Thread: What shocks you running?
Old 03-14-2013, 02:19 PM   #101
Default Re: What shocks you running?
You must not have researched info on the Gmade piggybacks.
Off course these shocks aren't like 1:1s.
I do not like the looks of the piggy backs before researching I wrote off the gmades. Now I want them and still dislike how they look
evan03 is offline   Reply With Quote
Old 03-15-2013, 01:35 PM   #102
I stand corrected. Last time I looked at g made shocks I didn't pay much attention to them since these weren't out yet.
Once they come back in stock I'm going to order up a set as they seem to fill most of the void that I was referencing.... Provided they are strong enough to hold up to pro4 wraith abuse and the o-ring seals keep the air/separate.... If not, it's just another useless shock that makes milk shakes for you!
95geo is offline   Reply With Quote
Old 03-15-2013, 02:00 PM   #103
lol. nothing wrong with milkshakes.
ive been doing alot of research on the gmade piggy backs most this research is led to the shourtcourse forumns. i now am completly undecided on what to get or if theyre worth it.
i bash hard and go very fast at times and these have a plastic cap with aluminum resivor.
i missed out on set of used ones on ebay last week.
weather is getting good so its time to start flying and maybe a good escuse to build an fpv plane and just run the wraith as is for now.
i did notice when doing big sand jumps 30-50ft of air time that the stock wraith shocks bottom very hard. traxxas gtrs and sprung and oiled for it might cure this alittle and bone cheap
Old 03-16-2013, 01:39 PM   #104
G-made G-Transitions. Internal spring. You can run flip internal springs to change ride height. Live em. No leaky!
mett1971 is offline   Reply With Quote
Old 03-17-2013, 07:41 AM   #105
So for a Wraith type Basher, I've read the whole thread what would be the best setup for a basher setup and the occasional crawling?
So many choices, any help would be super, thanks
cmnyj28 is offline   Reply With Quote
Old 03-17-2013, 09:45 AM   #106
nothing wrong with the stock shocks.
im not entirely positive that anything is huge improvment over stock
Old 03-17-2013, 09:48 AM   #107
For go fast bashing go with firmer damping/springs on a shorter shock OR consider sway bars.
Crawling demands a little faster shock movement and softer springs. Longer shocks with a droop kit work well for me.
In the end you're going to have play with things to find what you like.
gbean is offline   Reply With Quote
Old 03-17-2013, 09:52 AM   #108
Yeah I figured was looking for a good starting point..
Old 03-17-2013, 09:55 AM   #109
check out my go fast sand vids on stock shocks
Old 03-17-2013, 02:31 PM   #110
wow, you are exactly in the same situation than me, I running some C.K. Shock for the exo with medium springs, I just swap the shock shafts with the stockers and now my length is 93mm, the CoG is much better now and the car runs more stable
so true.. for a wraith basher type... like mine
Steelfish is offline   Reply With Quote
Old 03-17-2013, 04:12 PM   #111
I'm going to get some traxxass gtr's 25-20 bucks for a set of four on eBay. They're damn good shocks my slayer had them.
Would make a baddass trail basher and sometimes rock bouncer
Old 03-17-2013, 07:06 PM   #112
i just installed my new 110mm king off-road shocks
crwler is offline   Reply With Quote
Old 03-17-2013, 07:38 PM   #113
Damn nice
Old 03-17-2013, 07:54 PM   #114
Nice, how you like them for crawling?
throttlejock27 is offline   Reply With Quote
Old 03-17-2013, 07:56 PM   #115
mines with 93mm and still nice flex
Old 03-17-2013, 07:58 PM   #116
they work very good
Old 03-18-2013, 02:11 PM   #117
Just installed The Proline Shocks #6063-01....Very Very nice shocks.
Pita is offline   Reply With Quote
Old 03-18-2013, 06:30 PM   #118
They look good. I just ordered some rc4wd king shocks
Old 03-18-2013, 07:47 PM   #119
Pita
Can we get a pic of how tall its sitting with no preload on prolines. And with the pictured preload
Old 03-18-2013, 08:00 PM   #120
... if they are the Slash 4x4 rear shocks which they look to be, they are the exact same length as stock wraith shocks.
What shocks you running? - Similar Threads
what shocks are you running? maRRtin Redcat Crawlers 5 03-02-2012 06:26 PM
Shocks - What has everyone tried or running? NCT_Guy Axial Wraith 13 01-03-2012 03:37 PM
Wraith shocks? What are you running? Mr.Tek Axial Wraith 4 01-03-2012 08:28 AM
What shocks are you running? V3500 Axial SCX-10 21 01-22-2011 03:15 PM
What Shocks you running? LeDevil Tamiya XC/CC01 20 01-17-2010 05:27 PM
