01-20-2013, 09:19 PM | #1 |
Rock Stacker Join Date: Jan 2013 Location: garden city
| gearing question
im putting a 27t motor in my wraith and was going to go with a 84/15 gear set-up but was thing if stock is 80/20 would 84/15 be pretty much the same as stock? id like to have good crawling but speed when i need it. thats why i thought 27t motor and 84/15 would be good. help keep motor from running hot but also give good torque with ok speed am i wrong ? |
01-21-2013, 02:08 PM | #2 |
| Re: gearing question
any input would be nice thanks
01-21-2013, 04:19 PM | #3 |
Read this thread if you haven't already done so. Choosing a motor and ESC for your Wraith - Gearing Added! 80/20 = 4:1 gear ratio 84/15 = 5.6:1 gear ratio 84/15 is a lower gear ration than 80/20 I would probably start out with a gear ration closer to 5:1, check temperatures and adjust if needed. Depending on your motor you might be better off with 32P gears. That would in 54/11 32p range to start. |
01-21-2013, 04:35 PM | #4 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
On the 32 pitch you can go to the 56 and still get the cover back on. I'm running a 55T motor with 56/12 (4.666) ratio. Ran for more than an hour never got hot. Crawls great but for get the speed. It's about as fast as a trot.
01-21-2013, 07:03 PM | #5 |
ok i kind of understand i wasnt seeing how to get the ratio but now im understanding I'm waiting on a 84t spur gear so i think im going to try a 80/17 which i understand to be a 4.70:1 ratio I'm just hoping it doesnt make my motor run to hot
01-21-2013, 07:04 PM | #6 |
btw im running a 27t axial motor
01-21-2013, 08:05 PM | #7 |
i tryed the 80/17 i think its still to fast im gonna try the 84/17 when my 84gets here
gearing question - Similar Threads | ||||
Gearing question | Trentenowns | Axial Wraith | 3 | 09-23-2012 12:00 AM |
Gearing question | transambill | Axial Wraith | 6 | 01-29-2012 07:04 PM |
gearing question | 4x4boy | General Crawlers | 0 | 09-18-2011 07:20 PM |
gearing question | creepingcrawler | Newbie General | 6 | 01-13-2009 12:21 AM |
Gearing question | musicmaniac | HPI Wheely King | 4 | 08-08-2007 12:52 PM |
