01-27-2013, 12:46 PM | #1 |
RCC Addict Join Date: May 2010 Location: Midwest
| Die-Laughing's Monster Truck..
Well, after seeing a few of the guys on here build monster trucks out of wraith's, I had to have one. I basically just looked at their threads on my phone while in the garage and kinda just built it based off of ideas I got from all of them. I started with a box stock wraith roller. The material I used is .1875" Solid Stainless rod. I built a handful of chassis' but, I always brazed them together. This time, It'll be mig welded. It's not my first time mig welding but, the first time I'll apply it to a R/C chassis. Here's a fresh weld: and here it is rough ground: obviously, I'll do some finish grinding/polishing once it's complete and it'll look nice but, I'm pretty happy with how it's working out so far. I can actually hold a short piece of material with my bar fingers when I spot it.. I couldn't get near it while brazing. I didn't have to fixture anything up to hold a part once so far. I guess these are considered twin vertical plates? well, I got them done started: here they are on top of each other: They simply bolt onto the wraith skid plate: I started out building the TVP's straight because thats what everybody else did but, I soon realized that my wraith skid was pretty wide and my shocks would come in contact with the TVP's if I didn't do something. So, I decided the easiest way out was to put some bends in the front and rear so there would be no interference. It turned out pretty good. Then, I started the shock hoops: Now, this is a really cool idea I got from a buddy of mine (badhoopty). I saw him do it first. I basically took two pieces of 3/16" rod and welded them parallel to each other with an 1/8" gap between them. I'll use a through bolt and some concave spacers to pinch the shock in the location I like. I put them on a severe angle so that I could move the shock forward & back as well as up & down to my liking. I did that on the front and rear: You can see some of the bracing I started in between the TVP's but, it'll need quite a bit more. I'm going to set this thing up with 4WS so, I wanted to leave space for the axle mounted servos to fit up inside of there. This is where I'm at with it so far. Not bad for a half days work. The wheels are my mockup wheels that "badhoopty" let me borrow.. I'm keeping an eye out for wheels & tires for this thing. Thanks for looking! |
01-27-2013, 12:49 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: OUT THERE
| Re: Die-Laughing's Monster Truck..
Very nice DL I want one this is going to be badass |
01-27-2013, 01:10 PM | #3 |
Quarry Creeper Join Date: Jul 2010 Location: My garage...
Looks great man! Nice start! You do some pretty impressive work, I'm sure this build will be no different. I'll be watching! |
01-27-2013, 01:17 PM | #4 |
Looking really cool man! Is it going to have an internal body cage? |
01-27-2013, 01:26 PM | #5 |
Moderator Join Date: Jan 2004 Location: chicago
ok now that is cool! definitely a tuber and not a tvp. |
01-27-2013, 01:31 PM | #6 |
Thanks guys! Yeah, I haven't really thought about what body im going to use yet so, I'm not sure if its going to have an interior cage. Jason, I wasn't sure about that TVP thing but, I guess you're right. It's a tuber! |
01-27-2013, 04:25 PM | #7 |
Rock Crawler Join Date: Nov 2011 Location: Sin City
Geez dude! Nice work!
01-27-2013, 06:47 PM | #8 |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
It's coming along nicely, really like that upper shock mount idea........... Damn it I guess I will have to build a monster truck next.... |
01-27-2013, 06:51 PM | #9 |
I wanna be Dave Join Date: Dec 2008 Location: ?
What body do you plan on using?
01-27-2013, 06:55 PM | #10 | |
| Re: Die-Laughing's Monster Truck.. Quote:
did see sorry. chassis looks super cool. | |
01-27-2013, 07:00 PM | #11 |
I think I'm going to try the HPI Mini Trophy truck body.. I think one of the other guys has/had that on thier's and it looks killer |
01-27-2013, 07:06 PM | #12 |
Great start. Be sure to brace and cross-brace that chassis good. Mine got tweaked by some light jumps before I had it braced up. The tires and wheels are over 3lbs and with a Pro4 on 3s it can go wrong quick. Lol. I'm interested to see how this will handle with the wraith link geometry. |
01-27-2013, 10:04 PM | #13 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
Awesome, I'll be watching this for sure unfold. |
01-28-2013, 10:49 AM | #14 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
great start! i like the chassis layout so far.. |
02-01-2013, 09:56 PM | #15 |
Rock Stacker Join Date: Aug 2012 Location: enumclaw
keep up the good work
02-06-2013, 05:56 PM | #16 |
Thanks guys! I think I'm going with a summit 2spd trans in this one. I made a little progress. I picked up a used set of wheels/tires that somebody had modified. I'm not exactly sure what they did but, the end result was that the wheel offset changed in my favor so, I picked them up. Then, I modified them to fit some aluminum 12mm hexes. I made the center hole fit snug around the "boss" of the hub. (Left to Right) Stock, Drilled & Milled, Hub installed. I had to mill the little nubs off the face of the wheel as well so, I can put my screws there! And here it is.. Should do fine for a cheap & easy setup. |
02-06-2013, 06:27 PM | #17 |
Quarry Creeper Join Date: Feb 2008 Location: Dawsonville, GA
I'm liking where this is going. Keep us posted. |
Die-Laughing's Monster Truck.. - Similar Threads | ||||
Die-Laughing's Jeep YJ Hardtop... | Die-Laughing | 1.5 Scale Rigs | 33 | 02-06-2013 07:23 PM |
Die-Laughing's Toyota Mojave Drift Truck | Die-Laughing | Non Crawler RC's | 77 | 01-20-2013 09:11 PM |
Die-Laughing's BadAss FJ | Die-Laughing | 1.9 Scale Rigs | 89 | 09-28-2012 01:59 PM |
Die-laughing's FJ40 TF2! | Die-Laughing | 1.5 Scale Rigs | 62 | 08-21-2012 08:08 PM |
Die-Laughing's Wrecktuber | Die-Laughing | 2.2 Scale Rigs | 78 | 02-26-2012 09:54 PM |
