What shocks you running? What shocks everybody running? Was thinking about trying the gmade xd piggybacks. Was maybe thinking about the 103mm and running the level 3 droop kit.... Any opinions or info would be great, thanks |
I am running the 103mm gmade piggybacks and they work great. No droop kit, just did the lower tricks for the stock shock mounts. |
Re: What shocks you running? 4" losi crawler |
Re: What shocks you running? Slash front Proline Powerstrokes all the way around. "thumbsup" |
Re: What shocks you running? I run the stocker, but with STRC bodies and cap. They work good and don't leak anymore. Included dual stage pistons are a plus. I run them with Jeepin Doug spring retainers and losi white springs. |
Re: What shocks you running? I have the Proline Powerstroke shocks for the front of the Slash. They're very nice, but articulation is definitely reduced do to their length. I'm also running a CSM, so that's part of the issue. I'm not ready to change them yet, but I may want something slightly longer in the future. |
Re: What shocks you running? Im running the losi 4" with gold springs |
Re: What shocks you running? Xr10 shocks |
Re: What shocks you running? I'm running Traxxas Big Bores with silver Losi MRC springs front and blue on the rear. |
Re: What shocks you running? im running rc4wd king shocks 110mm |
Re: What shocks you running? Quote:
Re: What shocks you running? Losi crawlers |
Re: What shocks you running? slash rear aluminum big bores. |
Re: What shocks you running? Powerstroke rears with front spring set and a little somethin somethin on the inside "thumbsup" |
Re: What shocks you running? got my Integy 138mm coming. im excited for the longer shocks! I hear there good. we will find out. |
Re: What shocks you running? I'm running 120mm Boom racing piggyback shocks. With stock mounts, it is the longest you can get before binding. I tested a little farther and it is too much. If you raise the upper mounts, You could easily work with a 138mm shocks as stated above^ I'd love to see how much articulation you can get with 138mm!!!"thumbsup" |
Re: What shocks you running? Wheelie King shocks 153mm all around. About to switch to either stock Axial or something else just not sure on what I want. |
Re: What shocks you running? Any of you guys that are running longer shocks care to post some pictures. I'm looking to going a little longer and. Just want to get an idea. |
Re: What shocks you running? RC4WD 100mm King with piggyback. At first I was hesitant on how soft they were. Now I wouldn't choose anything else. |
Re: What shocks you running? Rear power strokes all the way around |
