Thread: Ar60 and VP 60's home made skids
Old 11-24-2012, 09:50 AM   #1
Default Ar60 and VP 60's home made skids
Hey homies ! First off I know this isn't a wraith but the axles are the same type as those in a wraith. Well at least the center section is! I made these skids for my honcho that uses Vanqish housing. Since they are the same as the Wraith center sections so I thought I'd post these here. I made these to protect that fresh aluminum and to keep from hanging up on the ARB diff covers. Any way check em out!
I started by cutting a strip of metal about 6.5 mm x 90 mm. I cut that into 4 pieces with angles close to 45* on the bottom edges with a 1/8 hole drilled into the top. They didn't have to be perfect because once I screwed them all on I just put the housing with tabs on a table belt sander and flushed them with the bottom of the case.
Then I took a piece of metal cut as wide as the four tabs mounted and with a 45* bend and tacked it to the pieces that I had made.
Then I took it off and finished welding, cleaning and painting it.
I also put a bend on the driveshaft side of the diff.
Here are a few finished result pics!
Jeepfixer1 is offline   Reply With Quote
Old 11-24-2012, 10:41 AM   #2
Default Re: Ar60 and VP 60's home made skids
Sweet, who makes those link/shock attach points?
benmara is offline   Reply With Quote
Old 11-24-2012, 11:56 AM   #3
Vp makes em
Joshs4x4toyz is offline   Reply With Quote
Old 11-24-2012, 12:23 PM   #4
Excellent idea!
KillerBlackbird is offline   Reply With Quote
Old 11-24-2012, 02:51 PM   #5
We have been known to make a few out of stainless..
scottanthony is offline   Reply With Quote
Old 11-25-2012, 06:30 AM   #6
Nice wraith, love the wheels and rotors, skins, etc... . The sliders look like some aluminum ones that I bought off eBay some time back. I liked them but they only covered the very bottom of the diff and not the 8mm on each side of the very bottom. But still I think in stainless like you have made would be a lot better than the aluminum for sliding on da rocks. Good job!
Tags
axle, skidplate, skids, vanquish, wraith axles
Ar60 and VP 60's home made skids - Similar Threads
Home Made. Creepy Inc. Chit Chat 9 10-06-2010 08:48 AM
Has anyone made skids for the Berg axles or diffs?? BigB_117 EnRoute Berg 7 02-01-2009 10:07 PM
I made some new AX-10 skids Headshok88 Axial AX-10 Scorpion 12 11-17-2008 04:56 PM
home made course skate General Crawlers 6 03-07-2008 11:44 AM
