03-05-2013, 05:46 PM | #21 |
| Re: 4WS vs dig vs UD/OD ?
Higher ratio gears will in reality put more strain on the rest of the drivetrain. UD gears which are lower gears would take some of the strain off of the rest of the system. You can get wheel speed by changing your pinion to a larger one. Or the by installing a faster motor.
03-06-2013, 07:53 AM | #22 |
I finished my latest Wraith and realized I had a set of dogbones, knuckles, chubs, steering linkage, and servo. I just need bearings and a servo mount for the rear axle. So, I'm considering giving rear steer a try too. I have a FS-GT3C so I was going to set it up for thumb button to switch on/off/crab and then have one of the trims set to dual rate or expo for the rear (need to play around). So, you could be running in 4ws with the expo set pretty high so you could steer as much as 75% in front and not get much travel in the back. Then when you turn the wheel the rest of the way, the back end swings around. |
03-06-2013, 07:57 AM | #23 | ||
| Re: 4WS vs dig vs UD/OD ? Quote:
03-06-2013, 08:08 AM | #24 |
| Re: 4WS vs dig vs UD/OD ? |
03-06-2013, 04:12 PM | #25 |
Quarry Creeper Join Date: Oct 2012 Location: high desert CA.
well i get the deal about less strain using ud gears,, but you didnt answer my question about getting more wheel speed with od/od you simply said to change things that are obvious to change to get wheel speed,, it was just a simple question of does it? no need to tell people a different way o doing it and ignore there question completely,, no wonder it takes so much searching to find good info on these forums! everyone gives a bullshit answer and quotes other bullshit answers with more bullshit,, Last edited by JDCrawler27; 03-06-2013 at 04:23 PM. |
03-06-2013, 04:17 PM | #26 |
that's not nice... here's my od/od on 2s: |
03-06-2013, 04:25 PM | #27 |
wasnt trying to be mean just gets old asking questions to people looking for knowledgeable info and get crap info in return,, and imo if you have 800+ post on this site you think you would know a little bit about this stuff but i guess im wrong, |
03-06-2013, 04:30 PM | #28 |
03-06-2013, 04:34 PM | #29 |
BTW, here's your answer right in the description of the product: "The higher gear range offers higher top speed (36/14)" Axial 36/14 Gear Set [AXI30401] | RC Cars & Trucks - A Main Hobbies |
03-24-2013, 08:30 PM | #30 |
Rock Stacker Join Date: Feb 2013 Location: North Texas
whats the advantage of running OD up front and UD in the rear? thats what yall are talking about right? and would that be possibe with the Gmade R1 portal axles because ive yet to find different ring/pinion gears for it? |
03-25-2013, 04:46 PM | #31 |
Pebble Pounder Join Date: Nov 2012 Location: Stoke on trent , England
Imo Ch 3 dig Ch4 Rear steer Ud od gears :LOL: Depends what power you run . Jack. |
03-25-2013, 08:01 PM | #32 |
Quarry Creeper Join Date: Dec 2012 Location: Cottage Grove MN
So would this setup be correct for strictly Crawling?? Front Axle: (36/14) Over Drive? Rear Axle: (43/13) Under Drive? |
04-02-2013, 10:29 AM | #33 |
Newbie Join Date: Oct 2012 Location: Canada
I was also wondering if the above setup is correct?
04-02-2013, 06:53 PM | #34 |
04-03-2013, 02:17 PM | #35 | |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
If you take a truck, crank the front wheels in one direction and drive in a complete circle. Since the rear tires are following the front tires they will travel a slightly shorter distance. Running od/ud gears will rotate the front wheels faster compensating for the difference in distance. Even if you don't turn in a complete circle the rear tires travel a shorter distance than the front. The other advantage of rotating the front tires faster is it creates a slight tension between front and rear which can help climbing. Unfortunately this tension puts strain on the drivetrain which can kill motors. The R1 axles seem to be ignored by aftermarket like a fat girl before happyhour so there isn't a bolt on od/ud. You may be able to replace the portal gears with pinion gears to change the ratio and get od/ud Last edited by spookyseven; 04-03-2013 at 02:25 PM. | |
04-03-2013, 02:59 PM | #36 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
06-19-2013, 07:12 PM | #37 |
Rock Stacker Join Date: May 2013 Location: Joshua Tree
06-20-2013, 02:56 PM | #38 |
Quarry Creeper Join Date: Aug 2009 Location: Gamecock Country
Underdrive and dig has worked well for me, but if you are going to be driving pretty fast often(especially on pavement, which my Wraith has never seen) you'll want to use the same gear ratio front & rear like others have said.
06-26-2020, 03:33 AM | #39 | |
Newbie Join Date: Nov 2019 Location: ENUMCLAW
07-05-2020, 08:47 PM | #40 |
Newbie Join Date: Nov 2013 Location: Yuma
I prefer OD/UD with 4ws. It has helped with lines that others with dig cannot do. Take your time and set the end points so the 4ws and crab will track correctly. I would avoid using it until I took the time to set the steering throw.
4WS vs dig vs UD/OD ? - Similar Threads | ||||
R1, 4ws or dig? | mrbenn | G-Made Crawlers | 5 | 10-14-2010 05:12 PM |
dig or 4ws | numbskul | Newbie General | 12 | 02-04-2010 08:23 PM |
4WS or DIG????????? | merlcrawl | Axial AX-10 Scorpion | 57 | 11-07-2009 11:10 AM |
Dig and 4WS | SeanD | General Crawlers | 1 | 03-28-2008 01:10 PM |
4ws vs dig vs both | chevy42083 | General Crawlers | 28 | 10-10-2007 12:25 PM |
