Thread: G6 wraith build
Old 01-06-2013, 07:13 PM   #21
Default Re: G6 wraith build
a new spot ross found over by his house..off dixon rd.
ROLANDROCKSHOP is offline   Reply With Quote
Old 01-06-2013, 07:40 PM   #22
I knew I knew it..... First place I got my XR650L stuck. Had less than 10 miles on the odometer. He's out near my family. When that shit gets wet it is the Devils mud!
mmatthews is offline   Reply With Quote
Old 01-08-2013, 10:17 AM   #23
got my exo radiator and rear light bar housing in today..
as well as these Crawler dad lightbars..2in and 5in versions
both were under $60 run off 3s powa!
Old 01-08-2013, 06:08 PM   #24
took the girly and the bullyboy to the park for a quick run around the trail..took the G6 wraith for a shakedown run too.
Old 01-08-2013, 06:17 PM   #25
sweet vid
kakachille is offline   Reply With Quote
Old 01-10-2013, 03:24 PM   #26
so after the shakedown run i noticed one of my Rc4wd coilover shocks was a lil stiff..so i decided to rebuild it real quick..
old orings pulled out...
new orings...
clean out the body..
mmhmmm...dirty..
couple of drops of shock oil for lube..and reassemble
Old 01-10-2013, 03:26 PM   #27
and finished installing lights and installed radiator w hoses..
stuffed a lil 3s lipo in the rear battery tray under gas tank..
oh yea!! its bright now!!
Old 01-10-2013, 08:31 PM   #28
Nice work Josh, I can't wait to destroy the new stomping grounds Sunday.
jeepinkid83 is offline   Reply With Quote
Old 01-10-2013, 09:34 PM   #29
The lights look really good. I like this Wraith.
Seeing you post on the shocks reminded me; I took your advice with the orange o-rings for the shocks. The set I got from you on the SCX chassis, I tore them down, cleaned everything, lubed everthing and took some scotch bright to the shafts. They are like new shocks.
Old 01-11-2013, 06:36 AM   #30
due to the rain our wraith beatdown session may be put off till we have some dry weather..that place is BAD mushy when it gets wet.
michael knows...hehe
Old 01-11-2013, 06:39 AM   #31
That shit is STICKY when wet.
Old 01-11-2013, 06:39 PM   #32
How did you mount the rear light bezel
peterk is offline   Reply With Quote
Old 01-11-2013, 08:29 PM   #33
had to trim edges to go around rear support arms..
then lined up on rear bar of rollcage..found good contact points
drilled 3 small holes 1 left 1 center 1 right..
drilled thru light housing into rollbar in each hole.
test fit..trim as needed
you can barely see the tops of the screws..
Old 01-11-2013, 08:41 PM   #34
Looking mighty fine . I got the same wheel and tire package, they rule! Are you putting a winch in? Keep up the awesome work
Rob
Krawler Konceptz is offline   Reply With Quote
Old 01-11-2013, 08:46 PM   #35
Rob
thank ya rob!
if i can find a place for one...
its pretty tight up in the front
maybe could do a servo winch mounted where the dig servo goes on tranny???
Old 01-11-2013, 08:49 PM   #36
ive never heard of the crawldad light bar, could you post a link?
dieselmudder is offline   Reply With Quote
Old 01-11-2013, 08:51 PM   #37
https://www.facebook.com/?ref=tn_tnm...068211?fref=ts
5in and a 2in version..runs off 3s, waterproof
i bought both versions for under $60
its a diy mounting install
crawlerdad@yahoo.com
Old 01-11-2013, 08:59 PM   #38
just what ive been looking for. thanks. will be hitting him up soon.
Old 01-16-2013, 11:24 AM   #39
a few at night pics to show just how bright these lights are...
Old 01-16-2013, 04:46 PM   #40
thing is sweet like the rear light bar
G6 wraith build - Similar Threads
My Wraith build..... ScottinBend Axial Wraith 1 11-13-2013 01:28 PM
1.9 Wraith build rckjeep Axial Wraith 25 07-07-2012 02:47 AM
My Wraith Build acesal Axial Wraith 29 05-02-2012 09:59 PM
my wraith build Slap204 Axial Wraith 0 11-14-2011 10:47 AM
Wraith build pwrwgn2000 2.2 Scale Rigs 2 10-17-2011 07:27 AM
