05-06-2012, 12:25 PM | #1 |
Newbie Join Date: Feb 2012 Location: Sterling
| Axial wraith battery
I have a 5000 mah hard case lipo and I was wondering if there was any way to fit a bigger battery in the wraith?
05-06-2012, 12:33 PM | #2 |
| Re: Axial wraith battery
why do you want such a big battery? i have a 3300 2s2p in my wraith and get an hour or more of run time out of it.
05-06-2012, 12:38 PM | #3 | |
Rock Crawler Join Date: Jul 2009 Location: greeley
| Re: Axial wraith battery Quote:
I'm running a 4000Mah. The only reason I went this big is so I could use the Batt. in other cars too. 3300 mAH of a high C rating would be good too. | |
05-06-2012, 12:42 PM | #4 |
my 3300 is 40c. it is a good size and gets you lots of run time.
05-06-2012, 01:04 PM | #5 |
Rock Stacker Join Date: Dec 2011 Location: calverton
i can fit my 4400mah 3s in the back tray, barely, but it fits.
05-06-2012, 01:34 PM | #6 |
My 5000 fits and it runs for about 45 minutes, I have a traxxas vxl system in my wraith so it uses a lot more but the problem is when I take my truck out I don't have anyway to charge the battery so I want a 2nd one that was a little bigger so I could go for about 2 hours.
05-06-2012, 01:46 PM | #7 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
Jew, I have a VXL in my wraith w/a 5000 3S and get alot more than 45 min of run time. You might have a bad battery.
05-06-2012, 01:55 PM | #8 |
It's a turnigy battery, I know it's not the best but I didn't feel like spending 60 or more on a battery.
05-06-2012, 02:14 PM | #9 |
i spent $40 on mine. i have a castle creations MM and a HH 25t motor and i get over an hour of run time. cheaper batteries use cheap cells. they wont run as long or have as long of a life span as a higher quality battery.
05-06-2012, 05:32 PM | #10 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
I have a 3300 kv venom motor in my wraith and use a 5000 mah Onyx battery. I ran mine for just over an hour today! It seems to fit just fine in the back and it was only $45.00.
05-06-2012, 05:55 PM | #11 |
Quarry Creeper Join Date: Jan 2012 Location: My house
I run a 3cell on my wraith 5000mah I put it in the rear of the rig, and it fits. If u wanna know how let me know I'll tell u what I'm running on my wraith
05-06-2012, 06:10 PM | #12 |
Quarry Creeper Join Date: Apr 2008 Location: PNW
5000 2s Gens Ace hardcase. ROAR approved, almost 3 hours of runtime. Affordable too, check out Hobbypartz.
05-06-2012, 06:52 PM | #13 |
Newbie Join Date: Dec 2011 Location: Coquitlam
I use a Tunigy 5000mAh 2s 30-40c hardcase and I get about an hour and a half of run time, why do you want a bigger battery?
05-06-2012, 07:06 PM | #14 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
Driving style is the biggest difference in LiPo duration. It's evident that many that have posted are basher type drivers. Pedal to the metal and battery life goes quickly. I, on the other hand, built my Wraith for crawling mainly. I don't think it's ever seen full throttle for more than a few seconds. A 2200 3S LiPo will last me over well an hour. Probably closer to 1.5 hrs and it's still not close to LVC. |
03-05-2013, 08:50 AM | #15 |
Newbie Join Date: Feb 2013 Location: ellensburg
alright im gonna get a tekin 35t HD motor with tekin fxr esc and need help with what gearing i should get that will make it crawl better and work well with the motor and secondly which lipo battery i should get to run about 1-1.5 hours and will fit in the front of my wraith any help would be awesome
03-05-2013, 12:25 PM | #16 |
Comp course took just over an hour slow and technical one 3s 2200 went the hole way though I did have a spare battery in my pocket. Bashing I don't even get 45 minutes |
03-05-2013, 04:40 PM | #17 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
A buddy of mine runs a cheepo 5000 mah pack in his wraith and gets over 2 hours out of it crawling and trail rides. I use tunigy 2200 3S in mine and get a little over an hour run time out of each. They were only around $10 each so I bought 4 at the time and usually have 3 in my pockets and one in the rig so I don't ever have to stop driving to charge batteries. At comps we break for lunch. I go eat while others are charging there batteries. At around $10-15 each and there starting on there 3rd summer, I can't complain about Turnigy lipo's. |
03-05-2013, 04:49 PM | #18 |
ive ran thunder power batts in helicopters before playing with crawlers i had switched to turnigy and man i think there awesome specialy for the price reduction and i dont see any less performance then the thunderpowers and tunrigy cost less than half. i have about 8 batteries from 2200-5000 to pick from all tunrigy but one is rhino. rhino does okay to and was also priced right. the i mostly run 3s a 2s 2200 wont get as much drive time as 3s 2200 ive got alot of batts |
03-05-2013, 05:00 PM | #19 |
Quarry Creeper Join Date: Aug 2011 Location: Antioch by a rock!
With the battery box up front I can fit a Sky 5000 2S 20C and crawl for almost 2 hours. Also fit a 2200 3S in there too
03-05-2013, 09:59 PM | #20 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
i slot a 4000 sky 3 cell hardcase behind the dash, get 1 hr 45 min easy. i get 2 hours most of the time |
Axial wraith battery - Similar Threads | ||||
Battery location and electricle on Axial wraith | muddywaters | Axial Wraith | 5 | 01-15-2012 04:36 PM |
