03-07-2013, 07:10 PM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
| What to expect from bigger turn motor?
Im strictly crawling with my Wraith. It currently has an Axial 20T motor. I think it works pretty damn good. If I put in a 27, 45, 55T motor is it really more torque? power? Would I notice an increased crawl ability? I'm running 87/14 gearing IM still brand new to crawlers so I only know what I have. Last edited by Bansh88; 03-07-2013 at 07:20 PM. |
03-07-2013, 07:16 PM | #2 |
| Re: What to expect from bigger turn motor?
Yes you'll gave more torque. But if you get a 27t Holmes Hobbies torque master you'll have speed and torque.
03-07-2013, 07:29 PM | #3 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
Will make a huge difference. I'm running a Holmes 35t
03-07-2013, 07:31 PM | #4 |
Quarry Creeper Join Date: Sep 2007 Location: No Cajones en El Cajones
Bigger parts bill.
03-07-2013, 07:31 PM | #5 |
Axial 55T is less than $20. Is there a downside to that high turns?
03-07-2013, 07:33 PM | #6 |
| Re: What to expect from bigger turn motor? |
03-07-2013, 07:39 PM | #7 |
Quarry Creeper Join Date: Dec 2012 Location: Cottage Grove MN
I have my Wraith setup for crawling only... Parts include: Axial 87 Tooth Spur Gear Axial 14 Tooth Pinion Gear Tekin FXR ESC and 35 Turn Motor (Crawler System)= Freakin AWESOME !!! Torque went through the roof with the gear swaps. This setup crawls really slowly. Its like my old Jeep TJ with 4.56 gears in low range and Atlas Transfer case. |
03-07-2013, 07:54 PM | #8 | |
| Re: What to expect from bigger turn motor? Quote:
If you are ready to look at different motor options, then also check the HH Crawlmaster 13T. The 5 slot arm produces really smooth low speed crawling. A 13T Crawlmaster is about the same speed as the 27T TorqueMaster. | |
03-07-2013, 08:01 PM | #9 |
03-07-2013, 08:15 PM | #10 | |
Looks like I'll keep an eye out for a Holmes | |
03-07-2013, 09:53 PM | #11 |
LOLZ, just bustin' your ballzderdashesshh man, besides the RTR cost is just the buy in, next is to replace it with all new shit. Then, repeat over and over....
03-20-2013, 07:44 AM | #12 |
Newbie Join Date: Mar 2013 Location: Central city
Only had my wraith a few weeks but I'm running a 17.5 Orion brushless motor that I use to run in my 2wd buggy. I have it geared 16/87 and it has plenty of grunt and even a little speed.
03-20-2013, 08:09 AM | #13 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
Higher turn# more torque, less Rpm Lower turn# more Rpm,less torque @30-35t on 3s is a decent combo for crawlability and a lil wheelspeed when needed. |
03-20-2013, 08:32 AM | #14 |
Motors faster than about 2100kv (27t torquemaster type) produce less torque because of brush saturation with standard copper brushes. Sealed can motors lose torque a bit earlier from the cheaper brush compound. Anything 27t or slower will have great torque.
What to expect from bigger turn motor? - Similar Threads | ||||
Higher Turn Motor Vs Lower Turn Motor ? | ReignMan | Newbie General | 10 | 11-15-2009 10:40 PM |
higher turn motor or lower turn motor......... | bob1961 | Newbie General | 6 | 03-18-2008 09:16 PM |
Do I need a bigger battery or different motor? | veewee25 | Electronics | 5 | 12-22-2007 11:56 PM |
