05-03-2013, 08:46 PM | #61 |
| Re: first basher build. Had to have a stinger to proteck the battery. That's 5000mah and can slide back about an inch Last edited by evan03; 05-03-2013 at 09:13 PM. |
05-03-2013, 10:18 PM | #62 |
Quarry Creeper Join Date: Feb 2013 Location: Coupeville, WA.
| Re: first basher build. That looks better but I am going to be an armchair quarterback for a minute. The battery is still going to be unprotected during a rollover with a rock if it has a point to it. What about putting a x or * pattern on the bars above it to help protect it. Then maybe could still slide in and out from the front of the stinger maybe? I don't know would need a top angle pic to see better. |
05-15-2013, 07:08 PM | #63 |
Scrapped the frame build. Back to my wraith frame. I will build something later, thinking a 650 truggy or something similar Made a few adjustments. Have a 5000 may 2s under the hood and am fitting my boggers with the foams that vme with the r35 ripsaws already thinking there to soft |
05-19-2013, 03:53 PM | #64 |
Did a little crawling on my lowest ride height ever. Shocks about 70% compressed and sitting slightly lower then level links. Seems to work very well. Also man I want decent foams since mods start at the ground u I finally decided to ;order a set of 6.0 dual stage ci foams in medium and soft. Those are rc4wd stock blogger foams all wadfed up after a few minutes of knarely crawling Pretty excited to get ci 6.0s |
05-20-2013, 08:10 PM | #65 |
My front end has been getting sloppy and I have a ton of these busings so I threw them in and shimmed the axles. Man way tighter steering and my tires aren't leaning in. These are the same bushings as the pinions |
05-22-2013, 05:53 PM | #66 |
Crawler innovations 6.0 foam on the left vs rc4wd on the right. The side wall on the rc4wd is folding over just sitting there. I'm gonna run mediums in the front and soft out back. Back words from what mist run. I may end up switching them around Last edited by evan03; 05-22-2013 at 05:58 PM. |
05-22-2013, 09:25 PM | #67 |
A quick video with the 6.0 foams doesn't show much but I'll post it anyways https://www.youtube.com/watch?v=-rmC...e_gdata_player |
05-22-2013, 10:07 PM | #68 |
OK few pics with the new foams installed |
05-25-2013, 12:50 PM | #69 |
Bumper redesign Last edited by evan03; 05-25-2013 at 12:52 PM. |
05-25-2013, 05:44 PM | #70 |
I was liking the tube build. The new foams look a lot better for the sidehills. Nice redesign on the bumper. It looks very well built and like you took your time on it. Oh and my stinger is much BIGGER!!!
05-25-2013, 07:48 PM | #71 |
Lol thanks. Yeah your stingers bigger ;)
05-25-2013, 11:45 PM | #72 |
Newbie Join Date: Apr 2012 Location: lake stevens
Nice work on the new bumpermy favorite one I have seen
05-26-2013, 09:20 AM | #73 |
Thanks Cody.
05-26-2013, 01:41 PM | #74 |
My boggers are on they're last leg so I decided to more or less turn them into a badlands type tread. Also did a little running and I think I need a bottom bare on the bumper. For some servo protection |
05-31-2013, 12:09 AM | #75 |
| Re: first basher build. Just brought home a 1/4 scale 300. So I'll probly be giving the wraith a little less loving for awhile |
06-14-2013, 05:37 PM | #76 |
Okay. Been seeing all these cage stifners and thought I'd try it. Actually drinking more beer then anything |
06-15-2013, 06:15 PM | #77 |
Setting up steering with hot racing high clearance knuckles |
06-15-2013, 09:10 PM | #78 |
These knuckles took some work to bolt on with axial bead locks I'm dign them. I made the steering out of 1/4" solid. I gotsa say this steering setup is kicking my ass This one shows how high the high clearance hot racing knuckles really are. Last edited by evan03; 06-15-2013 at 09:19 PM. |
06-16-2013, 08:38 AM | #79 |
In top hole on the servo there's wasn't much steering. Dropping one hole makes it steer twice as much but also makes it look fugly. I may drill and tap another hole in between these two on the servo horn Last edited by evan03; 06-16-2013 at 08:49 AM. |
06-16-2013, 03:17 PM | #80 |
Finally happy with this steering In my opinion the hot racing knuckles are cool for custom builders. Axial bead locks won't fit over them and stock wraith wheels won't fit. The steering is a little to high I think but would be awesome on a cms set up or dinky type mount. Knuckles feel good. Bearings are a tight fit and actually seem tighter then at stock axial knuckles |
first basher build. - Similar Threads | ||||
Hilux Basher Build | ckscaler | Axial SCX-10 | 1 | 07-21-2012 09:19 PM |
My Maxx basher/crawler build | crazy81 | Traxxas Crawlers | 56 | 07-25-2011 09:34 PM |
Help me build the Ultimate AX based Basher | Sixstring | Axial AX-10 Scorpion | 19 | 11-28-2008 08:12 AM |
WK Basher/Crawler Build | WK Joe | HPI Wheely King | 9 | 07-24-2008 06:05 AM |
