points where the radio box holder is in place usually. This makes the whole construction very stiff and can take quite a load. Cutting down the sidewalls and cut out for the crossmembers. Also make place for the front part with the lights. Fits all perfect. Fully compressed. Enough space to the bottom. With the side panels. Next I will make a battery holder and a cable duct under the battery into the cockpit and for hydraulic system and for all lighting. Also the box will be closed from all sides and final grinding for smoother look. Will be painted black. Also I decided to use the stock hood instead of the aluminum one. Doesn't like the angled look. |
02-22-2013, 01:29 PM | #59 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
Absolutely stellar work. Good Job!
02-24-2013, 07:22 AM | #60 |
Yesterday I've made some little progress. - battery holder and cable duct - firewall - cockpit reinforcement and tranny tunnel This is the baddery holder which also acts as a cable duct Cut some small parts to fill the gap Test fit - perfect. Draw contures of the battery and cut them out and glue them in. Reinforcement of the firewall to stand the heavy battery. The angled cross members also support the tranny tunnel. The footwell area which closes the nasty gaps to the fire wall. Also gives more stiffness to the tranny tunnel. Today I cut the floor plate rear section to fit the shape of rear compartment. Some additional supportplates and holder for the rear section of the cockpit ware made. Now I will start thinking about electronic components. How and where to install each. Also at last following steps to do: - Hoodmodification - Safty tank which also carry a battery - painting all the parts - install all hydraulik and correct lenghts of tubes. - various scale accessorie ..... and maby much more... |
Scale Wraith KOT style - Similar Threads | ||||
Racing Style Wraith | RcStud5 | Axial Wraith | 15 | 10-01-2012 08:19 PM |
Island Style Wraith | guahan911 | Axial Wraith | 10 | 05-29-2012 12:58 AM |
KoH style Wraith | Mad4Rnr | Axial Wraith | 60 | 04-14-2012 05:13 PM |
My Ultra 4 style AX/Wraith | jeepinkid83 | Axial Wraith | 36 | 02-27-2012 09:32 PM |
