12-10-2012, 07:15 PM | #1 |
Pebble Pounder Join Date: Sep 2011 Location: Between the thoughts of yesterday and the ideas of tomorrow
| Aluminum Panels
Does anyone have a template or an idea of how to draw a template of the stock wraith panels. I want to make some aluminum ones and i'm not sure how to factor in the curves. Thanks |
12-10-2012, 07:28 PM | #2 |
Quarry Creeper Join Date: Nov 2012 Location: Wapella
| Re: Aluminum Panels
Why not just use your stock panels. Lay it on a piece of paper and trace it out. Only tricky part is the tailend but not hard to do.
12-10-2012, 07:43 PM | #3 |
| Re: Aluminum Panels
Thats what i was thinking, But again, I dont' want to cut the aluminum and be too short after bending.
12-10-2012, 07:46 PM | #4 |
Pebble Pounder Join Date: Feb 2009 Location: New York
| Re: Aluminum Panels
I know you said you wanted to make them, but here is another option - Wraith body panels |
12-10-2012, 08:10 PM | #5 |
Quarry Creeper Join Date: Nov 2012 Location: spanish fork
You can lay them completely flat on the metal sheet, trace it out and even mark the wholes with a marker then snip them out Sent from my XT907 using Tapatalk 2 |
12-10-2012, 08:24 PM | #6 |
Quarry Creeper Join Date: Jan 2009 Location: atlanta
| Re: Aluminum Panels
uea a shirt box.tape it to your panels it bends well,then trace.
12-11-2012, 08:56 AM | #7 |
Rock Stacker Join Date: Oct 2012 Location: dfw
| Re: Aluminum Panels
I like this idea what gauge aluminum are you going to use??
12-11-2012, 09:29 AM | #8 | |
MODERATOR Join Date: Oct 2010 Location: RC Land
| Re: Aluminum Panels Quote:
I think even if someone mailed you a pattern, you traced it out, cut it out and then bent it up... I doubt you would be happy with the fitment. I bought a set of pre-cut, pre-drilled FLAT aluminum wraiths panels on here from a Vendor and ended up throwing them away after several attempts at getting them to fit. Either they were cut & drilled wayyyy off, or I just wasn't having any luck. I gave in and made my own as I described above with starting with a rough over-sized panel and it went quick and painlessly. . | |
12-11-2012, 09:36 AM | #9 |
| Re: Aluminum Panels |
12-11-2012, 10:46 AM | #10 |
Quarry Creeper Join Date: Nov 2011 Location: Plano,TX
12-11-2012, 02:24 PM | #11 |
Newbie Join Date: Feb 2012 Location: Princeton B.C. Canada
| Re: Aluminum Panels
My self I would go with Carter Fab, I have seen their work and it is great. It is a no brainer. |
12-11-2012, 03:11 PM | #12 |
| Re: Aluminum Panels
You know what they say go big or go home!!! |
12-11-2012, 06:29 PM | #13 |
Quarry Creeper Join Date: May 2010 Location: albuquerque
| Re: Aluminum Panels
traced my stock panels including the holes, fit perfect. used .040 aluminum, and i think i spent $4.00 on the aluminum and an hours worth of time |
12-11-2012, 10:26 PM | #14 |
| Re: Aluminum Panels
nice job. the problem is always the hood. advancedmetalfabs on ebay - $20 with free shipping. they are .040 as well. |
Aluminum Panels - Similar Threads | ||||
Got You Covered: Aluminum Panels | CarterFab | Vendors Paint and Body | 242 | 01-28-2015 08:04 AM |
painting aluminum panels | ezee | Axial Wraith | 6 | 02-23-2012 12:02 PM |
Painting Aluminum body panels!! | Mr.Tek | Paint and Body | 3 | 12-05-2011 09:11 PM |
