03-13-2013, 12:04 PM | #81 |
Rock Stacker Join Date: Jan 2013 Location: Kentucky
| Re: What shocks you running?
How long are the xxlong shocks.
03-13-2013, 12:23 PM | #82 |
Newbie Join Date: Jul 2012 Location: SC
Im running the 103 gmade shocks with the level 3 droop kit and have been happy with it so far, ive only run it a few times since i put them on though. No compaints
03-13-2013, 04:31 PM | #83 |
Newbie Join Date: Aug 2012 Location: sooke
im running king 110mm and there awesome!
03-13-2013, 04:36 PM | #84 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
| Re: What shocks you running? |
03-13-2013, 04:37 PM | #85 |
Pebble Pounder Join Date: Apr 2006 Location: Spring Hill, TN
Where do you buy this stuff? Seems like everyone is out of stock and has been for awhile. XD piggybacks, King, etc.
03-13-2013, 04:42 PM | #86 |
03-13-2013, 05:03 PM | #87 |
Hell, they're out of stock too. Man, must be a run on Wraith shocks. |
03-13-2013, 05:06 PM | #88 |
RCC Addict Join Date: Aug 2012 Location: Philippines
I stopped in at RPP on Monday and picked up a pair of 103mm XD Aeration shocks. Still have to assemble them. Will report back. The Venom Creeper 138mm shocks I am running in the rear are OK. Just OK. They leak a small bit, but far less than stock wraith shocks. For $20/ set of four I cant complain. Now if only I could find a spring that is 5" long with the same rate as Losi 1.4's....... |
03-13-2013, 05:13 PM | #89 |
What's the advantage with the Aeration over the regular XD Diaphragm?
03-13-2013, 05:28 PM | #90 |
No advantage to one vs the other, just different designs. Aeration is somehow supposed to be easier to fill. (according to Nate @ RPP.) I Would have gotten the piggybacks, but they are out of stock as stated above. |
03-13-2013, 05:31 PM | #91 | |
Quarry Creeper Join Date: Sep 2009 Location: Detroit
| Re: What shocks you running? Quote:
A 1:1 shock piston has two sides to it, compression and rebound. These are typically offset from one another so only one side is active when traveling in one direction. When the shock is compressing, the fluid is pushing on the valve stack of the rebound side, effectively shutting it off, but the gap between the rebound and compression ports allows the fluid to enter the compression ports and pass by the valve stack for the compression damping. The same happens for the rebound stroke except it uses the rebound ports and valve stack while closing the compression ports. The content of the valve stack determines whether you will have linear, progressive or digressive rates for low and high speed velocities. Bypass, whether internally or externally using tubes, bring in another factor which literally allows the fluid to bypass the valve stack for that zone of the stroke so you can have soft and firm zones of travel in addition to the high and low speed differences which are accomplished with the valve stack. What you did was soften up the damping across the board. The only way to give some priority to compression or rebound would be to chamfer one side or the other of a given set or series of holes. This would help create a Venturi effect allowing more fluid to pass through the hole as opposed to a non chamfered hole (fluid flowing in the other direction). If you want more details on any of the topics, let me know and we can go into a deeper dive, what I discussed was just brushing the surface of shock vavling and how to achieve a given desired result. As for the original topic, I'm running XR10 shocks with LOSI good springs and I'm looking into options for a shock that offers more functionality and packages at a similar length and diameter. I may end up going with the proline power stroke shocks with delrin pistons, that have either one of or both, these features; compression/rebound specific adjustability or an adjustable valve stack which can be adjusted for progressive, linear or digressive rates. Last edited by 95geo; 03-13-2013 at 05:35 PM. Reason: Wrong pic... | |
03-13-2013, 06:10 PM | #92 |
Well, I found one set of the 103mm XD piggybacks on Amazon so I grabbed those and another set of 103mm Aeration's. Guess I'll see which I like best. Who needs matching shocks anyways...
03-13-2013, 06:57 PM | #93 |
95geo. Awesome post. I've just about talked myself into the made piggybacks. I think crawler innovations sales shock valveing kits that looked interesting. Properly setup piggbacks have awesome reviews. I quit looking at the pro lines because the didn't seen as adjustable I may give them another look. |
03-13-2013, 11:08 PM | #94 |
Rock Stacker Join Date: Jan 2012 Location: Vancouver
| Re: What shocks you running? My measurements were approx. 4" eye-to-eye fully extended, and 2-7/8" EtE fully compressed. Went halfers on the 4962 8-pack with a buddy. Liking these shocks a lot already and getting the impression they're going to be really easy to tune with diff shock oil wts, spring rates, and piston hole configurations.
03-14-2013, 12:59 AM | #95 |
| Re: What shocks you running? I dont find them stiff at all, but i've also got my spring tension way loose on them. pretty much to the point that if i turned it out more the spring would bounce around in between the guides. this is my first wraith but i found the performance on these shocks were good. and yes of course they do look cool as ice with those reservoirs |
03-14-2013, 07:39 AM | #96 | |
If not long you'll soon find out they are very similar to the Exxon Valdez. | |
03-14-2013, 08:00 AM | #97 | |
A shock that mixes the air and oil is an emulsion style shock. This is ok for slow speeds or tight packaging confinements but the performance quickly degrades when compared to a shock with a divided oil/air system. The closest we can get to an ideal shock in the small scale world (that I have seen) is a shock with a bladder that isolates the air chamber from the oil. This is effectively a floating piston on a very small scale. If manufacturers are capable of manufacturing a shock that has a floating piston, adjustable valving and other full scale features, send me a PM if you care to. That's enough for now.... | |
03-14-2013, 08:08 AM | #98 |
03-14-2013, 11:02 AM | #99 |
Rock Stacker Join Date: Mar 2009 Location: frederick
There is a shock kit that mip is making that uses that same technology you are talking about. There is a vid on you tubealso. I saw the link on hobbytalk awhile back. It was in the oval section i think.
03-14-2013, 11:05 AM | #100 |
What shocks you running? - Similar Threads | ||||
what shocks are you running? | maRRtin | Redcat Crawlers | 5 | 03-02-2012 06:26 PM |
Shocks - What has everyone tried or running? | NCT_Guy | Axial Wraith | 13 | 01-03-2012 03:37 PM |
Wraith shocks? What are you running? | Mr.Tek | Axial Wraith | 4 | 01-03-2012 08:28 AM |
What shocks are you running? | V3500 | Axial SCX-10 | 21 | 01-22-2011 03:15 PM |
What Shocks you running? | LeDevil | Tamiya XC/CC01 | 20 | 01-17-2010 05:27 PM |
