![]() | #1 |
I stripped my stock bottom gear. Which would be best to replace it. Either the Robinson one peice or the Robinson bolt together gear. Price diftence isn't a hole lot. Just curious what you guys think on it. I've already installed the Robinson idler. Thanks |
![]() | #2 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
The one piece won't let you add the dig unit if you ever decide to.
![]() | #3 |
Pebble Pounder Join Date: May 2011 Location: under a bridge
Depends, do you ever plan on doing a dig unit??? If so go multi piece, if not single piece. One way to look at it is, if it is one piece there is less to go wrong...
![]() | #4 |
Pebble Pounder Join Date: Jan 2013 Location: Seattle
The one-piece will also NOT let you use the AX10 transmission housing, for instance the nice VP one. I have the one piece and I somewhat regret the decision. I'll probably end up going with the Crawler Innovations setup and have the 1-piece left-over (or for sale)
![]() | #5 | |
Pebble Pounder Join Date: Feb 2012 Location: Riverside
| ![]() Quote:
![]() | #6 | |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| ![]() Quote:
![]() | #7 |
Thanks guys. I'll order the multi piece
![]() | #8 |
From what I know, no, you can't use the one-piece with the VP case. Here is what I got from Crawler Innovations: "The BDW motor plate fits AX/SCX Transmission cases only. The wraith trans is completely different. If you have the one piece RR wraith locker, it is wraith only. To use the motor plate, you need; AX/SCX Trans case - Axial part# AX80009 Rob. Rac. Gear - Part # 1540 CI trans outputs" So that's what I know. Hope this helps! And I'm not selling my one-piece just yet, I don't have the other parts yet ![]() |
![]() | #9 |
Oh I think that is only if you use BWD motor plate?? I have the stock axial plate. I don't see how different the stuff from AX/SCX and Wraith are inside the trans. After all VP sells us the AX/SCX aluminum trans cases for the Wraith. Hmmmmmmm. Here is BWD motor plate and yes only for AX/SCX but I was told it can work on stock Wraith parts. http://stores.intuitwebsites.com/Bil...ate/Detail.bok |
![]() | #10 |
Newbie Join Date: Jan 2012 Location: Kamloops
It has nothing to do with the motor plate and everything to do with the rear half of the transmission housing. Wraith has a dig extension built into the housing requiring a longer rear output, AX/SCX case does not, hence very different rear output design. One piece Wraith RR will not work with AX/SCX rear case half
![]() | #11 |
Right, precisely what BikingViking said. My quote from Crawler Innovations included the motor plate, since that is the part that I bought that didn't fit the Wraith transmission housing. But I got all the other info with it, so I wanted to share it for completeness. Apologies for the confusion!
![]() | #12 | |
| ![]() Quote:
![]() | #13 |
Okay another question about Robinson Racing gears and the VP trans case? Can I order RRP1552 and use the Wraith stock outputs? Or do I need RRP1540 and the Wraith outputs? I am really confused with the VP case!! http://www.rpphobby.com/product_p/rrp1552.htm http://www.rpphobby.com/product_p/rrp1540.htm |
![]() | #14 |
Rock Crawler ![]() Join Date: Nov 2007 Location: Bay Area (RWC)
I first went with the the Robinson Racing Hardened Steel Bottom Diff Gear Wraith but after a few packs with my HV 4.5 motor, it bent the out put shaft, Pic Below, enough to cause my drive shaft to whobble pretty bad. So I ended up buying the RR one piece. Comparing the two, the One piece is Beefy. ![]() ![]() |
![]() | #15 |
Well if you are using an AX/SCX case (Vanquish) you could use a one piece AX output, basically all that is interchangeable is top gear and idler gear, the rest is different parts: bottom gear/outputs, rear case half, etc Robinson Racing Outdrive Diff Lock Gear AX10/SCX10 Last edited by BikingViking; 02-12-2013 at 11:23 PM. |
![]() | #16 |
Oh I guess I might have to sell my VP case I don't even have in my hands yet!! or maybe just use the front half of the case put the one piece bottom gear and not worry!! I am kind of mad at myself for not having a clue. Now I know. I guess I could also sell the VP case and get the HR Wraith one and use the parts then. I know VP is probably better quality but they don't make a full Wraith trans case!! Ahhhhhhhhhhhh. Live and learn!! Only Money right???????????
![]() | #17 |
Get the one piece AX10 gear for your VP case, OR go with the RR gear (just the gear) and the Crawler Innovations outputs. If cash is a problem, run the RR one-piece in your Wraith plastic case for now, and then swap that out for the VP case with the needed outputs later. That's what I'm going to do I think.
![]() | #18 | |
RCC Addict ![]() Join Date: Oct 2011 Location: Crawlerado
| ![]() Quote:
![]() Last edited by TheScaleAddict; 02-13-2013 at 06:34 AM. | |
![]() | #19 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Or sell the VP case (other than being pretty its tolerances weren't worth the money on the 3 I tried to assemble with good gears at Nationals with SuperShafty Rick). The HotRacing case (they make a wraith specific one) is real nice. Everything fits right too. |
![]() | #20 | |
| ![]() Quote:
Pros vs. cons ? | scalemudder | Axial SCX-10 | 9 | 02-02-2013 03:13 PM |
pros/cons of 2.2 vs 1.9 tires? | jp0160 | Axial SCX-10 | 12 | 12-13-2012 08:51 AM |
Pros and Cons | wardal | General Crawlers | 1 | 11-21-2011 06:20 PM |
Pros and Cons | Iberian | Newbie General | 20 | 01-13-2010 07:22 PM |
Pros and Cons of 50/50 to 60/40 | zboarder720 | Newbie General | 5 | 05-14-2006 10:13 PM |
