02-13-2013, 08:09 AM | #61 |
| Re: Servos, what are you running?
I've had a few of those in the past and have 1 on a current project rig. They are a good servo, just a bit pricey. I'd add a BEC anyways and get the full power capability the servo offers. It's only $20 and there will be a noticeable difference in the servo power once installed.
02-13-2013, 08:19 AM | #62 |
Rock Stacker Join Date: Feb 2013 Location: Upstate
| Re: Servos, what are you running? |
02-13-2013, 08:21 AM | #63 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
If your running plastic steering links then I don't see why even run a hi powered servo? The stock links bend so much so it don't make much sense
02-13-2013, 08:22 AM | #64 |
02-13-2013, 08:25 AM | #65 |
02-13-2013, 08:30 AM | #66 | |
| Re: Servos, what are you running? Quote:
As to the comment concerning bending factory links. I burned out the factory servo and servo horn. I have yet to break the factory links. Why would I fix it with the same dumpy part? Run it until it breaks and then upgrade with good stuff. That is only logical. | |
02-13-2013, 08:34 AM | #67 | |
02-13-2013, 08:45 AM | #68 |
02-13-2013, 09:05 AM | #69 |
| Re: Servos, what are you running? LOL, it helps me a lot more than no servo, and the hi-tec is way too expensive. Also, in one of the threads on here, it was advised to put anything 300 oz or better for the 5" tires. Listen, this RC car is nothing but a toy to me. I don't need it to be the best possible crawling machine possible. I would rather spend the 30 dollars I saved on a couple boxes of 9mm to run through my RR Vector UZI SMG. I'll get metal links one day. I might even try the Integy set. It would crack me up if they work just fine with no issues (which is what I am suspecting after talking to the people who work at my local hobby shop and my cousin who has done RC for 20 years) In the mean time, I won't have to buy a servo again because I got a quality one which is decently powered for a reasonable price.
02-13-2013, 09:14 AM | #70 |
It's not just about the $30 difference, it's about the toque, quality and customer service. No doubt you got a decent servo, but for a small amount more you could have had the best. The JR will suit you fine until you stip one of the gears. And a gear set is between $30-40 to replace. I could get a shit load of 9mm's for $30 since I pour my own bullets and it only costs me 2.5 cents a round to reload them. lol |
02-13-2013, 09:31 AM | #71 | |
02-13-2013, 09:35 AM | #72 |
Rock Stacker Join Date: Jan 2013 Location: Kentucky
I don't want to get in the middle but he said 486oz at 7.4 volts.
02-13-2013, 09:37 AM | #73 |
Specs Size Category:Standard Typeigital Application:Larger Air and Surface products Torque:403 oz/in @ 6V, 486 oz/in @ 7.4V Speed:0.19/0.15 sec @ 60 deg. (4.8v/6v) Weight:2.34oz (66 g) Bushing Or Bearing:Bearing Bearingual Motor Type:Coreless Gear Type:Metal Gear Material:Titanium |
02-13-2013, 09:39 AM | #74 |
The HighTec is a high voltage servo. I set my CC BEC to 7.4v, so yeah for $30 I got 116oz more torque. But hey you got a servo and a decent one at that so now go tear up some rocks with your Wraith.
02-13-2013, 10:34 AM | #75 |
Rock Crawler Join Date: Apr 2012 Location: Sparks
iv roasted a few savox in my 10 pound wraith but no probs with my hitec 7950 its the bomb!!!
02-13-2013, 11:19 AM | #76 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
pair of 7950th
02-13-2013, 11:52 AM | #77 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
7950 in mine at 7v, and by far the best thing ive put on my wraith yet.
02-13-2013, 03:32 PM | #78 |
What savox did you burn up. 1230 savox is 500 at 6 volts and about 50 dollars cheaper then 7950. |
Servos, what are you running? - Similar Threads | ||||
what servos are yall running ..... | fla_cracker | Florida | 35 | 01-04-2014 10:40 AM |
Ya'll running 35T motors, what pinion are you running? | concretejungle | Axial XR10 | 9 | 03-11-2012 08:18 PM |
servos you guys running? | axialnut | Newbie General | 19 | 02-06-2011 06:51 PM |
running 1/4 servos | yukon635 | Electronics | 2 | 05-23-2006 08:25 PM |
Running 2 different servos-Help!! | Nicklepimp | Electronics | 6 | 05-19-2006 07:26 PM |
