02-02-2013, 12:10 PM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: San Diego
| Hot Racing Links are hot mess!!
So, I'm new to RC and the Wraith is my first. I bought a link dress up kit from HR (Hot Racing) Here's my thoughts: Steering Link: First thing I put on. It actually functions ok. Better than stock. But..... The brass retainers fall out pretty easily. My fix? Spread super glue with a stick to the whole rim, then press back in place. This holds for a few days to a week. Suspension Links: They look nice and at $63.00, I didn't think I was cheating out. I tried to install and the geometry was horrible!!! The link ends are at a horrible angle and are aluminum, so they likely can't be bent. In this pic, I'm holding one link straight and you can see where the link wants to go. Don't even get me started on the uppers. I tried in threading the ends to get proper angles, but the the links were loose and unstable. Has anyone had luck with these? Should I try different ends? Revo? Jato? Diff Covers: these seem to work ok, but they lack the inner lip that the stock plastics have. So I can only assume they don't deal as well to water. I have ground my pumpkins down on the rocks from weeks of crawling. After putting the new covers on, I was worried about hanging up on the lip. Not a problem, these things are so soft, that within a few hours, they have ground down to match the plastic pumpkin that took weeks. All in all, I would strongly suggest avoiding this kit. I wish I knew that HR sucked. |
02-02-2013, 01:00 PM | #2 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
| Re: Hot Racing Links are hot mess!!
should have got the blue monkey links there around the same price and are way better
02-02-2013, 02:58 PM | #3 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
ill agree the hr link kit isnt the best i have the silver set on mine. what i dont like is the alum is soft an the brass retainers fall out on the links havent had that happen to the sterring yet. an the diff covers yea well dont hit anything with them i did an had to use a punch an tap out the dent as it was rubbin. as for the angles not sure why they wont line up for ya mine did but since i have had the brass retainer prob i used traxxas shock ends on the rear links an gonna do the front the same how ever in the end gonna grab some vp links. oh yea on the sterring link i took the drag link off an connected it to the sterring knuckle wich are also hr they seem pretty good so far.the pivot ball should move enough to allow your links to line up but are at an odd angle in the socket an i think thats why they fail so quickly ill snap a pic an post it when i can http://s1037.beta.photobucket.com/us...08863973656924 link to the pics of my wraith
02-02-2013, 06:57 PM | #4 |
I'll try the traxaas ends. I have these parts now and wouldn't feel right selling them to somebody. The steering link is tough. I've been running it for two weeks, primarily on rocks and it shows. It is rigid, but those brass inserts pop out every four or five trips. |
02-02-2013, 07:08 PM | #5 |
yea my steering link has been good since i used red loctite an mooved the drag link from the sterring rod an connected it to the sterring knuckle next on my list gonna do a shock cap mod an use a good rod end on them the rubber bushin thing ripped on me
02-02-2013, 07:10 PM | #6 |
Quarry Creeper Join Date: Nov 2012 Location: oshkosh
I bought the steering links in black and within 5 min of running it the brass ring popped out and broke in half so I could not put back in
02-02-2013, 10:19 PM | #7 |
Live and learn.. On a Wraith, you need either steel or titanium links and Revo rod ends. Anything less WILL fail you at some point. |
02-03-2013, 01:40 AM | #8 |
Pebble Pounder Join Date: Nov 2012 Location: united kingdom
HR blows, I had the same problem with my steering. I'd recommend STRC products. Not as expensive as Vanquish and the quality is just as good plus you can get the green colors if you want.
02-03-2013, 02:58 AM | #9 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
here is my experience with HR.just bought some wide hubs for wheels,at first look,they where ok,but when i wanted to install them,i couldn't,so i had to work a litle to fit them,but was easy,finally i am happy with product.as far as the link,i always use traxxas rod ends,and axial aluminum pipe of different sizes,and if it's to long i can always cut the aluminum and make inside it a thread to fit the rod ends.also a friend of mine uses the BTA system from HR and it works good,had no issue with it.also using STRC,they have very nice products,never had any problem with them,it's a bolt on,every piece i had and the price is good.Vanquish......hey.....we are talking from another class,altough is a little pricey,but the quality is awesome,u can't go wrong with Vanquish
04-04-2013, 12:26 AM | #10 |
Newbie Join Date: Dec 2012 Location: Canada
Well I sure wished to hell I'd read this 24h ago before ordering the link set. Guess Ill try to beef up the brass insert BEFORE installing somehow.
04-04-2013, 12:37 AM | #11 |
Rock Crawler Join Date: Feb 2012 Location: OC
The HR LINK Kit is the sweetest!!!! lol Those are the shittest links ever, they are the proper ones if you want to put it up on the shelf and not use the toy..... Everyone has the same problem with those "upgrade kits", took all that chit off and went with Chaotic Crawlers high clearence links, Ti, Revo 4mm rod ends....way better! |
04-04-2013, 12:44 AM | #12 | |
| Re: Hot Racing Links are hot mess!! Quote:
Try to place a cone washer/regular washer into the mix...maybe that will keep the assembly from popping loose, the brass inserts. Once those fall out...bummed. Good Luck trying to get a hold of HR too, they are a terrible company for service! HR=Hack Racing | |
04-04-2013, 03:57 AM | #13 |
Rock Crawler Join Date: Aug 2012 Location: Etowah
| Re: Hot Racing Links are hot mess!! |
04-04-2013, 04:00 AM | #14 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
For just a little more money you can buy r2j stainless links
04-04-2013, 07:45 AM | #15 |
Pebble Pounder Join Date: Nov 2011 Location: Muskoka, Ontario
You can use Loctite bearing retainer(green) on the brass inserts. If you don't have any green Loctite don't bother, just replace as Loctite is more expensive than new parts.
04-04-2013, 08:04 AM | #16 |
Ok so what about cutting the ends clear off, threading the rod, then putting on revos?
04-04-2013, 08:06 AM | #17 |
Or perhaps soldering the brass in?
04-04-2013, 08:13 AM | #18 |
Rock Crawler Join Date: Aug 2008 Location: Somewhere in the Sierras.
Sorry you had a bad experience with HR. I bought an HR steering set for my wraith and it's crap. My experiences if you want parts that work properly right from the get-go either get Axial upgrades or Vanquish upgrades. |
04-04-2013, 11:31 AM | #19 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
04-04-2013, 12:59 PM | #20 |
R2J kit ordered from Shon. Anyone wanna buy a HR set? |
Hot Racing Links are hot mess!! - Similar Threads | ||||
Hot Racing Aluminum Steering links?? | mcap | Axial Wraith | 7 | 01-22-2012 03:48 PM |
Totally hot, hot, hot Melons inside! | hvydty1 | Chit Chat | 6 | 06-03-2009 08:48 PM |
hot racing 2.2 ????? | LEROY | Tires and Wheels | 2 | 11-11-2008 09:30 PM |
Hot Racing...? | Blood_Clod | Tamiya Clod Buster | 18 | 10-11-2007 05:41 PM |
